Question about ViewSonic PJ458D Multimedia Projector
My Viewsonic PJ458D lamp not coming on
The power comes on fine but when I push to turn on lamp it starts making this clicking sound and then the lamp LED indicator starts flashing Amber (manual says this indicates that the "Temperature is too high. The lamp will turn off.") Anybody have any suggestions?
  • 2Busy May 27, 2008
    Ultimately I got a hold of customer support (not as easy as you might think) and they said I had a defective fan which would not allow the lamp to come on. I sent it in and hopefully it will come back fixed.
  • alvaroplada Jul 29, 2008
    Exact problem
I have the same problem before. I found a replacement fan. A computer chassis fan works perfect. It should be 60mmx60mm - plenty in E-bay for about $5.00. Very easy to open the unit to replace the fan. It has 2 fans in a rubber housing. Check which one need replacement.
Posted on Dec 22, 2009
  • 115 Answers
1.Pls Open the Lamp unit and check the proper condition.
2. Check the fans are working for the cooling of system.
3. Clean the filters of the projectors.
Viren
Posted on May 25, 2008
Why my projector is only coming on for 15 seconds and then coming off
there are some hardware problem your device going off due to protection open device( if warranty expir)e clean it proper and try
May 31, 2012 | ViewSonic PJ458D Multimedia Projector
Lamp will not turn on. I have (2) PJ458D DLP projectors. I took the lamp out of the projector that is not working and placed it in the other projector and everything worked fine. When I press the on off...
It sounds like an internal problem. How long have you owned the projector? How long have you been experiencing this issue? Once I have more information I can assist you further.
Thanks,
Lee
Sep 23, 2008 | ViewSonic PJ458D DLP Projector Multimedia...
Dear Sir, I have a NEC LT 260 K Lcd projector. The lamp of the lcd was busted.I replaced it with a new lamp. After replacing the lamp the lamp is not lighting when projector is put ON, I think the...
the clicking sound hopefully is the high voltage trying to start the lamp, but for some reason there may be a connection problem between the lamp and the projector power supply.
take the lamp out.
look at the lamp and check that the 2 connecting plugs are ok.
then look inside the projector at the power sockets that connect to the lamp (when it's installed).
check that the pins are not damaged or pushed down too far to prevent the lamp plugs making a proper connection with the power sockets in the unit.
Jul 01, 2011 | NEC LT 260K Multimedia Projector
Power led are flashing, but the lamp don't working
Hi
Please check the lamp & lamp cover .if o.k then suspected item color wheel or , main board or lamp ballst
Sep 02, 2010 | ViewSonic PJ458D DLP Projector Multimedia...
I press the power on and the lamp led not the
Hello :
Try to change the bulb .
Here is how :
1:Make sure that your power switch is off and that the power cord is unplugged from the electrical socket.
It is also wise to unplug any other cables and label them in order to restore them in the right way once the lamp is replaced.
2:In order to see the lamp, remove the access handle on the outside cover. You may need to use a screwdriver.
3:Pull out the used lamp and clean the relevant parts using micro fiber products and not paper.
Please note that in some projectors a small inside filter should also be replaced.
4:Insert the new lamp into the projector carefully avoiding touching the glass of the lamp itself.
Touching the lamp will deposit skin oil that will likely damage any new lamp during use.
5:Reassemble the access panel, replug the cables and power up the projector.
Things You'll Need:
new projector lamp
screwdriver
micro fiber duster
Warning:
avoid touching the bare projector lamp.
please rate !
Apr 12, 2010 | ViewSonic PJ458D Multimedia Projector
How to reset lamp timer on Pj458D
turn the projector on. open the menu. go to advanced. scroll down to the first option which should be auto source. make sure this option is checked. while on this option press right once, left twice, right 3 times, then left 4 times. another menu will appear. scroll to lamp time and push enter. this will take it back to zero.
Aug 17, 2009 | ViewSonic Office Equipment & Supplies
Will not power on...
Hi there
Simply search on the net for your nearest dealer and contact them
Apr 04, 2008 | ViewSonic PJ458D DLP Projector Multimedia...
Bulb doesn't light
yip, sounds very familiar
steve, does the pj lamp try to fire up.
does it briefly light up then shut off
these are the typ. symptoms of an expired lamp
Feb 26, 2008 | ViewSonic PJ458D DLP Projector Multimedia...
My ViewSonic PJ458D problem
This is known as 'cycling' and is common with mercury-vapor bulbs nearing end-of-life. When the bulb first starts, it glows dimly and grows in brillance. As the light grows, the pressure and temperature of the bulb also grows--increasing power demand. After a short while, the demand exceeds the ballast limit and the bulb extenguishes until the temperature (and pressure) drop again. Then, the cycle starts over. Bottom line: you need a new bulb (or, the correct bulb).
Nov 13, 2007 | ViewSonic PJ458D DLP Projector Multimedia...
ViewSonic PJ458D Multimedia Projector Logo
959 people viewed this question
Top ViewSonic Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
