Question about Dolphin Computers & Internet
Scanner doesn't work
I have a Dolphin Follett PHD+ scanner. I did not have it set up all year, and when I plugged it in, it didn't work. If the scanner is in the dock, I get a signal and get to the screen where it says "You have a log do you wish to ship it out?" No matter which button I hit nothing happens. When I take it out of the dock, I lose all contact - the screen is dead. I bought a new battery, charged it all night, and I still have the same issue this morning. I have tried rebooting it. It does sometimes say configsys driver could not be loaded. Do I need to reload the setup software on my CPU? I am using a different one than I used in the past. Or is that a totally different problem?
Sccaner open through screew driver & properly wash Logic board with ethiel alkohal. Plz properly check connection streep wire so connected with the warming lamp to logic board.
Posted on May 25, 2008
Follett dolphin phd
So, I had a large scan.log file which I would have lost if I followed the instructions above. Instead hold the shift, on scan and bksp buttons simultaneously. The device will reboot with your file still functional!
Aug 27, 2013 | Computers & Internet
My 3820 will no longer scan Follett barcodes. It makes several error beeps every time I try to scan anything
srodgers609
One of the problems I had with my scanner is that the USB port that I had the scanner in when bad. My scanner cable was a little short and it put extra pressure on the port. After time some of the connections in the port broke. To fix the problem I had to replace the USB card in the system.
So I would recommend that you tryu the scanner on another computer and/or another USB controller to see if it works properly. If it does you know that it is the USB port. If it does not then I would look at the cable of the scanner.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Aug 25, 2011 | Honeywell 3820 Wireless Handheld Barcode...
Dolphin 7200 Scanner won't power on
try holding down 7 and 9 then power on + shft + bksp
simultaneously then release 7 + 9 first. Let me know how you get on.
Jun 25, 2009 | HHP Dolphin 7200
Laser not working, screen won't show, beeps continuously.
i think i can help u with this, if u unscrew the unit and carefully unhook ur the cables in side then will see two Philips screws, unscrew them and unhook the display cable its on the side
now gently try to take the board out and put it back on then hook the display cable back and screw the board back and for the scanning
unhook and re hook ur scan cable that will make it work,i hope that will solve ur problem
Jun 11, 2009 | HHP Dolphin 9550 Barcode Scanner
The laser is not working on my Follett PHD- Dolphin scanner
You need to do a system hardware reset. Do this by remove battery and find small pin hole just below the battery terminal single pin side. It may be covered over by black sticky pad. Get paper clip wire and put through hole to you feel small click. Hold down for 10 sec and then put battery back in to see the unit run a rebooting procress.
Hope this fix it
Jun 09, 2009 | Computers & Internet
Laser will not work on PHD+ dolphin
Depending on the operating system, the scanner driver may not be there. If your device is Win CE, there is no scanner driver in the O/S. If it is WinMobile, there is. You may have to have your dealer sell you a utility like DataWedge or ScanWedge - there are others as well. Contact your dealer or the Honeywell Help Desk.
May 15, 2009 | Computers & Internet
TK-1000
Here at Legacy Global we can help you. Call Diana at 1-847-750-9231.
Aug 27, 2008 | Computers & Internet
Computers & Internet Logo
1,000 people viewed this question
Top Dolphin Computers & Internet Experts
matt
matt
Southpaw Jim
Lee Parker
Lee Parker
Are you a Dolphin Computer and Internet Expert? Answer questions, earn points and help others
