Question about HP Compaq dc7100 Ultra-slim PC Desktop
HI WHAT IS THE MAX RAM MY HP COMPAQ 7100DC CAN TAKE..3GB OR 4GB
  • 326 Answers
How much maximum ram size can i use?
If you are running a 32bit OS the max that will work, no mater how much you add, is around 3.8GBs. Memory in pairs is best, 1gb x2 or 2gb x 2, for instance. If you have a 64bit system OS it will use more. Your hardware/software will dictate the amount the machine will use efficiently
Nov 15, 2012 | Computers & Internet
214-Dimm Config Warning
Just had same problem. Found a solution:
I have an old HP Compaq dc5000MT. It has 4 RAM slots
Here's what DIDN'T work:
1gb + 1gb + 512mb + 512mb
1gb + 512mb + 512mb + 1gb
512mb + 1gb + 1gb + 512mb
Here's what DID work:
1gb + 512mb + 1gb + 512mb
I'm sure that:
512mb + 1gb + 512mb + 1gb would probably work as well.
From my guess they're are 2 "channels" (slots 1&2 are channel 1, slots 3&4 are channel 2) and you have to keep the amount of RAM balanced on both slots and in the same order.
Another thing to note with the old XP OS. IT ONLY WORKS WITH 3GB or RAM. MAX. So 1 + 1 + 1 + 1 (4gb) WILL NOT WORK... PERIOD for XP. Vista, 7, 8 etc. allows you to use a ton more ram + readyboost. They need all the help they can get though since they are major resource hogs.
Aug 15, 2011 | HP Compaq d530c PC Desktop
I have a compaq presario cq60-215dx notebook pc, was wondering how do i go about upgrading the RAM?
I have checked the Compaq Presario CQ60-215DX Specification It Originally has 2GB Memory and supports upto 4GB RAM max. If you intend to upgrade the RAM, you can buy additional RAM and put them in you system. Here is the HP Guide to Replace RAM and How to Upgrade RAM Guide
Compaq Presario CQ60-215DX has two RAM slots for DDR-2 (533 or 667) Memory Modules. First you have to check that the RAM slot is available for additional RAM. I believe that it has two modules of 1GB each in both slots. So, you have to get two modules of RAM 2GB each to upgrade to 4GB (or one 2GB RAM module to upgrade to 3GB). Hence, it is recommended that you get 2GB replacement module for each 1GB module you have on you system from local laptop repair/ service center, which would be cost effective as existing 1GB RAM Modules would be useless for you upon upgrade.
Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Dec 31, 2010 | Compaq Presario Notebook
HP Pavilion dv7 ram upgrade, came with 4gb ram, supposedly is able to upgrade to 8gb, is this possible?
Yes. The specifications say the MAX memory is 8GB
Memory 4096MB Memory Max 8192MB
You should go to Crucial.com and run their online tool for ram upgrades. It will tell you exactly how much and what type of memory to add.
Thanks for using FixYa.
Mar 19, 2010 | HP Pavilion dv7-1130us laptop
Blue screen with 4gb, OK with 3gb of RAM on 6720s laptop Using windows 7 (32 bit) there are 2x slots, but the top slot seems only capable of recognising 1gb of RAM without giving the blue screen at startup...
A 32bit OS and Processor is able to Identify and work with upto 3GB of memory.
That may be the cause of the issue
Even if any computer has more then 3gb of ram it will showup only upto 3gb.
if you install 4gb or more then also it will not show up.
.........and second reason, may the ram that you are using are not identical or one of them is not working properly.
Check the specifications of the ram and also try using one a time.
Thanks and Regards
Jan 03, 2010 | HP Compaq 6720s Laptop
Can I upgrade my Macbook Pro to more than 4GB ram?
4GB is the MAX but only 3GB is utilized.
What Os are you running. Tiger Leopard Snow Leopard?
Nov 23, 2009 | Apple MacBook Pro Laptop Computer with...
Upgrading My hp530 laptop
It is working.
Tested first with one new module with 2GB RAM, then with 2 modules, 2GB (new) + 1GB (original). Post and Windows are showing 3GB.
The HP 530 notebook is working OK.
Sep 12, 2009 | HP Compaq 6720s Notebook
How much memory can this product of hp take i have cone some test and i think it should be up to 2gb per slots i have try to upgrade it to 4gb and fail i have even try 3gb and fail but it works with 3gb if...
If you are using the XP or Vista OS, if you are going to install more than 3 GB of Memory then it fails to show up on the computer properties.
Once you install the memory then you may check the BIOS for the memory installed in the system, the BIOS shows the exact amount of memory installed in the system.
You system is capable of 4 GB of RAM.
Sep 10, 2009 | HP Compaq 6720s Notebook
4gb ram wont work
its not XP it will be the maximum capabilities of the amount of memory the laptop can handle, please refer to manual for max amount, i would suspect 2GB max
Aug 19, 2008 | HP Compaq 6720s Notebook
HP Compaq dc7100 Ultra-slim PC Desktop Logo
192 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
