Question about Logitech SoundMan SR-30 Computer Speakers
Base speaker will not work - Logitech SoundMan SR-30 Computer Speakers
Both mini speakers are playing, but not getting any sound from the base box.... what might be happening?
The mini sub woofer's amplifier is not working but the other amps powering the left and right channels are ok.
Nov 28, 2013 | Klip Xtreme KSS-710 2.1 Stereo Speaker...
Speaker phone in base unit does not work
probably a bad solder or kinked wire going to speaker
Mine is perfectly working.
Nov 20, 2012 | Panasonic KX TG1061 Phone
The speakers on my Griffin Evolve wireless speaker system will not work. However, when I transfer them to a second identical system and base, using the same iPod they do work. It seems as though the base...
Well, you did the right thing by verifying that the speakers are not the problem (they work in an identical system). Try connecting a different iPod, just to rule out that being a problem. Some of these docks need an adapter for some versions of the iPod... check to make sure you have the right one. Otherwise, if the base is defective, maybe you can get a replacement from Griffin. Contact their technical support staff. Good luck.
Nov 07, 2010 | Griffin Technology Evolve Wireless Sound...
My harman kardon soundsticks base light flickers, no sound
Ok this needs careful observation to determine this type of problem
Please unplug these speakers and plug it into an mp3 player and write back to me if the speakers work ok? I'll tell you more from there
Mar 15, 2010 | Harman Kardon SoundSticks II Computer...
One of the speaker ports does not work, only left and center works but not right, does the base have a fuse box?
Please check if the cable connecting the speaker port to the speaker is OK. To check this, connect this cable to any other port and see if the speaker is working. If so then the internal connection has to be set right by a technician from the BOSE company as they have the necessary tools to open the Base. Yes, the base has a safety fuse to save the system from spikes.
Dec 20, 2009 | Bose (321GS) System
JBL Creature Speakers have very low volume
use another device like your i pod to make your jbl sounds louder and then plugged it to your pc without turning it off. after plugging try to test it if works.
Apr 02, 2009 | JBL CREATURE II Computer Speakers
Speakers losing base
if ur speakers are losing base..then check out any two or more wire may b naked.
and they wre touching each other.
so apply tape on them.
this may reduce the noise..& bass will come back.
Mar 14, 2009 | Packard Bell Speaker Computer Speakers
Base Spearker not working
I got mine today (not new) and took it apart and saw two wires that SHOULD go to the bass speaker completely off. It seems to me that there was a line of units that the wires were too short and the workers just pulled them out. I would take it back if i were y'all (if it wasn't from a thrift store like mine :) )
Feb 07, 2009 | Altec Lansing Multimedia Computer Speakers
When i place my sirius radio into the base, driver side speaker goes off and on but most time i only hear the passanger side speaker working, I had my sirius sportster for 3 years. I think it is the base,...
when you listen to a cd or the normal radio does the drivers side speaker work? if it does then it is most likely the base is the problem. you might have a loose connection in your car. or the speaker is blow.
Jan 01, 2009 | Sirius Satellite Radio Sirius Sportster...
How to add more speakers?
In the end I biwired the speakers and that's worked fine.
Aug 12, 2007 | Denon D-M71DVS System
Logitech SoundMan SR-30 Computer Speakers Logo
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
