Question about Makita 7" Electronic Sander - Polisher 9227CX3
Loss of power in my 6 inch dynabrade da sander
  • 2,176 Answers
Look for lMBSWOOL in rhw beush are.
Posted on Sep 16, 2010
  • jasonwarn Sep 16, 2010
    Not very helpful. Because of the spelling errors, I think you are saying there's lambswool in the brush area?. It's not a polisher I'm enquiring about. It's a DUAL ACTION sander!!!
  • David Ford
    David Ford Sep 17, 2010
    I am sorry but the header states that it is a POLISHER and that would be a symptom. I don;t appreciate the negative rating, I answered the question as it WAS POSTED, And ye s I might have misspelt some words but the point was clear. Please in the future please furnish the model number and brand and if I ever answer another one of your posts it would help. You have a nice day,
Why the oil will come out from the sander? how many oil drop must regulate the regulator
Oil coming out of the sander indicates that too much oil is flowing into the the supply air. The rule of thumb for oiling an air motor is 1 drop of light machine oil per minute, per 10 cfm of air.
Jan 16, 2014 | Dynabrade Air Tools & Compressors
Can i use my dynabrade sander to car polishar
I would not recommend it for that purpose. A polisher has a much SLOWER RPM than a sander and you would probably cause paint damage from burning, secondly the polishing pad might not be rated for this higher RPM.
Feb 17, 2012 | Dynabrade Tools & Hardware - Others
A friend gave me a 210055 3/32 Sander. I would like to get a manual for it.
Hi vepa, my name is John. Welcome to FixYa. You can get it here. www.mastertoolrepair.com . Thanks for choosing FixYa...John
Dec 05, 2010 | Dynabrade 6" Dynorbital-Spirit Random...
Dynabrade sander doesn't spin
check the exhaust muffler. or just take it off and see what happens.
there is usually an inlet air adjustment on the palm sander itself one of these will correct your sander.
if not, and your air supply is good. put some air oil in it or even a light weight oil will work.
if none of this is the correct action to get it going. its probably toast!
Mar 03, 2010 | Dynabrade 56818 5" Supreme Vacuum Orbital...
DA SANDER RPMS SLOWED
get some air tool oil and oil it lol, if that will not speed it back up you may have to take it apart and clean it but the oil should do the trick. Do NOT use wd40, etc. use air tool oil
May 23, 2009 | Chicago Pneumatic 864 6" Heavy Duty Dual...
I ned the internal vein parts.
One of the cool things about the Dynaorbital Spirit sanders is that, they were designed to be the lightest sanders out there (as opposed to the Dynaorbital supreme). This is nice as it keeps hand fatigue to a minimum. Another cool thing about the spirit, is that it was designed to be able to change out the entire drive motor all at once. The drive motor being the rotor with the vanes on it. These motors are available from dynabrade directly. replacing one vane only will tear the sander body up fast. I would recommend you get the replacement motor from them. They can be found here:http://www.dynabrade.com/dyn09/intro/selregmark/index.html
TIP: When replacing the motor, be very careful not to compress the sander body (i.e. bench vice).Dynabrade sells a rubber grip collar for this operation. then you just R and R (remove and replace) the motor and yer' good to go!!
May 12, 2009 | Dynabrade 59035 5 Non Vac Dynaorbital...
I have 5" Dynabrade Orbital sander that needs a new sanding pad and could probably use a going over at the same time. Who does this work? Cost
You can get new pads at the automotive paint stores in your area. They are not expensive. Most of these wholesalers have a service department that can r&r yours. Hope this helps you, Rick
Apr 21, 2009 | Dynabrade Air Tools & Compressors
AIR VOLUME REQUIRED
You need to look at the tool cfm requirements because they are posted on the package or usually in the ads. Your compressor will run the sander, just how long at a time will depend upon your tool's cfm. Rick
Apr 14, 2009 | Air Tools & Compressors
As soon as i apply my sander to the surface it stops sanding
hi a major problem with pneumatic tools is that nobody ever seems to oil them! try droping tool oil or a light machine oil down the air inlet and leave over night and then run the tool on full ,if this doesnt work then strip the tool and clean and make sure that the blade sealing surfaces are good
hope this helps ian
Mar 21, 2009 | Dynabrade 57810 Dynabug Orbital Air Sander...
Makita 7" Electronic Sander - Polisher 9227CX3 Logo
89 people viewed this question
Top Makita Tools & Hardware - Others Experts
Jim Thurston
John Porter
Are you a Makita Tool and Hardware - Other Expert? Answer questions, earn points and help others
