Question about Kenmore 16372 / 16374 / 16379 Built-in Dishwasher
Kenmore 16032401 Quiet Guard 4
The machine stopped working midcycle. Went to the parts warehouse and replaced the thermal cutoff (T.C.O). Ran machine again and same issue present.
  • lkfbc May 18, 2008
    I'm going to order today. Can you direct me where I can get a hi-limit thermostat online? Thanks for the help. I'll let you know how it turns out.
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    Have you checked the heating element? Did you replace the hi-limit thermostat at the same time you replaced the TCO. It is highly recommended that you replace the TCO and Hi-limit thermostat at the same time, or more component failures can occur. Post back and let me know.
  • 5,911 Answers
Sorry to take so long getting back to you. Go to searspartsdirect.com and type your complete model number in the "Search by Model Number" window. Follow the links on the next page. You can also try repairclinic.com. The website offer competitive pricing with one of the other usually having the better price. The Sears website offers helpful parts diagrams. If you have any futher questions, please let me know.
NOTE: There may be a possibilty that you could have damaged the part you already replaced. It is recommended that you replace BOTH components at the same time. They are available as a SET on both websites I believe.
NOTE: Make sure your exhause ducting is clear as well before starting the unit or it will overheat and do the same thing.
Posted on May 19, 2008
Maytag quiet series 100 stopped midcycle, smells a little bit of smoke
sounds like a burned belt, once the belt is burned from being loose, the burnt spot gets hard and the pulley will not catch to make the machine run , replace the belt.
Sep 16, 2013 | Maytag Washing Machines
How to connect dryer wires to thermal cutoff
The first thing I would like you to do is get your model number from the dryer, it is located near the inside the of the dryer door. you need to make sure you have the right heater and thermal cutoff kit. The manufacture has more than one type of heater and thermal cutoff kit out, (( some will not work with others ))... Call another parts store or sears and make sure you have the correct parts !!
Most of the thermo cutoff kits have direction and if they are not making scence then the chance of you having the rong one is good !!!!!!!
If you remove the thermal cutoff from your origanal heater and then look at how many conetion pins are left. The new heater and old heater should be the same.
The most common heater is the 2 conection. But they made one with three. and if you have the one with three, it has to be replaced with the same one !!!
Without knowing the model of your machine, I cant tell you how to wire your machine.
I recomend you use the direction that came with the Cutoff kit.
Aug 11, 2010 | Kenmore 62602 Electric Dryer
Loud Buzzing Sound from Dishwasher
have you ever seen green led "Clean" light flashing? before or about the same time the buzzing sound started? and if so that would indicate that the control senses a fault in the temperature rise during the heating cycle and that the electronic control could be reset by initiating a service diagnostic cycle.(which is what you were trying to do) pls reread your manual there are times during that sequence that some buttons have to be pushed at the same time and within a certain amount of time..possible that your machine also has a bad timer which would give you a buzzing noise..if thats the case I would recommend replacing the cpu or control board..or the machin all together..The Kenmore Ultra Wash Quiet Guard name is sears but whirpool has the contract to produce all "kenmore products.hope that helps.
Jul 30, 2009 | Dishwashers
HOW TO REPLACE A THERMAL CUTOFF ON ELECTRIC DRYER
you will need too take off your back panel of your dryer and the heater is on your right the thermal cutoff is on the left of the heater housing at the top and then there is a little white thermal cutoff on your blower housing in the bottom left of the dryer now if this is not how your dryer looks let me know cause there is several different style of kenmore dryers but this is the most common one
Dec 29, 2008 | Kenmore 67082 Electric Dryer
Where is the filter on a Kenmore Quiet Guard 2 dishwasher?
I have a Quiet Guard 4. Same problem so will describe my solution.
1. Remove bottom basket. Remove top basket.
2. Remove bottom washing arm. Unscrew (Gently but firmly) the centre post. Lift arm assembly up and out.
3. Remove overhead conduit. One screw at back, one at top (Philips #2 bit). Rotate whole assembly 45 deg right (Clockwise) and lift off of centre post.
4. Remove centre post (Pull straight up). Remove 4 screws (Star T-20 bit). Lift whole assembly out. Pop off screen and clean.
5. Remove cap over cutter/chopper. There is a single screw at front left (under assembly removed in 4). Remove screw (Star T-15 bit) and cap (Needs some wiggling to free it up). Remove cutter and filter. It is on a spring loaded pin. Pull the cutter blade foreward and then the filter disc straight up. Clean thoroughly as it may be the cause of your problems.
Reassimble. Good luck!
Dec 09, 2008 | Dishwashers
not a dumb question,
is the bottom dishes coming out clean? there is a chopper that breaks and will trap food and not clean the top rack.it is not easy to replace.but not impossible.
Oct 23, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore Elite Dryer, Model: 110 60972990... will not restart.
yes, a DIY person can replace a thermal cutoff. just open the rear of the unit and look for parts with big red wires connected to it. it is round, one small and one big. both have two terminal clips.
if you can find the schematics inside the switch panel, then it would help you further. the thermal cutoff consist of two pc. replace both even one of them has continuity.
tnx 4 using fixya,
drcool
Sep 29, 2008 | Kenmore Elite HE4 Electric Dryer
Dw stopped in midcycle.
There is a thermal fuse located on the electronic control board housing that may have failed.This replaceable part (gray or white) is clipped on to the side of the housing.
May 31, 2008 | Kenmore 24 in. 17032 Built-in Dishwasher
Kenmore 16372 / 16374 / 16379 Built-in Dishwasher Logo
607 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
