Question about Garden
Looking for Instruction manual for single-cylinder air cooled diesel generator Model No 5GF-LDE (silenced) Elect Start Made in China no other Manufactures Name \\ Fuzhou Haiyi Electromechanical Equipments Co Ltd ??
  • dennis18674 Sep 15, 2010
    Thanks clay58 Will give your suggestions a try
    dennis18674
    Yes thanking you
  • 2,841 Answers
You have a Lutian generator made in Zhejiang, China. Here it is with some information. http://lutian.en.made-in-china.com/product/dqwQkPYcEAVv/China-Diesel-Generator-5GF-LDE-.html Here is a link with more specs and they list it as Yangke. Fuel tank capacity (L) 16
Lube capacity (L) 1.65
Fuel type Diesel 0# (summer), diesel -10# (winter)
Lube brand SAE10W30 (above CC grade)
http://www.trademetro.net/GF-LDE-GF-153435.html
Here is the telephone number of the supplier in China 86-576-82620992 82642888 82645288 Or you can go to this site and contact them. Do not trust this site with any personal information or credit card numbers. http://lutian.en.hisupplier.com/product-188200-Diesel-Engine-Generator.html I was unable to find an owner's manual anywhere but hopefully by contacting one of these sites you can acquire one.
Posted on Sep 15, 2010
I've got a kipper diesel 60hz single cylinder generator that will not shut off in the off position...any suggestions as to why not??
the stop solenoid on the pump is still getting power to stay on , probably from a faulty relay in the system
Jan 11, 2017 | Diesel Electrical Supplies
Missing wire of generator falcon 5GF-LDE from regulator to wich place ,so battery not charging
cant answer that one
5 kva diesel generator ....
needs a volt meter and or electrician to
ask why wire is disconnected
check regulator isnt faulty
and identify the right wire from its regulator to the right connection
Sep 20, 2016 | Cars & Trucks
Generator wont start up unless i spray starter fluid into it
This sounds like a dirty carbureator. Just bad enough that it won't start cold.
Mar 29, 2014 | Electrical Supplies
What is a glow plug
Glow plugs are heating devices to aid starting diesel vehicles.
Purpose:Diesel engines, unlike petrol engines, do not use spark plugs to induce combustion. Instead, they rely solely on compression to raise the temperature of the air to a point where the diesel will combust spontaneously when introduced to the hot high pressure air. The high pressure and spray pattern of the diesel ensures a controlled, complete burn. The piston rises, compressing the air in the cylinder; this causes the air's temperature to rise. By the time the piston reaches the top of its travel path, the temperature in the cylinder is very high. The fuel mist is then sprayed into the cylinder; it instantly combusts, forcing the piston downwards, thus generating power. The pressure required to heat the air to that temperature, however, necessitates the use of a large and very strong engine block. The problem posed is that in cold weather, if the engine has not been running (as is the case when the car is left to sit overnight), that the large engine block becomes very cold; when one then attempts to start the engine, the cold engine block acts as a heat sink, quickly dissipating the heat generated by the pistons compressing air. The engine is then unable to start, because it cannot generate and maintain enough heat for the fuel to ignite. For that reason indirect injected diesel engines are manufactured with glow-plugs in each prechamber, and direct injected diesel engines are manufactured with glow-plugs in each combustion chamber.
Wikipedia
Dec 07, 2011 | Cars & Trucks
I need the maitenance manual for your sdmo 500kva generators
Regular maintenance for generator is necessary that can help prolong the service life of the generator.
Generator Maintenance Tips
Generators
Generator Set Maintenance Tips
Useful Maintenance Tips for Diesel Generator Set
Maybe You Are Interested VOLVO generator Volvo Generator Volvo Generator Set Supplier Manufacturer Factory in China
Aug 30, 2011 | Computers & Internet
Ihave a single cylender 178 china yanmar diesel
these engines have a mechanical injector and when water gets in them the best way to say this has larger particals then the diesel the best way is to remove the injector and the fuel lines and spray a carb cleaner in then this will dissipate the water place the injector in a pan and heat up on a stove not to get to hot this will dry out the injector then when this is done spray wd-40 in where the fuel tube supplies the fuel do not touch the tip or bump or drop striking the tip that goes in the engine you will have to replace it then reinstall all the removed parts keep the line lose at the injector crank the engine till fuel starts flowing do not hole the ling with a finger you can blow a hole and inject fuel in to your blood these pumps build a massive pressure when lines held .
when the fuel flows start to tighten the line what your doing is purging the air out as well as any water. when you get the lines to where their is a dropping of fuel the engine should start to run it will be ruff and smoke with a wrench loosen then tighten line a couple times wile it is running then snug the line the fuel in the injector will push what rest of the air out and it will smooth out . DO NOT USE STARTING FLUID ON THESE ENGINES you can crack the case they cant take the stress. i hope this helps
Jul 11, 2010 | Electrical Supplies
Generator starts but gives no 220 volt electric
This is a frequency issue 50 hertz for Europe, 60 hertz in US. It's speed related. Faster RPM for 60 Hz
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jun 26, 2009 | Coleman Powermate Premium Plus 6250W...
Diesel generator does not working
After using a diesel generator for a long time, some malfunctions may occur that will cause the generator fail to start.
If diesel generators fail to start, you can analyze the causes from fuel system failure, electric starting system failure, insufficient compression pressure in the cylinder and the low ambient temperature and other factors.
1. Air in the fuel system
2. Fuel line obstruction
3. Fuel filter clogging
4. The handle position of fuel injection pump is not correct
5. Battery power shortage
6. Run out of fuel
Learn more reasons from this article.
Why Diesel Generator Fail to Start
Feb 22, 2009 | Taylor Skid Mount Diesel Generator Set 30...
GE Heat/Cool model AJHS10DCBM1
OK I will be looking over the manual. Now that squeal sounds like the squirrel cage fan scraping the housing around it. Those units are so tight fit they can be twisted one way or tightened a little to much they scrape. I love them for there silence win they work right but hate them because my hand are too big to move things around inside them. Stay in touch I will be looking around while
multi-tasking today- I'll be here!
Feb 02, 2009 | GE Zoneline AZ38H12DAD Split System Air...
Diesel manual does not include my watch! DZ7091
c05b449.jpg451a77f.jpg I have a booklet of these watches in 30 pages, in English,Italoano,Deutsch,Francais, and Espagnol. Contact: joe3ssen@wxs.nl
Dec 13, 2008 | Diesel Audio Diesel Watch
Garden Logo
452 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
