Question about ASUS P5P800-VM Motherboard
Please can you tell me, my motherboard Ram Device is too loose it and can you tell me that how to make it again??
  • ASUS Master
  • 27,725 Answers
There are 2 notches at either end of the ram module with 2 levers adjacent.
press down firmly on top of the ram until the levers secure into the slots
Posted on Sep 15, 2010
My refurbished Dell Latitude d600 won't turn on. Please tell me what is most likely wrong with it...
Check power. Check battery. Check RAM (memory). The main problems for this are usually failure to deliver power to the device, improperly seated components, or damaged crucial components such as the RAM, CPU, or motherboard.
Jul 30, 2011 | Computers & Internet
My Foxconn motherboard M61PMV suddenly stopped booting up. No beeps, no monitor but computer powers up. Before this everything was working fine and the computer was shut down normally. Please help me solve...
Will your system come up in safe mode? Try a shutdown and unplug the tower. Plug the tower back in and see if it will come up in safe mode. If it does, go to "control panel", find "device manager" and right click on it. Find "display adaptors" and click on box at right(has a little + inside), it should drop down your device. right click o it and you sjhould see 'enable" or "disable". If it says enable click on that ad you should be good to go. Make sure your connections between tower and monitor are good.
Mar 15, 2011 | Foxconn M61PMV Motherboard
Hi, I have this mother board, in my pc running windows xp, i decided to put more ram in it one day, and it just quit working. It says No Signal Input or Cable disconnected. Everytime I turn it on it...
One continuous beep should mean power supply, motherboard or keyboard problem. Assuming you didn't change any p/s connections, it's telling you the motherboard won't start.
The most likely cause is that you haven't put the RAM in correctly - it's often difficult to add RAM because it's so hard to see inside there with everything connected. Or you may have dislodged something else while pushing things out of the way.
While working inside the case, leave the power cord plugged in at both ends to provide an earth, but turn off the power at the wall. This will help to avoid static damage.
You need to remove the extra RAM again and see if the PC works as before.
If not, you'll need to carefully check that the original RAM isn't loose, and that no cards were dislodged.
If it does work without the extra RAM, you know it wasn't plugged in correctly. Try again, very carefully plugging it in and make sure it clicks into the motherboard completely. [RAM sticks only go in one way, if they've been put in backwards they can be fried.]
See how you go.
Jun 20, 2010 | ASUS P4SGX-MX Motherboard
Ram upgrade in 845GLL
Best advice....go to www.crucial.com and run their system scanner. It will tell you what you have, what kind it takes, and the max. amount you can install. They will also suggest upgrades.
This is the info I found on their site:
http://www.crucial.com/store/listparts.aspx?model=D845GLLY
Again, go to the site and verify it with the scanner. It is safe.
Thanks for using Fixya.
Dec 28, 2009 | Intel Motherboard
All problem of pc restarting
1. Power Problem i.e., SMPS - Replace
2. RAM Problem -Replace and check problem persists or not
3. HArd Disk Access problem with Sata Drives. Loose cable will cause that - Fix'em
4. Mainboard Problem - get it tested
Loose cable, dust on the Ram slots and connectors, Loose cards, etc.
Jan 05, 2009 | ASUS P5LD2-VM Motherboard
Fujitsu P1510 wireless card replacement
Some laptops have a modem or wireless card that clip onto the motherboard like how the RAM is fitted to the motherboard. This card is larger than the RAM and may have one or two wires connected to this card. If so you will be able to replace this card.
If the wireless is a chip and is mounted on the motherboard then it would be impossible to replace.
Your only solution to this problem is to buy a PCMCIA wireless card and insert into the laptop's PCMCIA slot or use a USB wireless device. You may have to go into the BIOS and disable the internal wireless device.
Nov 25, 2008 | Computers & Internet
MSI 915GM-FR Motherboard monitor looses power turns off /standby mode
this problem i have seen mostly with the d845gvad2 (series) motherboard. i myself is using it and it often happens. unplug the power supply connector from the SMPS and plug it again tightly, also press the RAM tightly, the RAM Sloth may be loose. Keep in mind, do it with the main power supply unplugged....
Oct 09, 2008 | MSI 915GM-FR Motherboard
Mother board dead
Hello how are you. Please give me ome detailed information the make and model of the computer. i will help you with this. Easy. This is what I do for a living.
Thank you hope to here from you
Feb 10, 2008 | Intel Motherboard
Display problem in pentium mother board!
MODEL NO.--INTEL 845 GVRS. problem is --- power led is on but no display and no beep sound. SMBS, RAM ,, PROCESSER, & HD Are all ok. Pls. tell me how can i slove my problem?
Nov 13, 2007 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
ASUS P5P800-VM Motherboard Logo
20 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
