Hello Fixya, I have a Lowe Profile Plus TV and when I switch it on a clicking sound comes through the speakers. It is a digital clicking sound, it happens several times and then the green light goes out on th unit. I would be greatfull for any advice you may be able to offer. The TV is about 10 tears old. Thanks again for your time and any help. kind regards John
    Genius:
  • 1,622 Answers
A common problem for these is bad capacitors in the power supply, Remove the back from your TV and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Take care and hope this help in solving the problem...
Posted on Sep 15, 2010
Why doesn't the ARC TV sound work through the HDMI cable? Is it because the KDL-52XBR7 only has the Bravia Sync and no ARC support?
Not all Hdmi cables have same capabilities. Check out:
http://www.hdmi.org/consumer/finding_right_cable.aspx
Mar 27, 2015 | home Audio Players & Recorders
Fault F96kHz
turn the audio down from the TV seems as if its overdriven, disconnect speakers , if no clicking, you have a speaker problem
Mar 04, 2014 | Kenwood Audio Players & Recorders
I cant find the hdmi icon in sounds
Hello walchell,
Welcome, and thank you for using FixYa!
To answer your question: HDMI Audio Output is part of your Digital Output package. Try turning up the Digital Output.If you are not hearing sound to your TV from your PC or DVR while connected to the HDMI cable, it is likely that you have purchased a cheaper HDMI cable that only provides video out. A high quality HDMI cable cost close to $35.00 for both outputs.
Have a great day!
Dec 01, 2011 | Computers & Internet
NO SOUND
Hello
First check whether the sound is muted or not. If it is muted, release the mute. If it is not muted and still there is no sound output from the TV, its speaker may have got damaged. To check the speaker, place your ear very near to the speaker side of the TV, and switch it ON by its POWER ON/OFF switch [Not by remote control power switch]; and listen whether there is a 'thumb' sound comes from the speaker or not. If there is; the audio output IC inside had damaged and shoul be replaced. If there is no 'thumb' sound from the speaker, speaker itself is damaged and sould be replaced. If you want anymore assistance, feel free to get me by Fixya. OK.
Jun 26, 2011 | Dynex 32 in. LCD Flat-Panel HDTV
When I connect my laptop to my tv with an HDMI cable the video works but the sound comes out the laptops speakers. How do I get sound to the tv?
What operating system are you using? If you are using Windows 7, right click on the Volume icon on the system tray and select "Playback Devices". A window would pop up showing you speaker and HDMI. Select HDMI and then choose the "Set Default" Button on top of the OK button. Thats it! If you want the sound to come out of the laptop again when you disconnect the HDMI from your TV, you have to do this again, then choose the speakers.
Cheers!
Mar 01, 2011 | Vizio 42 in. LCD TV
How do i get the regular cinemate system to run through my tv so i can watch cable tv while using the sound system. My tv is the LG 55LH55 the cable comes from the wall outlet directly to the tv. no dish...
Hello,at this point you have two options, You'll either need the home re-wired so the receiver is in the same room, or you can try purchasing an RF modulator. This is basically a cable converter you can find these at radio shack. Hope this helps!!!
Daniel Busa
DISH Network Customer Service
Jan 15, 2011 | Bose Cinemate Digital Home Theater System...
I have a 32" LG
Hello Undernet01,
Yes, it's very simple. Connect the computer speakers to the headphone socket on the TV, then run a separate audio cable from the PC to the TV. A PC monitor cable wont carry an audio signal so you need to connect an RCA type cable or similar - depending on whether you have corresponding audio OUT sockets on the PC and audio IN sockets on the TV.
You will then have sound from both the PS3, the PC, and the TV on the computer speakers. The TV speakers will automatically switch off when something is plugged into the headphone socket.
Simples as pies.
BElectric
Dec 26, 2010 | Computers & Internet
No sound
Hello
First you check the speaker of your Daewoo Tv. To check the whether the speaker is good or damaged, place your year very close to the speaker side of your TV, and switch the TV by its front panel power switch, not by the remote control. If you can hear a "Thumb" sound from the speaker, as the TV is switched on, the speaker is good and you have to to further. If not speaker has got damaged and have to be replaced.
If your TV is provided with an earphone or headphone socket at its fron panel, insert a earphone or headphone pin into it and listen whether there is sound coming from it or not. If ther comes the sound, it doesnot comes to the speaker, means that the headphone or earphone socket is faulty. Replacing it will solve the problem.
If there is AV OUT from your TV, connect it to an amplifier or so to get the sound. If there is sound and no output from speaker, means the Audio Output IC inside your TV is faulty.
Just locate the audio output Ic, and replace it with same type and number. Audio Output IC can be easly located ans speaker wire goes to that section, and follow the speaker wire. locate it. If you need any more assistance, feel free to contact me through Fixya. OK.
Dec 07, 2010 | Daewoo DTQ-20U9SC TV
We have a picture but no sound, it is hooked up to our surround system and the dvd and radio work and we have sound coming out of the speakers but no tv sound....help
Try switching the external/internal speaker switch on the back of the tv to internal. This way you should at least get sound (from the TV not the sound system) when you change the volume of the TV itself.
Explain your set up if you need more help. By that I mean what do you have hooked to the TV and sound system, Satellite or digital cable box DVD ?
Make a note of where all the inputs to the sound system come from.
Dec 04, 2009 | RCA P56830BL 56" Rear Projection...
Speakers
Test the speakers by changing source to the disc mode, and inserting a dvd into the HTS. If you get sound on all 5 speakers in DVD mode, then your speakers are still good. If you don't get sound on all 5 speakers, then press the "SURR" button to try the sound in stero, dolby, or other modes - one of these should give you sound on all 5 speakers. If you still don't get sound on all 5 speakers in dvd mode, then there is a problem with the speakers or speaker wires.
If you do get sound on all 5 speakers in disc (dvd) mode, but not when in TV mode, then take out the red and white AV cable, go buy a digital audio or SPDIF cable, and plug in the digital audio or SPDIF cable from the digital audio OUT of your TV or cable/satellite box to the "DIGITAL IN" of the HTS.
-Tha Mp3 Doctor
Feb 17, 2008 | Philips HTS3440/37 System
Televison & Video Logo
Top Televison & Video Experts
