Question about Bosch Dishwashers
I have a bosch classixx slimline dishwasher when I use the quick wash the tablet doesn't dissolve. Is ther any solution to this problem
  • 901 Answers
Check your inlet water flow to the machine. Clean the filter at the machine end near the flexible hose connection!
Posted on Sep 15, 2010
Bosch Classixx dishwasher around 5 years old. Started clicking regulary during cycles. Not much different although tablets weren't dissolving entirely. Now its clicking from back bottom left of the...
The Bosch may have a similar setup to the Meile where the main wash motor has a diverter which controls the water flow to the upper , then the centre, then the lower arms in sequence. When this sticks, the little drive motor "clicks" as it is trying to turn the diverter but cant. It will eventually fail. You may have to pull the motor out to check.
Feb 28, 2015 | Bosch Dishwashers
Bosch classixx dishwasher not heating water on cooler wash works on hot wash
Most dishwashers don't heat the water. They run on whatever temperature water you have it set for. They have heating coils on the bottom but that's for drying, not heating up the wash water.
Nov 30, 2014 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Tablet not desolving after quick wash cycle
Find out whether your quick cycle is a wash cycle or a rinse only. If it is a wash it's obviously too short, and the tablet is not dissolving. You do not want undissolved tablets because they will contaminate your rinse water and u end up with soap on the dishes. You can switch to powder if a tablet isn't going to dissolve quick enough on your quick cycle.
Jun 03, 2011 | Bosch Dishwashers
Bosch dishwasher cotinually runs and does not get very hot
The heater relay has failed in the control unit,easy repar quite expensive part
Jun 03, 2009 | Audiovox Bosch 718 World Cellular Phone
Bosch Slimline Classixx,water cutting on/off during filling on any program, have changed inlet valve already, made no difference
Does it still have enough water to wash? Mine does this too. The float is very sensitive. If it gets the dishes clean don't worry about it.
Jun 30, 2008 | Bosch Dishwashers
Bosch Exxcel Auto Option/Detergent tablet does not dissolve?
It seem that your DW drain it's water by syphon action. Check if the drain hose is properly installed as a U shape; otherwise the DW can drain itself at any time, leaving the soap undissolved .
Nov 16, 2007 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Goes through washing cycle but doesn't dissolve the tablets or cleans the clothes.
Clean out your outlet filter; this is to be done regularly once a month, depending on your usage. Re your tablets not disolving, try using front loading washing powder. Also refer to your manual..........
Jun 10, 2007 | Bosch Classixx WFL 2066 Front Load Washer
Bosch classixx slimline dishwasher not running through cycle
fault is that there is a leak. the tray at base of dishwasher is full of water which operates a float and turns on drain pump. tilt over 45deg and water will run out and then it will work or remove bottom front panel and mop out (better). then find leak
Mar 17, 2007 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Dishwashers Logo
263 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
