Question about Dell 2300MP Multimedia Projector
No power - looks like power supply - Dell 2300MP Multimedia Projector
I had the same problem, tore it apart and replaced $5 capacitor on the power supply, works great again
Posted on May 25, 2013
JUNK IT!!! ITS A COMMON PROBLEM WITH THIS MODEL EVEN DELL CANNOT FIX IT. ITS A FIRMWARE PROBLEM OR DESIGN PROBLEM THAT THEY CANNOT FIX. THEY DONT EVEN HAVE A REPLACEMENT FOR THAT. THATS WHY DELL STOP MANUFACTURING IT AND YET THEY STILL SELLING THEM.
Posted on Oct 05, 2010
PowerEdge t110. powered on, led 134 light up a sec, the system fan starts & shuts off. then all leds 1234 light up and off. all turns off & after few seconds, the amber light goes on and no blinking.
Sounds like the power supply is dying. Startup is the highest power draw. If there is a CD or DVD drive, make sure there is no disk in the drive. The optical drive startup is a huge power draw when starting. You should also disconnect any eternal peripherals. You might want to try disconnecting the hard drives, as they also have a large draw. If it starts after that, your supply is probably dying. Looks like a 300 watt supply. Looks like these are about the age I'd epect a power supply to die. I'd get a supply rated about 500 watts, but make sure if fits. Dell often uses proprietary supplies that are odd sizes. I'd look for supply from pc power and cooling or look at the newegg.com site for reviews of any 500 watt model that will fit.
May 24, 2017 | The Computers & Internet
Bought a new power supply since the previous power supply looked burned and short circuited. Installed the new power supply and sparks flew inside the Tv right when I plugged it in.
If you look around at where the sparks came from or for evidence of burnt parts inside the TV - not in the power supply - then you will find the fault that probably caused you bad looking power supply in the first place!
Oct 20, 2015 | Samsung UN37EH5000FXZA 37in Led 1080p 60hz...
Light goes blue to orange, no picture or sound?
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for blown fuses burnt parts, bad capacitors, etc. Look for 5vdc, 12vdc, and 24dvc. you have to this with the help of multimeter to read...
- You can look at the sample of the power supply board, the picture with the soldering side has labeling of what you should have on the output of the power supply, yours may be labeled on the top side of the board, there are high voltage on the board so you must be real careful, if you are not sure, let the professional handle it.
Good luck in solving the problem.....
May 31, 2011 | Westinghouse LTV-27w6 27 in. LCD HDTV
WHERE CAN i GET A POWER SUPPLY CORD FOR THIS PRODUCT
Are you looking for the cord that plugs into the the electrical outlet that connects to the external power supply? Or are you are looking for the external power supply as well? If you are looking for just the cord itself, they should be common item that you should be able to purchase and any appliance store.
If you are looking for the cord and the external power supply, there are many online outlets that you can look like ebay, etc. You need to search for a 15 Volt 4 amp universal power supply. I would recommend the universal power supply since it will come with multiple adapters plugs so you should be able to find the right one to fit your monitor. Also note the polarity of the the plug otherwise it might damage your monitor.
Jun 30, 2010 | Advueu Technology ADV1901B (Black) 19 in....
I have a ViewSonic N3250W Television with FSP212-3F01 power supply. The power supply looks OK no visible caps problems no burn signs. I get the 5 Volts output OK but not the 12 Volts or 24 volts. The red...
Does the LED kick on when you push the power button or when you apply power? Typically, the 5volts will run the microprocessor and that looks for a command (power button). When it sees a command, it will send a signal to the power supply to kick that on.. so at this point, you want to look for that signal. If you push power and no power on (p_on) signal goes to the supply, its likely your main board.. but if it does, and the supply doesn't react, then maybe its the power supply. I am not totally familiar with this tv, but thats how all of them really work. Even if the caps look good, some could be bad.. look for brands like "capXon, sanXon" are typically the defective ones, theres another but its slipping my mind.. usually 1000uf @ 16v are bad, or 2200uf @ 10v are also common.. you can search the value and the little code, usually like C9M or something and see if that batch has known issues..
let me know what you find, or how I can help
Jun 15, 2010 | Televison & Video
I am looking for the model number of a power supply for an acer ax1200. I need to replace it but I can't find the model number to search for a new one.
look on google for power supplies for acer ax1200 or go to acer site. you will find when you do the google search, many sites that may have it, just do good price checking.
Feb 03, 2010 | Acer (56.04145.901) (5604145901) Power...
Need to get a new power supply for my samsung monitor
you first look the watt on the power supply and if same watt power supply is available then connect because power supply has overload protection it will not work also look the connecter is matching if not then purchase only original power supply dont chase the duplicate it will consume more money
Nov 20, 2008 | Computers & Internet
Looking for a smaller fit 14cmX15cmX8.6cm power supply (ATX 12v)
It looks like a standard size case. Any power supply should fit. I doubt you'll find anything under 400 watts nowadays.
Heres a place with great prices on power supplies.. the prices jump around, so browse slowly:
http://3btech.net/powersupplies.html
Jan 11, 2008 | Computers & Internet
Dell 2300MP Multimedia Projector Logo
547 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
