Question about Sharp AR-M205 Copier
The machine is showing service man and developer
  • Sharp Expert
  • 1,326 Answers
That means that the drum & developer needs to be replaced. It depends on you? You will also need to reset the counters. Also, you can turn those warnings off in service mode.
Posted on Sep 15, 2010
How to mix toner in New machine Canon image runner 2525 .
you need to enter service mode.
Service key (the service key is like a mans head with a * in it)
service key >2>8>service key
navigate until you see ENGIN, press OK, navigate until you see TNRINST.
This procedure is to send toner to the Developing Assembly from the Toner Bottle at installation.
Best regards,
Marius.
Nov 28, 2016 | Canon imageRUNNER 2525 AllInOne Laser...
Help plz..... Hello Sharp has a slit 5516 in which the problem of red mark is showing maintenance man
you need to change the developer on the machine and clear the error code by entrance the service mode and press 14
Aug 19, 2016 | Sharp Office Equipment & Supplies
Developer light on
'Service man:press # interupt and C interupt
enter 24 and then 01 for drum and then 42 then 01 for developer.
Mar 22, 2014 | Sharp AR-5316 Advanced Digital Imager...
My sharp xerox machine AR-5516 is bleaking a man near toner signal point. why is this bleking? Kindly solve my problem.
The blinking man who we refer to as Mr Bill is a "time for maintenance light". Just ignore it, the machine will keep working.
Aug 21, 2011 | Sharp AR-5320 Black and White Copier
The error message is a symbol for of human being and a circle and dots around it.
A circle with dots around it indicates that the machine requires a developer change.
This should only be carried out by an engineer but you can still use the machine whilst this status light is up.
A red man indicates that a routine service is required.
hope this helps
Feb 10, 2011 | Sharp AR 163 Copier
Panasonic FP 7718 error e3 40
E3-40 means there is a problem with the machine reading the black level density...this is not normally due to a faulty component but is normally due to to dirt inside the machine and possibly old/worn developer and /or drum in the machine. These are items that would have to be replaced by a service man.
Feb 03, 2011 | Panasonic Office Equipment & Supplies
A) Developer signal is always showing after replacing developer.How can it be solved? Man signal is always showing. B) New toner has been replaced but also it is printing light.
A) To reset developer signal press: # key __ interrupt key __ C key __ interrupt key __ 42 __ ready __ 1 __ ready . and you may have to check program 41 for developer counter cycle
B) check the developer
Dec 16, 2010 | Sharp AR-5316 Advanced Digital Imager...
HOW TO RESET CAL SERVICE MAN AND TO RESET DEVELOPER
Apr 29, 2010 | Sharp AR-5320 Black and White Copier
Clear seviceman
The service man light is an indication that preventative maintenance is due to be performed on the machine. This is also most likely the cause for the faint copies.
This is true unless there is a code associated with the service man light...check the display for any alpha numeric codes such as H4 or L2 etc.
Oct 19, 2009 | Sharp AR-5320 Black and White Copier
I have been using sharp copier- table size(SF-2218). but recently a red image in form of a man is viewed which is stopping the copier from warming up.
Dear sir; The symble of red man, means need PM service, you need to replace DEVELOPER,
slide out developer unit and remove toner hopper(2 screw),Empty old developer,replace with full bag, reassemble, install back to the machine. power on, press "clear", "pause", "0", "pause" keys, then enter 25, press print, enter 2, press print,machine will run for 3 minutes, the "pause" key also call "interupty" key, when machine stop then press "clear" then enter 20 press "print" enter 01, press print, enter 0, then press clear key enter21 press print enter01 press print,enter 0, press print press clear twice to end the simulation.
If you not clear or need more help just email me, I always around, good luck!
DON'T FORGET GIVE ME A RATING
HAVE A HAPPY HOLIDAY !!!
Dec 22, 2008 | Office Equipment & Supplies
Sharp AR-M205 Copier Logo
85 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
