Question about Dishwashers
I need granite mounting clips for samsung dmr78ahs dishwasher. Were can I get them?
  • 330 Answers
SOURCE: need side mount brackets gpf65
I don’t know your counter situation, usually you have to put dishwasher in a bottom cabinet and mount both side. Suppose you only have one side to mount, you have to go to home depot to buy a 90 degree metal mounting bar, mount the top part to your top granite support board, the bottom side mount to the dishwasher, it should be a ¾” plywood board underneath the granite, you can use ½” screw to mount it.
Hope this can help you,
Posted on Jun 25, 2008
SOURCE: mounting brackets for granite countertop
This is the best way i have found. You must check this company out. Granite Grabbers www.GraniteGrabbers.com They are extremely simple mounting brackets secured with a very strong double sided adhesive. You do not have to drill you cabinets or deal with any expoy.
I have used them with excellent success, took 5 minutes to install
Posted on Feb 03, 2009
  • 574 Answers
SOURCE: i have granite countertops< so i have to
If you can't find any place on the sides to mount the clips then you can take a piece of wood that matches your cabinets and fasten it to the opening in you cabinet for the dishwasher so you will have somethink to mount the washer to. Make sure your washer is level so you can figure out the gap size at the top, then pull the washer out and mount the wood to the cabinet. You could call the guys who installed the counter tops and see what they would or could do, but I wouldn't drill into the granite myself
Posted on Jan 07, 2010
  • 18 Answers
SOURCE: mounting my dishwasher to granite counter tops.
Ask a local granite fabrication shop to get you some dishwasher mounting clips. They look like a perforated disc of metal with a small nut brazed to one side. They come with a short screw that attaches through your dishwasher mounting tabs. Place your dishwasher where you want it relative to the cabinets and pick a hole in the mounting tabs that won't leave the clip protruding and attach the clip to the chosen hole. Use masking tape on the top of your dishwasher door, wipe the bottom of the granite and the top of the clip with acetone, then use a gel-type two part epoxy from your local hardware store to attach the clip to the granite. Use enough to make the epoxy push through the perforations in the clip as this is how the epoxy grips the clip. Push the clip to the bottom of the granite and close the dishwasher door, using a wood shim or two between the top of the door and the mounting tab/clip to push the clip tight to the granite. Pull the shims out once the epoxy has cured (check the instructions on the epoxy).
Feel free to contact me with any questions. Brandon Wiese - Brandon@StoneRepairman.com - http://.www.StoneRepairman.com
Posted on Mar 26, 2011
Macmarkus
  • 2605 Answers
SOURCE: I am a 30 year
Hello, Welcome to FixYa. I read your post and having changed a few of those myself and since you asked for "ideas" I do have an idea that comes to mind but first I need to know, are you attempting to snap the stainless steel ring under the filter ? Is that indeed what you are referring to ? In my experience and according to my samsung service manual, that piece must go in before or at the same time as the mesh filter assembly, but it wont go in after...not sure if you knew that so I'll watch for your reply and go from there...if need be. Regards, Macmarkus :) Regards, Macmarkus :)
Posted on May 09, 2011
How do I mount Kenmore dishwasher model 65515779 to granite counter top?
Joanne,
You need a granite/stone counter-top mounting kit. It will be a metal strip that you can attach to your cabinets and allow you to screw some short screws up into that metal strip. I would think that most major home repair dealers would have something like that. Dishwasher Undercounter Mounting Kit W10426979 The Home Depot
May 13, 2015 | Kenmore Dishwashers
DMR78AHS error code HE
Hi, the HE codes refer to temperature errors. The HE codes refer to heater problems. These are all functional errors that require a certified service technician, but disconnecting the circuit breaker in the meantime can prevent the problem from growing worse.
Jun 13, 2011 | Samsung DMR78AHS Builtin Dishwasher
Need to stabilize machine and have granite countertops
Nov 20, 2010 | Siemens 24 in. SL84A305UC Built-in...
Mounting my dishwasher to granite counter tops. Granite Grabbers last about a week before they loosen up
Oct 21, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
Just did a kitchen remodel, kept the Bosch dishwasher model SHU9955UC, contractor having problems will attaching dishwasher to granite. Any suggestions? Thanks!
Sep 24, 2010 | Bosch SHU9955UC Built-in Dishwasher
When shutting the door, it rubs against the side. The other side has plenty of clearance. How do I adjust the door?
If it rubs against the cabinet that its under there should be two clips that are attached to the top of the washer and is screwed to the underneath of the counter top. Take the screws out of clips and counter top and you should be able to move it enogh to fix the probels.
Mar 10, 2010 | Samsung DMR78AHS Builtin Dishwasher
I have granite countertops< so i have to install the clips on the sides of the dishwasher instead of on top. however the dishwasher has no holes with plugs
Jan 07, 2010 | Dishwashers
I'm having my kitchen counter tops replaced with granite. I have a GE Model GSD700 dishwasher that is now attached to the existing counter top. The granite counter tops will not accept having a dishwasher...
• Purchase and install the GPF65 side-mount
bracket kit if the underside of counter is granite
or a similar material that will not accept wood
screws. The GPF65 kit is available from authorized
GE appliance dealers.
Also note that any stainless steel tub models would be able to accomadate granite tops without a kit, and I beleive all Profile GE models come with the kit included.
Sep 27, 2009 | Dishwashers
Need side mount brackets gpf65 because of granite counter top, model #ghda485n10cs ser# rm763786b, quietpower3 dishwasher
Jun 25, 2008 | GE Dishwashers
Dishwashers Logo
71 people viewed this question
Top Dishwashers Experts
