Question about Plantronics Voyager PRO Bluetooth Headset
Cutting in and out. best described as sounds like i am talking into a fan.
    Prodigy:
    An expert who has answered 500 questions.
  • 537 Answers
Make sure that it has a good connection, try to re-pair the headset to your phone. Before running through the pairing process, be sure to totally delete the headset from the phone's menu. You may want the headset turned off for this process.
Once you make your cell phone discoverable, then put the Plantronics Voyager Pro headset into pairing mode by holding the power button until the headset flashes red and blue. Here is the link below for the Voyager Pro pairing instructions:
Plantronics Voyager Pro User's Guide
Good luck from Headsets Direct!
http://www.headsetsdirect.com/plantronics-voyager-pro-bluetooth-pairing-instructions
Also if you have a different phone available just to test, see if it does the same thing.
Posted on Nov 02, 2011
Why would my Veon 55" tv short circuit? turns off thn comes bak on but does that through out the day ...maybe 6 times a day ...
Sounds like a heat protecting switch is getting triggered . So I would suggest placing a fan at the back of the unit to keep it cool and to test if this is the problem as I have had issues like the one you are describing and a fan stopped the constant cut outs .
Oct 18, 2017 | Televison & Video
Xerox DC12 has cut out whilst making repeated off and on sounds and will not restart.
That suggests either the power supply or the control board is failing.
If my printer did that I'd call some local service agents and find one who will talk you through what might be wrong, what he can do about it and how much that will cost...
If he won't talk you through that much, go elsewhere.
Aug 23, 2016 | Xerox DocuColor 12 Printer
TURNED OFF FAN ON TOP OF UNIT WHILE CLEANING COILS. WENT TO TURN IT BACK ON AND THE FAN WON'T START
Could you please describe the problem you are having a little better?
Are you talking about the condenser fan, evaporator fan or the damper?
Nov 08, 2012 | KitchenAid KSSS48FK Side by Side...
Buick running hot and cutting off.cools and runs good until it cuts off again. get red hot underneath the car
may want to have the convertor back pressure tested. sounds as if the honey comb in the convertor is breaking apart and has clogged it up.
Aug 02, 2011 | Buick LeSabre Cars & Trucks
Turned on AC was running fine. 30 minutes later began to hear a strange noise. Opened AC/Furnance closet & heard a sound best described as air letting out of a tire. It seemed to be coming from...
Hi!!
This means that the condenser fan motor (outside unit) failed, this caused to build hi pressure and either activated a safety valve to release the extra pressure or blew a line and R22 Refrigerant escaped from system.
The fix is to replace motor fan and capacitor find the leak and refill system with R22 Refrigerant Gas. It is safe to turn on the Fan Only mode on the Thermostat until a HVAC Tech arrives.
To perform this job parts and labor included will cost: about $300 -.$400. Look on the Yellow Pages for a Tech in your neighborhood.
Good Luck!! Don't forget to Rate this post!!
Aug 13, 2010 | Goodman CKL42AR42 Air Conditioner
Condenser fan motor runs constantly compressor stops but fan still runs
Don't know what type of unit you're talking about but usually there's a relay or contactor to turn the fan on and off. Sounds like it may be stuck closed. The points may be pitted. Best to change.
Jul 15, 2010 | Heating & Cooling
Freezer cold, fridge warm
The small cooling fan in the freezer compartment that sends chilled air to the food side is defective and needs replacement.  Sometimes that are only frozen stuck.
When you receive advice from this website you have to understand that without the item in front of us, we are only able to provide "a best guess" as to what the problem might be based on you description of the defect.  If you haven't described a clear and precise description of the defect you decrease the chances of an accurate reply.  Thank you.
Mar 17, 2009 | Haier HTE18WAA Top Freezer Refrigerator
F61
Sound amplifier ic??******** this guy is talking out of his ***.
F61 relates to fan error. There are two fans, one of them is either spinning too slowly or not at all.
This fan can be purchased in any computer store. Just remove it and take it with you.
Jul 28, 2007 | Technics SC-DV290 System
Plantronics Voyager PRO  Bluetooth Headset Logo
137 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
