Intertherm I have a package unit that has stated dropping out the cond. fan and comp, but contiues to run the blower motor. when I opened panel I noticed that the contactor will pull in and then drop out . this happens every few mins. The unit did this for the 1st time night before last. When I checked it yesterday morning I replaced the contactor and still had same problem. while checking voltages the contactor pulled in and the unit worked fine all day. then last night the problem returned. I opened panel and just placed a finger on the parts of a small board ( part # 6214770 ) and the contactor pulled in and has worked fine for more than an hour now. What could cause this and what can I do to repair?
  • 828 Answers
Check the board for a cold soldered joint. If you can move the spade that the line connects to it should be re-soldered. A cold soldered joint can give intermittent service because it can make contact at one time then loose contact by even a change in temperature around it.
Posted on May 16, 2008
Intertherm MGHA-070ABFC-05 will not run/cool
Multiple problems. Eliminate thermostat first. Remove face from wall and turn on breaker. If fan still runs you have a bad board or bad relay. If fan outside is running compressor should be too. These operate on same contactor. Verify you are getting 24 volts to coil side of contactor. If odf stops working and contactor remains pulled in you have a bad motor. If odf motor stops working the compressor will shut off due to overheating.
Jun 07, 2016 | Intertherm Heating & Cooling
Fan wont kick on
a bad fan motor they will go bad is the blower on your inside unit or the condenser assembly outside either could be a bad motor
Jul 13, 2012 | Intertherm Heating & Cooling
I have an old Intertherm gas-fired furnace, Model MGH-055AB which ceased operating last night. It was quite warm when I arrived home, and when I set the heat up a little, began to hum, but the fan would...
Tom P's answer is generally correct: The motor start capacitor is usually not the problem. However, in some cases, particularly on older furnaces, where there were capacitors of certain make and production run will prematurely fail. This happened in March on a mobile home HVAC unit where both the blower fan and condenser fan motor capacitors failed open circuit. Both caps were of the same Mfg, and production lot.
Here is a suggestion (for you or an electrically inclined friend): Locate a substitute motor capacitor having similar Mfd (or MF) and Voltage ratings. Remove power from the unit. Reach into the blower squirrel cage and spin it to verify that the shaft is not frozen. Pull the wires from the existing capacitor noting color and location. Connect the wires to the substitute capacitor and secure it place. Apply power and turn on the blower. A no start? Motor replacement time.
Nov 08, 2011 | Intertherm P3RA-048K Air Conditioner
How to install an intertherm furnace filter for MGHA-070AAFC-02
Hi, this is a 4 ton package unit, most filters are in the home. There should be a drop down grill somewhere in the home, maybe more then 1. If not, the filter would go on the blower back side of the evaporator coil. Remove the panel and see if it has a slot for a filter.
Shastalaker7
Nov 07, 2011 | Intertherm P3RA-048K Air Conditioner
Fan on unit not kicking on but comp is
You need to check the run capacitor on the fan motor.
Aug 02, 2011 | Intertherm Heating & Cooling
No heat fan running
This is a 10 Seer electric heat package unit. There are few possibilities. Does the blower come on when you put the t-stat on Fan on? If it does, then it is probably the blower time delay relay which is nordyne part# 622181. If the blower doesn't come on at all, check that the blower is getting power and if it is, then the blower motor is bad but could possibly be the capacitor as well. Both should be checked.
Mar 31, 2009 | Intertherm P3RA-036K Air Conditioner
Intertherm furnace problem?'s
the blower on my furnace keeps going on and off when i turn the furnace on .ichanged the snapdiscs no change changed thermocoupler and therostat still no change whats my problem
Oct 27, 2007 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
85 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
