Hi our boiler has a bentone burner runs fine when it reachs the thermo setting cuts off as normal but when it comes on again it just fires and cuts off and locks out if you release the bleeding screw it gets away again. If i get to the switch before it finishes first cycle and then switch off manually, i can switch on again at any time and its fine. Our plumber has changed pump and did everything to release air but unable to solve. Please help. Thanking you Sean
  • 455 Answers
Hello Sean, You need to install a RETURN line to the tank making the pump self-priming or if that can't be done install a TIGER-LOOP on the pump to reslove the priming/air problem.
Posted on Sep 15, 2010
I have a riello burner 40 it will fire and come to temp but wont refire, goes into lockout
My first guess would be that it sounds like a clogged oil filter, air in your fuel line, is piping overhead, or leak in a fitting or connection causing it to loose it's prime when running.
I have also seen primary controls that are faulty do this, watching the complete cycle of the run time will give you more clues as to when the control actually locks out. Does it lock out during the run cycle as the boiler reaches temp.? If so,check for oil line and suction issues as stated above.
If it locks out on start up after reaching boiler set temperature, if hitting reset right away burner doesn't start and lock out occurs with no motor engaging, check motor (Note: Some motors when HOT will not kick in when powered, but after they cool down naturally they start, motor shaft may also be bound up tight, replacement is necessary) if burner motor spins but does not fire, check for fuel flow to the nozzle, be sure oil is pumping to the nozzle, if it is, clean cad cell eye, and check transformer for spark, if all is good.. replace primary control.
Disclaimer:
Of course all this information is technical troubleshooting information and should be performed by a Licensed Technician, not knowing how to properly test for flame failure can cause injury, fire or worse! Consult a technician in your area if you are not proficient at oil burner repair!
Nov 21, 2014 | Honeywell Biasi B10-3 Boiler ,riello...
Tip
Cruise Control for Your Oil Burner to Save Money
The Beckett HeatManger is a microprocessor controlled device that will manage the on/off cycles of your boiler. Every time your boiler has to shut down and then restart your have just lost a bit of efficiency. By reducing the start/stop cycles of your boiler you not only reduce fuel consumption, but you also reduce wear on the parts of the boiler and emissions coming from your boiler. Your burner burns very inefficiently on startup and shut down. When I have my combustion analyzer on a burner it goes crazy with bad gasses right after shutdown.
If you have a fuel oil or gas fired boiler and you are wondering how you can save money on your heating bill without replacing your boiler then I have good news for you! By adding a simple device to the burner of your boiler you can be saving at least 10% in minutes
With this control if your thermostat requests heat and the HeatManager has sensed that there is heat available in the boiler, it will not start the burner until the heat is used up. When the burner is running, the HeatManger will optimize the runtime to match the boiler output to the load.
The unit is very easy to install. It is mounted to the junction box under the relay and wired into the normal burner relay wiring. There are a couple of sensors that need to be attached. One senses the supply water temperature for heating, coming out of the boiler and the other senses domestic hot water boiler supply temperature.
Even if you would decide to get a professional to install this unit you will be on the road to saving big dollars while only spending few hundred bucks. Then when the price of fuel oil and natural gas begins to rise again, which it will this winter, you will be getting even more savings from your small investment.
Saving money is always a good thing, but when you can combine saving money with greater comfort than I would call that a great thing!
on Dec 17, 2009 | Heating & Cooling
Johnson and starley j32 pilot light on but burner not lighting
Check you have power going to the gas valve .
Feb 10, 2013 | Heating & Cooling
Ariston euro-combi boiler not giving hot water
odd noise like popping or singeing fire....clicking noises.....sounds like you have a water leak putting out the pilot.......or your thermo coupling is bad....or the noise is the tank full of calcium buildup and that will make noises when the burner is on
Jan 19, 2013 | Water Heaters
I have a thermo king tripac and I'm having issues
Hi there, do you have the diesel fired heater unit? have you checked the inline filter and also the injector nozzle inside the burner, we had one come in that was slightly blocked and wouldn't fire up! i have a brand new complete heater unit if you need any parts.
Dec 03, 2012 | Cars & Trucks
We needed to turn the water off at the stopcock to repair a tap and for safety we turned the boiler from all day to off. when we turned the water on again the boiler was off completely. what do we need to...
Hi the temperature control on the boiler should start the boiler as soon as you restore power to it. I don't know if you have a automatic ignition module or a standing pilot. If it is a standing pilot, make sure it is lite.You should have a temperature gauge telling you the water temp., and if it was off all day I am sure it is very cool. Do you have a drain valve on the front bottom of this boiler? If so, and you have a floor drain, turn it on as you may have gotten air in the system causing it not to fire up. If not, open all outside hose bibs/faucets and indoor faucets and let them run for awhile. If the water was drained out from the boiler to repair this tap, its off on its low pressure shut off switch. This is a safety. After bleeding any dirt or air from the system, make sure that you hear the boiler filling up with water. Once it reaches its low pressure cut off, it will fire up and start to heat the water. I don't know how large it is, but it may take some time to reach its cut out switch before it will fire again. Please keep me posted in the comment box. Please rate me on my help to you, and I thank you for this.
Sincerely, Shastalaker7
A/C, & Heating Contractor
Feb 20, 2011 | Heating & Cooling
My furnace will not keep running. After approx 10 minutes of normal burning, the burners flame out and then re-ignite over and over again (about 1 second on/ 1 second off) and the gas valve can be heard...
hi
have you checked the pump? if the pump has failed you will be super heating the water around the boiler causing it to lock out.
could be a fault on circuit board or faulty thermo stat.
hope this helps
Dec 19, 2010 | Heating & Cooling
Problem with hot water from Vokera Excell 80sp boiler
Hi - hope someone can help. I have a VOKERA EXCEL 80SP combi boiler and been without hot water/central heating for two days. The pilot light is on, the fan is on, but boiler not triggering once the hot water tap is turned on.
Hopefully someone come to look at it today but hoping for some advice. Anyone else had this problem?
Thank you.
Dec 21, 2009 | Water Heaters
I'm a plumber and was looking at a friend's Ariston Microgenus 28 kW combi boiler today. The problem is the DHW comes out tepid, then within a few seconds of the burner igniting, the temp indicator lights...
Many boilers seem to use a more or less common type of thermister although actual fixings vary. My experience of one of these from another brand of boiler was 670 ohms at 10 deg C and 10 -11 k ohms at 20 deg C
Dec 10, 2009 | Combi Centre DX - Mango
Riello oil burner
i have a reillo oil burner that fires up from cold no problem reaches the set temp and cuts out, when it tries to kick back in it keeps clicking the lockout light is not coming on and the fan is still running any ideas?
Oct 08, 2008 | SySTOR Systems (400S52) Burner
Heating & Cooling Logo
212 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
