Question about Dyson Flowcheck CRO1 Front Load Washer
Hi my dyson cro1 flow check is making the fuse box trip in my house
Just had that problem myself and it turns out the heater was faulty and needed replaced.
Mines would go as far as filling up and as soon as the heater kicked in, it would trip the main fuse.
Heater was replaced and all is working now... although engineer also found a seperate fault with pump, and will replace that in a couple days - included within the original Dyson call out charge - £99
Posted on Nov 02, 2010
Drum is not turning
Dyson Flowcheck CRO1 Front Load Washer "drum seized ...
www.fixya.com > ... > Dyson Flowcheck CRO1 Front Load Washer
Dyson Flowcheck CRO1 Front Load Washer, drum seized related issues. Get free help, solutions & advice from top Dyson experts.
Aug 08, 2015 | Dyson Memory CRO1 Front Load Washer
I HAVE FAULT F11 HOW DO I FIX IT
Dyson Memory CRO1 Front... Fault f11 Solutions - Fixya
www.fixya.com > ... > Dyson > Dyson Memory CRO1 Front Load Washer
Dyson Memory CRO1 Front Load Washer, fault f11 related issues. Get free help, solutions & advice from top Dyson experts.
Aug 08, 2015 | Dyson Flowcheck CRO1 Front Load Washer
How to remove motherboard on dyson
go to facebook group dyson cr01 repair and read away.
Aug 25, 2014 | Dyson Memory CRO1 Front Load Washer
Hi got the F11 fault on my Dyson Washer just tried the reset and has not worked looks like the fuse has gone can the fuse be changed easily?
Sorry to hear you're having difficulties with your Dyson Contrarotator. It's probably best if you get in touch with us directly, so one of our experts can run through some troubleshooting over the phone, and provide the information and assistance you need.
You can call us free on 08002980298 - our Helpline is open from 7am until 10pm, 7 days a week. We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Aug 17, 2011 | Dyson Flowcheck CRO1 Front Load Washer
Dyson croi front loader showing up fault 6 please advise re same
Hi its Darran at Dyson.
So that we can help you with this issue, please contact our Helpline on 0800 298 0298, between the hours of 7am - 10pm, 7 days a week.
We look forward to hearing from you.
Kind regards
Darran
Dyson Customer Service
Mar 16, 2010 | Dyson CRO1 Front Load Washer
Hi my dyson washing machine comes on for 30 secs than turns off
I would recommend switching the machine off and contacting our Helpline on 0800 298 0298.
Kind regards
Darran
Mar 15, 2010 | Dyson Memory CRO1 Front Load Washer
How do i repair a f11 code on my dyson cro1 contrarotor
Get Dyson out, the powerboard has failed, don't be fooled into thinking replacing the fuse on the board will do the job, it doesn't, a component has failed on the PCB which has caused the fuse to blow in the first place, £95 call out i'm afraid.
Dec 30, 2009 | Dyson Flowcheck CRO1 Front Load Washer
How to repair a F 11 fault on a DYSON CR01 flow check
f11 fault code is a problem with the main power board (could be blown fuse) or a blown board check the fuse the board is behind the back plate in the bottem right corner (looking from the back of the machine.(!unplug before you take apart!)
May 29, 2009 | Dyson Flowcheck CRO1 Front Load Washer
Dyson cro1 stuck in self clean mode??any ideas
hiya did you have any luck with your self clean problem? I only ask cus i have the same problem kind regards Dave
Apr 05, 2009 | Dyson Memory CRO1 Front Load Washer
Dyson cro1 fault f11 came up after interupted power suply
normally error like this disappear when a hard reset is performed? did you leave the unit turned off by plugging out from wall power for one night ??
The F11 fault is a fuse blown on the circuit board.
Apparently this fuse failing can blow the board so you may have to change the board if needed. The board is located at the back of the machine so you need to take the back off, unplug the board, change the fuse which you can buy at Maplins and put the board back.
If it works fine, if not then you need a new board. Hope this helps you.
First make sure machine is turned off.
Second press & hold temperature button .
Thirdly press the on button & hold at the same time as the temperature button.
Fourthly release the 2 buttons at the same time .
Fifthly press the soil button .
Sixly turn machine off then back on & F11 message saying fault F11 must disappear.
if not try this process once again. if the error is not cleared then you will have to do as i have said you earlier.
Jan 18, 2009 | Dyson Flowcheck CRO1 Front Load Washer
Dyson Flowcheck CRO1 Front Load Washer Logo
108 people viewed this question
Top Dyson Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Dyson Washing Machine Expert? Answer questions, earn points and help others
