Question about Toshiba TEC B-472 Thermal Label Printer
NOT PRINTING HELP PLEASE
Hi All,
we have here barcode printer, once we press the FEED button
an error will occur and it noted on screen "NO RIBBON" but
there's a ribbon inserted on it. can you please assist me please.
thanks..
  • 300 Answers
Make sure that the ribbon is correctly loaded in the machine. Here is what to look for:
On the back side of the print block, the ribbon must pass between the two parts of the ribbon sensor. The upper sensor is located on the back of the print block itself, while the lower sensor is located on the black plastic arm that extends from the main printer wall.
Posted on May 16, 2008
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
Card keeps jamming and ribbon breaks
Download the Fargo Diagnose Utility .
But Requires Windows 98, 2000, NT, XP, Me; 16MB of RAM (Recommended); SVGA Monitor (800x600 or higher is required); and at least one printer drivers installed.
If a card becomes jammed inside the printer, the LCD Display will indicate
approximately where it is jammed. At this point you can either try to correct the
problem and continue printing with the same card, or remove the card completely
and continue printing with a new card. Refer to the following steps for instructions
on doing either:
1. Leave the power ON, and open of the printer?s Top Covers.
2. Remove the ribbon and overlaminate as needed.
3. If you would like to try to correct the problem and continue printing with
the same card, do so by pressing the On/Cancel button to advance the card or
the Pause/Resume button to reverse the card. Use these buttons to help free the
card from its jam. Try not to move the card too far from where it was just
before the jam occurred. Once the jam is cleared, replace media, close the Top
Cover(s), and press the Pause/Resume button to resume printing.
4. If you would like to remove the jammed card completely, do so by using the
On/Cancel and Pause/Resume buttons to manually eject the card. Then,
replace media, close the Top Covers, and press the On/Cancel button. At this
point, the LCD Display will prompt you to either press the Pause/Resume
button or the On/Cancel button. Pressing the Pause/Resume button will cause
the printer to feed in a new card and reprint the job which originally jammed
along with all subsequent jobs still being sent. Pressing the On/Cancel button
will reboot the printer and cancel all jobs within the printer?s memory. In this
case, you must also cancel and resend the print jobs from your computer.
CLEARING A RIBBON OR OVERLAMINATE JAM
If the ribbon or overlaminate becomes stuck to a card or jammed inside the printer,
the LCD Display will indicate that it is jammed. Refer to the following steps to clear
the jam:
1. Leave the power ON, and open the printer?s Top Covers as necessary.
2. Remove the Take-Up core (the side with used ribbon or overlaminate on it)
from in between the two black Drive Hubs.
3. Steadily pull the ribbon or overlaminate free from where it is jammed. If stuck
to a card, pull the ribbon or overlaminate off the card and throw the card away.
If it is jammed underneath the rollers, press and hold down the printer?s
Pause/Resume button as you gently pull up on the ribbon or overlaminate. Do
not **** the ribbon or overlaminate to free it, since this will increase the chance
of breaking it. If it does happen to break, simply tape the broken end of the
supply roll directly onto the take-up roll. Then, wind a few inches worth of
ribbon or overlaminate from the supply roll onto the take-up roll. Be sure the
ribbon or overlaminate is passing beneath both the supply and take-up rolls.
4. Once the jam is cleared, replace media, close the Top Covers, and press the
On/Cancel button. At this point, the LCD Display will prompt you to either
press the Pause/Resume button or the On/Cancel button. Pressing the
Pause/Resume button will cause the printer to feed in a new card and reprint
the job which originally jammed along with all subsequent jobs still being sent.
Pressing the On/Cancel button will reboot the printer and cancel all jobs
within the printer?s memory. In this case, you must also cancel and resend the
H. CLEANING THE CARD FEED ROLLERS
To assure consistent printer operation, all of the gray card feed rollers within the
printer should be cleaned during every ribbon change (every 250 prints) or if the
rollers are noticeably dirty. To clean these rollers, use the special adhesive-backed
Cleaning Cards from the Printer Cleaning Kit. Refer to the following steps to run a
Cleaning Card through your printer:
1. Open the Top Covers and remove all print supplies from the printer. Leave the
printer power ON and the Top Covers open throughout this procedure. The
Cleaning Roller Assembly can also remain within the printer during this
cleaning process.
2. Remove the Cleaning Card?s adhesive backing paper.
Nov 12, 2010 | Fargo Pro L ID Thermal Printer
Card jams and ribbon keeps breaking
CLEANING THE INSIDE OF THE PRINTER
As you use your printer, dust and other foreign particles may accumulate inside
the printer?s case. These particles are attracted to the underside of the ribbon by
static produced during printing and can cause voids on the printed image.
Periodically, use the following procedure to remove dust and other foreign
particles:
1. Open the printer?s Top Covers.
2. Remove the ribbon and overlaminate from the printer.
3. Use a Cleaning Pad from the Printer Cleaning Kit or a soft, lint-free cloth
slightly moistened with isopropyl alcohol to wipe out all visible areas inside
the printer. Remove any debris that may be inside. Be extremely careful not to
let any alcohol drip inside the printer!
4. Once the cleaned areas are completely dry and free of foreign debris, re-install
the ribbon and overlaminate, and close the covers.
F. CLEARING A CARD JAM
on doing either:
Section 7: Maintenance 53
Pro-L Card Printer User?s Manual
G. CLEARING A RIBBON OR OVERLAMINATE JAM
the jam:
cleaning process.
HP Photosmart C5180 Ink System has Failed Error:0xc18a0306 Can't clear this error
Here is what you can try:
1. Turn off the power and unplug it from power source.
2. Open the right side of the printer (looking at the front).
3. Disconnect, by pulling gently, both white flat ribbon cables off the main circuit board.
4. Plug in the power source and turn the printer on. Wait till you get a error message and push "OK".
5. Unplug the power source.
6. Reconnect the flat ribbon cables by aligning and carefully pushing them into the conectors on the main circuit board.
7. Plug in the power source and turn the printer on (Printer preparing occurred).
8. The 0xc18a0306 error should now be gone.
get more information for HP printer errors . Hope this helps you.
Good Luck!
Aug 14, 2010 | HP Photosmart C5180 All-In-One InkJet...
Ribbon Error
According to the user's manual this message indicates a problem with the ribbon sensor. As a test, set the unit for thermal direct printing and attempt to print a barcode. You will not see the code if yoiu are expecting thermal transfer, but the paper/label should feed like it is printing. That will indicate that the printer is functioning. At this point, the sensor needs to be replaced.
Hope this helps,
Dan
Apr 22, 2010 | Toshiba TEC B-472 Thermal Label Printer
Hi can you help ? My zebra TLP 2824 printer keeps printing out of alignment. I reset the printer by holding the feed button while powering on but instead of printing dump info the label moves for a while...
If you are using a ribbon remove it and perform a calibration, hold down feed key for 2 seconds as you power on, release key and wait for it to complete its calibration, when it has stopped shifting labels (wait for 10 secs to be sure) HIT THE FEED KEY to exit dump mode. If it has successfully calibrated it will feed a label each time you hit feed key. Re-install ribbon, make sure ribbon is pushed formly onto drive sprockets and then re-run the calibration..
If this does not fix problem. download firmware to latest version. This will automatically reset printer to factory default condition.
Nov 12, 2009 | Zebra TLP 2824 Printer
My Canon I550 quit printing.
An error has occurred in the printer. The number of flashes indicates the type of error, as outlined below. Check the cause and take the appropriate action.
bullet.gif Two flashes: Out of paper or paper feed error
Replace the paper correctly and press the RESUME/CANCEL button.
bullet.gif Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, replace the paper in the printer correctly and press the RESUME/CANCEL button.
See Paper Jams
bullet.gif Four flashes: Empty ink tank
If you press the RESUME/CANCEL button, it will continue printing with an empty ink tank. However, when printing is finished, replace the ink tank immediately. If you continue printing with an empty ink tank, it will be a cause of trouble.
See Replacing an Ink Tank
bullet.gif Six flashes: No print head installed
Install a print head.
bullet.gif Seven flashes: Defective print head
Contact a Canon service representative.
bullet.gif Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact a Canon service representative.
i_note_us.gif Note
Canon recommends to call for service as soon as this error occurs. Once the waste ink tank becomes completely full, printing will no longer be possible.
bullet.gif POWER lamp flashes alternate green and orange:
An error that requires contacting a Canon service representative may have occurred.
Turn the printer off and unplug the printer from the power supply. Plug the printer back in and turn the printer back on.
If the problem remains, contact a Canon service representative.
Apr 14, 2009 | Canon BubbleJet i550 InkJet Printer
Hi, My printer model is TLP 2844.i m facing the problem in printing. The printer is hang after one or two lines printing and red LED are ON and I press Green button repeat same as before. Please solve my...
Solid red light. This indicates the printer is in an error state and will not print until the error is cleared. Check to make sure the printer is not out of labels or out of ribbon if it is a TLP model.
A solid red light will occur if
  • the printer is out of labels
  • the printer is out of ribbon ( TLP models only )
  • the printhead is open, not latched down all the way. Press down on the top cover of the printer to see if the error light clears and goes to green.
  • the ribbon spool is slipping on the ribbon spool holder on TLP models:
These 2 links will help you troubleshoot the problem:
https://support.zebra.com/cpws/docs/eltron/2844/28x4_rib_det.htm
https://support.zebra.com/cpws/docs/eltron/2844/2844_tsguide.htm
Click on this link. Or copy and paste it into your browser.
If I could be of further assistance, let me know.
If this solves your issue, please be kind to rate it.
Thanks, Joe
Mar 15, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Zebra 2824 red light
Hold the feed button while turning on the printer. After a config label prints, turn the printer off and then on again, and try printing again.
Also, make sure the lid is closed far enough to engage the lid sensor. If the red light comes on again, press down a bit on the lid, hit the feed button and try to print again.
Sep 03, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Will not print on all four lables, and does not print in the same place each time.
for starters you need to calibrate your printer.
Note: If printing in Direct Thermal Mode, default the printer first (4 flashes).
1. Load the labels and ribbon (if used) and close the printer
2. Turn on the printer power.
3. Allow the printer to feed or error out.
4. Press and hold the feed button until the green status LED flashes once, then twice. Release the feed button.
6. The printer will set the media sensor for the label backing being used and then automatically feed until a label is positioned at the printhead.
7. A profile of the media sensor settings (similar to the example in Figure 1) will print. Upon completion, the printer will save the new settings in memory and the printer is ready for normal operation.
8. Press the feed button. One entire blank label will feed. If this does not happen, try defaulting (Hold the FEED button until it flashes 4 times)
Jun 23, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Toshiba TEC B-472 Thermal Label Printer Logo
233 people viewed this question
Top Toshiba TEC Office Equipment & Supplies Experts
matt
matt
richie46
Are you a Toshiba TEC Office Equipment and Supply Expert? Answer questions, earn points and help others
