Question about Intimus 502 Shredder
The cardboard hopper inside the shredder is falling to bits and will soon be beyond patching up. Any idea where I can get a new one, or better still a aplastic one which won't fall to bits so quickly?
  • 3,594 Answers
Contact Martin Yale @800-225-5644.
DickyO
Posted on Sep 15, 2010
How can I operate the equipment safely?
Just a few I can think of off the top of my head .
Do not over feed shredder - too thick = bad
avoid paper clips and staples going in
Avoid neck ties scarfs near shreder when other end around a neck
Avoid loose clothing near device that can fall into device.
Avoid plastic going in shredder
Make sure waste bin is not full before and while using device otherwise can strain motor.
Do not put water in device or wet paper
Do not operate near water or in rain
do not run shreder on wrong voltage and frequency check voltage from power point matches voltage and frequency required by shredder
do not put tree branches in shredder if designed for paper shredder
do not put cardboard in shedder
If paper gets stuck in shredder use reverse button and remove and try again with less paper . Do not forced shredder to drag paper through it.
Jun 02, 2015 | Office Equipment & Supplies
Can I buy a new basket
Fold a piece of cardboard into the slot on the shredder. I had to do this on an office shredder I owned for years.
IMPORTANT: ALWAYS REMEMBER TO REMOVE the piece of cardboard ANYTIME YOU HAVE TO CLEAR THE CUTTERS &&& ALWAYS UNPLUG IT!
Aug 04, 2014 | Fellowes PS60C-2 Shredder
Can not feed paper
First try moving the switch manually to reverse. The machine should start. This may cause some paper to appear in the slot where you place the paper to be shredded. If it doesn't start, your problem may be more serious or complex and you should get in touch with the Staples store where you purchased it.
It may be that the paper you are trying to use is too lightweight. Try inserting a piece of cardboard (SLOWLY SO AS NOT TO LET THE BLADES CATCH THE CARDBOARD - LETTING IT CATCH THE CARDBOARD MAY BE BEYOND THE UNIT'S CAPACITY). If this starts the shredder, quickly remove the cardboard. If it continues to run (cycle), you may have had some paper blocking it.
Hopefully this has done the trick and everything now works. If not, talk to the Staples store where you bought it.
Jan 08, 2014 | Staples Cross-Cut Shredder
Jam with a cardboard from check book
On most Fellowes ideal unjamming would be by trying the reverse, if that fails there's 2 options: 1 - opening the unit by removing screws (usually 5) and using small narrow flat screwdriver carefully clearing out all the stuck paper/cardboard from in between two rollers, but be carefull and make sure the power cord is NOT plugged into wall socket. 2 - without dissassembling the unit spray some WD-40 into the shredders feed opening and let that cardboard soak for a while. WD-40 will soak into cardboard and any stuck paper and will loosen it, you might need to spray couple of times allowing to soak in between sprays, but this definitely does the trick. Once sprayed 2-3 times allowing to soak for at least 10 minutes between sprays simply swich the shredder on and use reverse and all stuck paper should come out. Be advised after unit was cleared you must use some spray oil to protect the blades. Once oiled allow unit to run in reverse for at least 2 minutes, the swich it off. 15-20 minutes later your shredder will be good as new!! Hope this helps ;)
Oct 27, 2013 | Fellowes (R) OD1500C High-Performance...
How can I clear a paper jam on a hsm securio b32 shredder when the reverse function does not clear it
On most shredders ideal unjamming would be by trying the reverse, if that fails there's 2 options: 1 - opening the unit by removing screws (usually 5) and using small narrow flat screwdriver carefully clearing out all the stuck paper/cardboard from in between two rollers, but be carefull and make sure the power cord is NOT plugged into wall socket. 2 - without dissassembling the unit spray some WD-40 into the shredders feed opening and let that cardboard soak for a while. WD-40 will soak into cardboard and any stuck paper and will loosen it, you might need to spray couple of times allowing to soak in between sprays, but this definitely does the trick. Once sprayed 2-3 times allowing to soak for at least 10 minutes between sprays simply swich the shredder on and use reverse and all stuck paper should come out. Be advised after unit was cleared you must use some spray oil to protect the blades. Once oiled allow unit to run in reverse for at least 2 minutes, the swich it off. 15-20 minutes later your shredder will be good as new!! Hope this helps ;)
Oct 16, 2013 | HSM SECURIO B32 Shredder
How can I clear a paper jam when the reverse function does not work
Oct 16, 2013 | HSM SECURIO B32 39mm shredder
Microwaves
What you are meaning is the waveguide within the cabin which could have been burnt due to food particles that got entangled.
Click this link and also check for spares.: Waveguides
Feb 11, 2013 | Microwave Ovens
The overloa light comes on and the shredder stops immediately. the hopper is empty and there doesn't appear to be anything blocking the shredder. i was shredding for about 1/2 hour when this started. i've...
You have probably "fried" the pcb inside the machine.....this is a "consumer" machine...no more than 5 mins ON then 10 Mins OFF to let it cool down.....you should only shred about 70% of the MAX rating for the machine.
For Parts advice call Royal at 1-800-524-0799.
Feb 13, 2010 | Royal VF1012mx Shredder
Olympia shredder 1280.6
On this model, make sure the hopper is all the way in. If it is, remove paper hopper and check to make sure the hopper is not broken. There is an electromagnetic switch in the front and the hopper has a magnet built in to it. run a stick magnet across the right underside and front to see if it extinguishes the light. If not, then the board is bad.
Jun 12, 2008 | Olympia 1280.6 Shredder
Intimus 502 Shredder Logo
125 people viewed this question
Top Intimus Office Equipment & Supplies Experts
ray gallant
Lonnie Arks
Tom Chichester
Are you an Intimus Office Equipment and Supply Expert? Answer questions, earn points and help others
