Question about Bosch 3107DVS Electric Sanders & Polishers
Instruction manual for the Bosch PBS 75A sander
Parts Diagram For Needle Shaft.
send ur exact model and brand name ..will get ur schematic diagram soon
Sep 20, 2008 | New Home L-373 Mechanical Sewing Machine
Tip
Replace drive belt Bosch pbs7a
To replace drive belt on Bosch 7 PBS belt sander remove cover, 3 screws, place new drive belt over splined drive pulley. Feed belt clockwise over paper pully and Utilize welded hexigonal with suitable wrench to turn and 'pop' the belt on.
on Feb 02, 2014 | Bosch Belt Sander Drive Belt For Pbs 7a,...
The micro filter system is not picking up the saw dust. Any tips?
you need to clean the duct, check if there is flow, best done outdoors and with pressure air hose...
remove filter unit, put it to pieces and blow air in reverse, this will clean the filter unit.
blow now air in reverse through the hole towards the belt, will raise heaps of dust but will clean the fan as well as the duct.
if cleaning do not help - remove cover and check the fan, it is possible that bigger particle broke wings or that they just wear off, you need then to replace the wings.
hope this will help you - we do that several times a year with our sanders.... do not forget to vote :-)
Apr 04, 2015 | Bosch 1607000916 Handle For Belt Sanders...
NEED A AUTO REPAIR SHOP TO RESET IT ONLY THERE COMPUTER CAN DO IT OK
Nov 14, 2012 | Bosch Belt Sander Drive Belt For Pbs 7a,...
PBS 7 AE belt won't turn and dust won't collecr
I had the same problem. On mine it was because the drive belt had worn out. This is under the black cover on the side. You have to remove three torx screws to remove the cover.
Jun 05, 2010 | Bosch 1274DVS 3" x 21" Belt Sander
Bosch 3 x 21 Belt Sander
Remove the dust bag and unplug sander for now. Everywhere you see an access hole (fan area, dust port, back of sander blow thru the tool to remove lodged dust that clogged the system, Also look for broken belt pieces in the back of sander. Then while running (remove belt) blow again thru all the ports to try and reomve as much contamination as possible. When finished you can feel to see if air coming from dust bag port, it not you still have a clog that might need more work. If I have clarified your request would you please rate this response accordingly and thank you.
Sep 10, 2009 | Bosch 1274DVS 3" x 21" Belt Sander
Bosch 3107DVAS Random Orbital Sander not working.
You must replace the fan assembly. The part number is
2606610901
Hope this helps
May 04, 2009 | Bosch 3107DVS Electric Sanders & Polishers
My Bosch PSM 80 palm sander on/off switch is very stiff, can it be lubricated? I so what with?
You can try and blowing it out with compressed air but I dont think that I would try any lubrication, however if you decide to I would use WD-40
Dec 16, 2008 | Bosch Power Tools Sanders Orbital Sanders
Bosch 3107DVS Electric Sanders & Polishers Logo
371 people viewed this question
Top Bosch Tools & Hardware - Others Experts
Tom Chichester
Are you a Bosch Tool and Hardware - Other Expert? Answer questions, earn points and help others
