Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
Strong meldew smell from washer
We have a LG washer, one year old and there is strong meldew smell from inside machine. We have used the clean tub cycle frequently. Model WM2016CW front loader. Any way to get rid of the smell?
  • 4 more comments
  • Anonymous Jul 15, 2008
    my front load washer has a strong mildew smell. I noticed mold on the inside of the seal that is around the drum. It looks like water stays in the seal and forms a small puddle at the lowest point on the seal.
    Other than wiping out the seal each time I use the machine, what can I do?? any ideas??
  • Anonymous Jul 26, 2008
    We had the same problem in 2003 thru 2005 - Lg changed seal twice, we ripped out and changed plumbing. LG repalced machine with newer model which has no smell. You must leave door open to ventilate all the time. Too Bad if a hallway.
    However main drive has failed once, and now leaking water everywhere. May not fix. Anyone need parts? Good Luck
  • cimgold Aug 19, 2008
    strong mildew smell from washer.
    making all the cloths stink!
    please help
  • etbugs Nov 27, 2008
    We've had the washer for two years. Unless you wash continuously, you must let the inside air out by leaving the door open-over night usually works. And don't leave damp clothes in it overnight either. Also, regularly run the clean the tub cycle with bleach. There obviously is no real fix, so you'll just have to deal with the problem. As far as other issues go. It has never seemed to handle large loads very well. And just as of yesterday, it leaked water everywhere. We have no idea why. But we get the "famous" lE message...which I understand means call for service. And apparently it could me that the "main drive" failed! Just fabulous! If you are shopping for one like this...don't.
  • raaascal Feb 08, 2009
    clothes especially towels never smell clean,and dirt becomes trapped  between rubber boot and  drum
  • Anonymous Mar 27, 2014
    the washer has was smoking inside the drum and smells of burning rubber but no belt is on this machine.
    at first the machine wouldn't drain so I cleand drain and filter and then it drained but it smoked inside the drum and smells of burning rubber
Clean out the drain filter. mine had one of my kids socks stuck in it. Any small item could get clogged, it is best to use a laundry bag for those items.
Posted on Jul 13, 2008
  • 5,911 Answers
Please take a look at the following link and see if you are following all the steps. Front Loaders are notorious for smelling this way , but there are things you can do to minimize the problem. I have owned a front loader for 8 years now and have never had a problem by following this advice.
http://www.fixya.com/support/r513372-front_loader_mildew_odor
Posted on May 16, 2008
  • Jeff Rockwell
    Jeff Rockwell May 16, 2008
    PS If the link does not work, please copy and paste to your web browser window. Let me know if you have any problems.
This is more of a suggestion that a known solution. We have not had this problem, but in the process of trying to get our washer to drain today (we have an LG WM 2016CW) we blew into the drain hose and a horrendous smell came out. We had the filter out to clean it and a gush of water came out so be prepared. If the smell we got from the drain hose got into the machine our close would be pretty nasty. I can't promise this will fix your problem but your filter may need cleaning anyway.
Posted on Feb 08, 2009
8 YEAR OLD LG FRONT LOAD WASHER WONT SPIN OR DRAIN
If the washer won't spin the stator or rotor assemblies at the back of the washer tub might be bad or damaged. The rotor is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the rotor fails or is damaged the washer might not spin or agitate. Check the rotor for damaged magnets or other defects
Aug 29, 2014 | LG WM1814CW Front Load Washer
My LG front loading washer smells like wet clothes that have been in the washer for months? Musty smell?washer overnight? Strong smell of musty old clothes
This is caused by the biomass built up inside the tub of the machine. This can also be caused by a moldy door boot. You need to scrub your door boot between the tub and the door. Water settles in the bottom of it and molds. Once you clean this, order affresh washer cleaner for your machine. This kills all the biomass built up in the tub and removes the smell. You will put all three tablets in the drum and run on the longest hottest wash available. When this is completed your machine should smell much better. To keep this from getting so bad again... Keep the washer door cracked open between cycles. This keeps the inside from smelling. Hope this helps
Apr 04, 2012 | LG WM-2277HW Front Load Washer
I have the smeel of old grass coming from my washer, probably from my yard work jeans. How can I get rid of this smell? Is there a filter I can change?
All you can do is clean the rubber door boot inside and out and in all the folds with a strong bleach solution and then run an empty load with a a few cups of bleach in it, then always leave the door open after your finished the laundry, there is probably mold and mildew inside the tub between the spin basket and tub and you cant get to it. various products for mold and mildew may help
Aug 25, 2011 | Whirlpool WFW9050X Washer
Kenmore Dishwasher 665.1383 is about 4 years old. The past 2 months it has developed a strong plastic or chemical smell. The smell has tainted brand new glasses that then have the odor when they are...
that's not the full model number,there should be four more numbers.anyway does it have a heating element in the bottom of the tub,if so feel it with your hands,a piece of plastic could of hit it and is still melting when you run it,you can try using dishwasher magic,it's a bottle that you stick in the washer,the heat opens the bottle and it cleans the machine,also what kind of soap are you using?maybe try a new brand.also make sure the heater is in the metal holders,i've seen it knocked out and it will burn a hole through the tub.
Apr 09, 2011 | Dishwashers
Has meldew ordor
Front loaders are known for building up mold and the smell.
It's caused by using liquid detergent which is made from animal fat. Use powder. And use the minimum amount.
It's caused by using fabric softener. Dilute it 50/50 with water.
It's caused by the water remaining in the tub between washes. Leave the door open to allow it to dry. .
Pull the rubber door seal back and clean the mold off .
Affresh is recommended by some manufacturers. You run it through a wash cycle with it.
Dec 29, 2010 | LG WM-2277HW Front Load Washer
My clothes stink so bad from my front end LG washer! My co-worker on my first week of work started buying bath and body sprays and body wash leaving it on my desk. I'm so pissed off because my washer was...
My LG stunk too. I did the tub washing with 1 cup bleach and wiping the rim, leaving everything open, nothing worked. I added 2 cups of a 6% bleach and used the tub cleaning cycle, rinsed with an empty hot water cycle then added bleach-able clothes to the 2nd hot water rinse (the third cycle/step). It gets a very strong bleach smell so don't take a whiff if you open the door in the first 2 cycles! After I did the strong bleach cycle, I am able to treat with just the 1 cup bleach about every 3 or 4 weeks and I make sure to wash with a hot water wash every week and a half at the least. This seems to keep my clothes smelling fresh like they should. Before I bought the LG, I read where people turned up the amount of water the washer takes in but I can't find the link that said how to do that. I think it was 1/4 turn on a screw on the top of the machine (when you take the cover off) but I can't guarantee how to do that.
Jun 26, 2010 | LG WM-2277HW Front Load Washer
There is a strong oil smell in the dryer
If you have recently painted or varnished inside your home the fumes in the air can create a hydrocarbon type smell in your dryer. This should stop as soon as the house is aired out.
Oct 17, 2009 | Whirlpool LTE6234D Top Load Stacked...
Our front-loading HE washing machine delivers
try putting in 2 caps of a citrus or pine bleech straight in to the drum with some old rags. then select a boil wash. the rags will spray the water around the tub, the bleech will clean the tub and make it smell fresh. DON'T put any clothing in whilst doing this. if you are worried about bleech in the machine just select a rinse cycle after. i do this once every 3 months
Aug 05, 2009 | Maytag MAH2400A Front Load Washer
I have exactly the same problem!
Try using the tub clean cycle and use a good dose of bleach or vinegear. Here is how to run the tub clean cycle.
To start the TUB CLEAN cycle:
1. Remove any clothing or items from the washer and close the door.
2. Open the dispenser drawer and add liquid chlorine bleach to the bleach compartment.
NOTE: Do not add any detergent to the detergent compartments. Excessive suds may be produced and leak
from the washer.
3. Close the dispenser drawer slowly.
4. Power On and then press the Extra Rinse button for 3 seconds. (Prewash option will be selected.)
5. Press the Start/Pause button to start.
6. After the cycle is complete, leave the door open to dry around the washer door opening, door seal and
door glass.
Jul 11, 2009 | LG WM2688HWM TROMM SteamWasher
Clothes not fresh as with a topload washer
Call a servicing dealer and see if there is an update for your machine that has an extra circulation hose and port
Jul 04, 2009 | LG WM-2277HW Front Load Washer
Washing Machines Logo
499 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
