Tech support Error code SC45-20 on Konica 8050
  • Billy R May 16, 2008
    still need help
  • Nisar Khan May 11, 2010
    Sc45-20
F45-20 Color registration correction
results in abnormality.
Printer control board (PRCB)
Color registration sensor /F (PS8)
Color registration sensor /R (PS9)
Posted on May 16, 2008
How do i reset error c20 in bizhub konica minolta
OHP sensor malfunction had a tech check it out and or replace
Jun 04, 2016 | Konica Minolta Office Equipment & Supplies
Bizhub 164 error code CC153
Have a tech come and re-flash the firmware, and check the NVRAM. Firmware is only available fro secure Konica Minolta Web site they like to keep they software secure. You mite also have a bad control board. Or the memory on the board, a Tech is required.
May 08, 2014 | Konica Minolta bizhub Office Equipment &...
How to clear error code cfa35 on a Konica Minolta c352
Copier Operating system firmware crashed need tech to reflash
Jan 10, 2014 | Konica Minolta Office Equipment & Supplies
Konica minolta bizhub c350 error codes c-0510
eror code c-0098 meaning ??????????????pls tell me the solution
Jul 31, 2012 | Konica Minolta Bizhub C350 Digital Copier,...
I have problem witm color copier konica minlta 8050 with error sc28-02
Check the yellow drum charge corona to get that open the front of the machine unscrew the front section then pull out he charge corona for yellow do not have open the unit to expose belt and drum. ensure they all are seated properly
Feb 02, 2011 | Konica Office Equipment & Supplies
Have a HP Photosmart 8050. Won't Print. In the
go on web site www.hp.com they will answer your question after putting in you model number of the printer you have
Jul 27, 2010 | HP Photosmart 8050 InkJet Printer
Error code EA3226 when I try to scan to e mail on Konica Bizhub C220
this error code is not listed in any of the konica c220 books or on the konica minolta service tech internet site
Nov 11, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
I need to reboot a Konica Minolta 8050 printer copier with error code SC27-04
Hi...
Error Code : SC27-4:
Output of toner density sensor/K (TDS K) cannot be controlled.
Unplug the power cord that should reboot the copter.
Let me know
Thanks
Smith
Jul 28, 2009 | Konica Office Equipment & Supplies
Konica 8050
need to activate jam codes on the machine so you can pinpoint the problem.it's in the 25 mode dip switch 11-7 to on
Sep 29, 2008 | Office Equipment & Supplies
Konica 7020 Printer
HI,
you need to reset the fuser latch as it has a fuser error code most likely needs new thermisters,
anyways give this a go, hold down 2 and 5 keys together and power on machine, this will put you into to a service mode call 25 mode, go to dip switch 3 and bit 1 and then next to bit 1 hit the key that says turn off,
turn machine off and back on should clear error code, if it doesnt you need new thermisters, even when you put in new thermisters you still need to clear this error in service mode
Regards
Konica Tech
Feb 15, 2008 | Office Equipment & Supplies
176 people viewed this question
jasbo
jasbo
