Question about Roper REX4634KQ Electric Dryer
Roper Super Capacity natural gas dryer works but doesn't heat up
  • 4,323 Answers
Hi
If your dryer is not heating, then check if the power cord is plugged into the wall. It may be loose or disconnected. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working. Now, check whether the heating element in your gas dryer is burned out by using an ohm meter to check for continuity. If the continuity is not there then you would need to replace the element. After checking the element, check out the thermal fuse to see if it's burned out. The thermal fuse is attached to the exhaust duct on the back panel of the gas dryer. It's usually surrounded by a black resin material situated in a housing made of white plastic. If the fuse looks like it's blown, then it needs to be replaced.
Now, check the igniter, there is a plastic connector attaching the igniter to the burner. Disconnect this and place the probes onto the two contacts of the igniter. The meter should read under 100 Ohms of resistance. If the reading is above 100 ohms then igniter is bad. If the igniter passes the test then you need to test continuity on the flame sensor. You should have continuity between the two contacts. If not, then you need to replace the flame sensor. The sensors are usually located close by the igniter so are easily visible. Hope this helps...
Daniel
Posted on Sep 15, 2010
Roper heavy duty super capacity 8 cycle fabric softener mess
check to see when and where you are to add the softener read the manual for tips look in the trouble shooting guide
Jul 06, 2012 | Roper RAS8445KQ Top Load Washer
Dryer heats OK when turned on but the timer never moves and the dryer doesn't turn itself off......
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101,./,./'
Jul 13, 2011 | Maytag Centennial 7.0 Cu. Ft. Super...
DRYER WON'T HEAT
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 10, 2011 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Dryer will not heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 12, 2010 | Maytag Centennial 7.0 Cu. Ft. Super...
My dryer is about 7 years old...it runs but no heat isnt spewing out....and it only works on the "timed" settings......Its a Roper super capacity.....model number RGX5634KQ2....serial...
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 23, 2010 | Whirlpool Dryers
Gas but have only electric hookup
Sorry, but there is no conversion from gas to electric. (only natural gas to LP gas or back again) You will have to get an electric dryer or have a gas line run to the dryer.
May 25, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer timer is not working and won't heat but runs fine
check the ignitor. That's a very common cause for no heat in a gas dryer. other possibilities are the coils, or it could be that you have a bad fuse in the dryer.
Dec 26, 2008 | Kenmore 73952 Gas Dryer
Roper REX4634KQ Electric Dryer Logo
178 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
