Question about Gigabyte GA-8I845GVM-RZ Motherboard
Iin my system i amnot getting the display . i have removed everything cleaned but then also i am getting it.
  • Gigabyte Master
  • 27,725 Answers
Replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
good luck
Posted on Sep 15, 2010
The LCD display screen is cloudy on one side so difficult to read part of display. Is there a way we can remove it and clean the glass?
I don't have your model number to look up but I'll try to answer. Most digital displays have 2 parts to the display cover. The actual display and sometimes a clear or green plastic cover to help protect the actual display. That type system can usually be removed and cleaned. Some of the newer systems have eliminated the extra cover, so if moisture is getting behind the display you can't clean it. If it is actually moisture, applying heat from a hair dryer may help get rid of some of it but be careful you don't get it too hot and melt the display.
May 13, 2015 | Electrolux WaveTouch Perfect Steam 8.0 cu....
Where is the obd1 fuse located on a 95 bmw 318i
The fuse box with spare fuses, fuse removal tool and relays are located on the left wheel arch inside the engine compartment.
23 - 5 Amp Unloader Relay (K9), Rear Defogger Relay, Combination Switch, Climate Control System, Clock, Instrument Cluster, On-Board Computer
31 - 5 Amp Climate Control System, On-Board Computer, Instrument Cluster, Clock, Chime Module, On-Board Display
45 - 7.5 Amp Wiper Relay, Wiper Motor Relay, Clock, On-Board Computer, On-Board Display Check Control Module
iIn the glove box
on-board computer 23 45 (10-93 to 09-95)
on-board computer 23 45 (10-95 to 09-96)
on-board computer module, center console
Sep 09, 2014 | Cars & Trucks
Washed bsking dishes in dishwasher j had hotshot iin disher when i did wash of fishes we baked snd ate off dshes can we get sick?
If you are in any doubt about the ability to properly clean your dishes etc, then get an engineer to check it out.
You could always wash the dishes yourself?
Jul 21, 2014 | Dishwashers
No display
first check wether ur monitor light is blinking if not there is problem with ur display or the power is not correct if all this is ok and ur monitor light is blinking remove the cpu cover remove the memory and restart ur computer in new motherboards muzzers are fitted on the motherboard or else connect a buzzer to the speaker pin iin the frontpannel and restart the computer with no memory you will hear 2 long beeps it means the memory is not present then clean the memory pins eith an erasor dont use any metalto clean the memory insert the memory in the nemory slot if you hear again the long 2 beeps it means the memory is fried if you hear one beep means the memory is fine and the system is working still no display means then check if the display card is addon or motherboard built in if addon change the addon card if built in contact chiplevel service person also check the ponit cable connected firmly to the computer with 2 screws on the cable tightened to the cpu
Oct 14, 2010 | Dell OptiPlex 360 Desktop Computer
My syastem was working properly since five month don"t no suddenly what happned after swiching on the computer its showing like DISK BOOT IS FAILURE, INSERT SYSYEM DISK AND THEN PRESS ENTER ....... i amnot...
this means, there is no bootable disk detected. Make sure there is no floppy drive inserted to the system and remove external storage devices, then try to remove and reconnect the hard disk. Make sure your boot method is set to use the hard disk with your OS installed. If this does not work, you may have to reinstall your operating system. If this fails, it may indicate a failed hard disk and you may have to get in touch with your vendor for warranty replacements if needed. hope this helps.
Aug 29, 2010 | Computers & Internet
Ice build-up at the bottom of Glaiator freezer.
Normally, ice buildup in the bottom of a freezer is caused by one or more things. Lack of air circulation, either from a malfunctioning fan or the freezer being overloaded to the extent that either the fan or return ducts are blocked, spillage of ice cube trays, putting warm items into the freezer, thereby causing extra condensation or a bad door seal. If you can't feel resistance when you put a dolar bill iin the door, shut it and lightly pull straight out on the dollar bill, the door seal needs replaced. Mouse damage in the rear of the unit, where the cooling tubes enter the freezer eillbe a pain in the ****, until you get it sealed back up. A little room air, leaking in all the time, is actually a lot of moisture.
Remove everything and put it into something to keep it frozen. Do a FULL defrost and cleaning. Check your seals. It would be best, to remove the back inside panel and make sure the cooling fins are completely ice free and dry before you turn the unit back on.
Dec 20, 2009 | Gladiator Freezerator Top Freezer...
Acer aspire 5050
i assume your dvd is working ok.
to burn, acer give you application (NTI cd-dvd) to burn cd/dvd, i amnot sure the complete name, but for sure is NTI...
You should have this software when you reload/cpr the operating system.
Mar 23, 2008 | Acer Aspire 5500 5570-2609 Laptop
Gigabyte GA-8I845GVM-RZ Motherboard Logo
23 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
