Question about Sony Playstation 3 (PS3) Console
When the ps3 is turned on the fan starts making a really loud noise, and then the system says it is overheating and turns itself off
    Novelist:
  • 151 Answers
Hello rtargo21
There are several factors that can contribute to this problem.
Firstly, let the system completely cool down. Turn off the power, and move the unit into an open area and try turning it on again to see if the problem persists. If so, leave it off for at least 30 minutes then try again.
I would also recommend vacuuming the air vents. DO NOT use compressed air as this can cause further damage.
Where your system is positioned can also make a big difference. - Make sure the system is at least 4 inches away from any walls. - Don´t leave it on a rug or carpet. - Try to give it as much open space as possible so that the fan can dissapate the heat efficiently.
If after trying all the above steps, the problem still persists, you may have to consider sending it in for servicing. If it´s still under warranty, take it back to the place you purchased it from. Otherwise, go to the official Playstation website to receive instructions on how to do this in your country.
Hope this helps. If you require any further help, feel free to contact me. Good luck!
ajblaj
Posted on Sep 15, 2010
PS3 fan keeps making noise
If it's an older system, break that thing open and clean it! ^^ If it a newer system, or you just don't feel like stripping it to clean it, then use an air compressor to blow the crud built up in the back of the system. Make sure the compressor hose is dry, as you don't want water to get inside your system. Good luck, and I hope this helps.
Jan 21, 2014 | Sony Playstation 3 (PS3) Console
I have a Dell Inspiron 1521. 6 months ago the fan makes a really loud noise when the laptop has been running for a while. It went in June to be looked at because my computer messed up and they had to redo...
Yes, the fan can be definitely be replaced. You can actually get a replacement fan for your computer at The Laptop Fan Shop online for about $22. The process of changing a fan is quite simple, so you should be able to do it yourself to save on labor. Although, if your computer is still under warranty you should contact dell directly at 1-877-694-3591 to see if they can replace it for you for free.
Sep 16, 2011 | Dell Inspiron 1521 Notebook
Fan makes really loud noise and then computer shuts down by itself i have an acer aspire4530
sounds like the machine is overheating, remove the case and clean out the fan and surrounding area.
May 02, 2011 | Acer Aspire One PC Notebook
I have a PS3 and it just started to make a really loud groaning noise when I first turn it on. It will only do it for about a minute and then it stops and runs fine. Why is it doing that?
Most computers and electronics are programmed to run the fans at full blast when you first turn it on, to clear out dust and purge the air inside. It sounds like one or more of your fans in jammed with dust. Some electronics repair stores will clean console fans for a fee.
I wouldn't say that this issue is a real problem right now, but having damaged fans can do serious damage over time by overheating your console. It's a problem best solved early.
Apr 17, 2011 | Sony Playstation 3 (PS3) Console
PS3 WHEN CONSOLE SWITCHED ON IT BEEPS THEN TURNS OFF AND FLASHES RED
My guess is its going to die soon. I would back up most of your stuff on a hard drive if possible. If it gets that far. I had this happen to my 40GB PS3 about a year ago. It turned on for 5 minutes then off. Soon after that it didn't turn on. And it was making really loud fan noises.
What are the specs of your PS3 and was it making loud fan noises before? Consider buying a new PS3 slim?
A quick guess that i just thought is try doing the fan test before turning it on. Turn Off PS3 completely (switch in back) Hold eject button and Turn on switch.
NOTE: This is dangerous and can harm the PS3.
Good Luck
Nov 29, 2010 | Sony Playstation 3 (PS3) Console
My Ps3 makes a loud fan noise after 15-20 minutes
its your backup fan turning on you must not have adequate venitlation take it out of small place and put it near a fan or window
Oct 22, 2009 | Sony Playstation 3 (PS3) Console
Overheating
Go to any store that sells ps3 stuff and buy a ps3 fan I got one for about 35 dallars makes my ps3 run very good
Jul 12, 2009 | Sony PlayStation® 3 (60 GB) Console
Heater making angry noise!
Your heater fan bearing is shot,,time to replace Fan now before you really need it.
Jan 19, 2009 | 2004 Mazda 3
My laptop turns on and then it turns right off!!! HELP!
hi there
It seems your laptop computer is not cooled properly which might be beacuse of a broken cpu fan as you mentioned it makes loud noise.
The reason your laptop turns off by itself is because theres a circuitry built on the motherboard which power offs itself if the internal temperature raises, this is a safety feature to prevent your computer getting burnt.
Please avoid using your computer and take it to a shop where you can have it checked for cooling.
hope this answers your question
May 30, 2008 | HP Pavilion dv1000 Notebook
Big Screen gets loud, mad and turns off
without a model number, i can't be much help. if this is a newer dlp or similar tv, the fan is probably going out. some newer tv's have a fan that is part of the light assembly, some have a separate fan.. the loud whirring noise is usually caused by bad bearings or the blades of the fan may have become unbalanced, either way, the fan making the noise will need replacing. the color going is usually caused by the lcd or dlp overheating and/or the lamp overheating.
if the tv is out of warranty, remove the back panel, locate the fan making the noise, and search for a replacement. if you have a model number, i can check around and see if i can find the part number for you.
hope this helps,
trin
Nov 19, 2007 | Televison & Video
Sony Playstation 3 (PS3) Console Logo
156 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
