Question about Hoover Dryers
Hoover Electron Dryer Model D6214 after say 5 minutes motor slows down and stops. Timer continues operating. I have unplugged, removed the back cover, reconnected to power, motor starts then stops. Flicking the fan on the motor it runs again for a short time. The motor appears under some strain but nothing is evident. Belt looks in good condition and tensioned well. Please advise, Thanks.
    Master:
    Sergeant:
  • 449 Answers
The motor bearings are about tofreeze up replace motor
Posted on Sep 15, 2010
Timer won't stop after cycle finished.
Dryer will not shut off:
The timer: Located in the control console of the dryer the timer consists of a small motor connected to a series of gears that rotate cams, which turn electric contacts off and on inside the timer. The timer contacts control the dryer motor as well as the heat circuit and the timer motor itself. A defective timer motor or a defect in the timer's electrical contacts can cause the timer motor to fail and the timer will need to be replaced. The contacts can be checked for continuity with a multi-meter. This test should only be made when the dryer is unplugged. Another test u can do is observe by eyesight and see does the timer advance or is it stuck on one cycle?
1. On gas and electric dryers that have an "Auto Dry" cycle, the cycling thermostat is often used to advance the timer as well regulate the drum temperature. Essentially, thermostat will alternately turn on the heat source or the timer motor when the temperature has been satisfied. To check this thermostat, you will have to check for power to the timer motor with a multi-meter, during a cycle. This is a live voltage test and caution should be used.
2. Some dryers will use a cool down thermostat to tumble the clothes without heat, at the end of the dry cycle. Power is routed through this thermostat to the drive motor to keep it running until the drum temperature has dropped to a specific temperature. If this thermostat fails it can cause the drum to turn indefinitely or until the door is opened. You can check the thermostat for continuity with a multi-meter. This test should only be made with the power removed from the dryer.
Lastly check the moister sensor for OHMS according to ur schematic as it must show a certain amount of ohms as per ur unit. When unit has been on short while
May 20, 2015 | Dryers
Maytag Dryer
HI,
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Aug 28, 2008 | Dryers
Freezing compartment stopped operating. Heard motor struggling, then stopped. Frost had gathered at the back wall of the freezer to over 1/2 inch thick. Refrigerator side also gave out cooling. Cleaned...
Hi, What you are having is a defrost problem. You will need a defrost timer or on newer models the control board, also the defrost heater and the termination thermostat. You will need your complete make and model number to get the parts from a local supply house. You will need to unplug the machine. The back wall of the freezer needs to be removed. Use a blow dryer to get rid of ice buildup. Install parts. Timer is probably in the frig compartment or the board on newer models on back of frig. Hope this helps
Jan 18, 2011 | GE Refrigerators
I have a whirlpool LEC6646aq2. Noticed a burning smell inside drum.The dryer baffle inside the drum was completely melted. The timer was stuck on 20 minutes and the heating element was full on . The...
it sounds like one of the coils on the heating element could be touching metal and grounding out constantly running until you shut it down manually,when the heater is on the timer doesn't move until the heat shuts off,then the timer advances,when the machine calls for heat again the timer stops and the heat comes back on,it does this until the timer reaches zero but in your case the heater isn't shutting down and is keeping the timer from advancing.the filter is on the top of your dryer so unplug it,pull it out remove the ventline from the back of the dryer and remove the back panel,you'll see the heating element on the right side,also with a meter check the thermostats on the heater box,when checking any part at least one wire has to be diconnected or you won't get a correct reading,check for continuity on all the parts on the heater box,when the dryer is running correctly say you have a blocked vent line,when the dryer starts running hotter than normal the thermal fuse or the high limit thermostat will pop,the thermal fuse is the white piece to the right of the lint filter duct and the hgh limit is the top thermostat on the heater box,but with the element grounding out nothing will shut it down until you manually cut the power by moving the timer to off,if it melted the baffle you could have damaged other parts like the motor,check the rear end of the drum and see if there's like yellow on it or lint stuck to it where it touches the back wall,if there is then the oil from the motor sprayed out and the motor could last for a week or 5 years but the overheating most likely damaged it,if the dryer is old you might want to think of buying a new dryer instead of repairing it and then you have problems with something else like the motor or changing out thermostats in a month or two but you have to make that call,good luck and let me know what you find
Oct 30, 2010 | Whirlpool Dryers
Dryer will start run 5 minnutes shut down
After the dryer has been started to run, the motor will stop only when at least one of the motor feeder circuit wires is disconnected. The main feed line is routed through the timer while the neutral feed line is routed through the door switch. Hence, the problem is either the timer or the door switch. But the dryer shuts down 5 minutes after it is started and this signifies a dead spot in the timer that discontinues the main feed line shutting the motor down and also the timer motor. If the timer stops at the same point, then the timer is faulty and needs to be replaced.
Replacing the timer is an easy task that an average handy housewife can do. Just make sure the power to the dryer is disconnected prior to servicing to avoid the risk of electric shock.
Pull the timer knob off the console then remove the screws attaching the console rear panel to the console and move the panel away.
Disconnect the wires from the timer terminals one at a time then connect it to the new timer to avoid swapping out the wires.
Remove the screws securing the timer to the bracket then remove the timer and secure the new timer in place. Put the console rear panel back into position and secure it with the screws.
Apr 07, 2010 | Whirlpool WED5200T Electric Dryer
Maytag dryer model PYE4558AYW. Stopped running, and no light in drum. Getting power. Timer switch continues to work. Fried Timer?
first off check to see if you don;t have a breaker tripped in your breaker box ! also make sure there is 220v going to the recept.
then with unit unplugged remove the back cover to see if there is a wire burnt on the motor start switch which is common will be a red or a orange wire. if all that checks out then sounds like a timer issue
Jan 12, 2010 | Maytag PYE4558A Electric Dryer
Kenmore electric dryer model number 86860100 dryer not heating.....cleaned out vents not the problem....everything else seems to work.. I had seen in the past it glow in back of the dryer so I turned out...
hello there:
Testing with an ohm meter checking on a dryer....
These are the places that pass voltage to the heater elements on an electric dryer. In order to check a dryer for no heat, here is a list of places to check. Remember to always unplug the appliance before starting testing with an ohm meter. Always remove wires from the part you are testing with an ohm meter ( write down what goes where first before removing any wires ).
Meter testing and usage tips.
1. Power supply-check power supply at terminal block where cord enters the dryer. Should read 240V. If you read 240V here, tested with a volt meter, unplug dryer and test components with ohm meter.
2. Thermostats-Cycle and safety thermostats-read them with an ohm meter. Should show continuity . How common thermostats work.
3.Timer-The timer has a set of contacts that pass voltage to the heaters. If you can not determine by wiring picture what they are, check across the two terminals with the largest wires on them. The heater wires are almost twice as large as the others. You should read continuity with timer in heat mode.
4. Thermal fuses-In recent years the makers of dryers are using thermal fuses to let you know something is wrong with your dryer. They are generally non resetting and have to be replaced. The thermal fuses are located on the heater element housing and should read continuity if read with an ohm meter. Most blown thermal fuses are the result of vent/air flow problems or a grounded heating element.
5. Selector Switches-Read the wiring picture and determine which switch is closed. You should read continuity across closed switches.
6. Safety Switch on Motor-There is a safety switch on motor to insure that heaters can not come on unless motor is running. It is normally open when the motor is idle/not running, and closes when motor runs. In order to check with an ohm meter, remove the two large wires on motor switch and make them electrically safe. Tape them. Plug the dryer in and start motor. Check continuity across the terminals on the motor switch you removed the heavy wires from. If it is ok you should read continuity. Remember that the smaller wires in a dryer carry the 120V and the large wires carry 240V. There is no voltage on these two terminals with wires removed. It is ok to test with ohm meter.
7. Heat elements-Test heater element with an ohm meter. You will read continuity across a good element 8-12 OHMS
Jan 09, 2010 | Kenmore Dryers
Dryer keeps running and timer continues to move around dial.
A common problem, had it happen to me.
Replace the timer control. takes about 15 minutes and the skill to remove screws, disconnect plug from old timer, remove timer, install new timer, connect plug, replace screws and panel, run dryer.
Reply the model number, and I'll get you the timer P/N.
Jan 15, 2009 | Kenmore 97572 Dryer
Dryer runs for minutes then stops timer keeps going and going and .....
remove the vent on the dryer that goes to the outside start the dryer if it continues to ru n and not cut off you have a venting problem of the house
if it cuts off after 5 mins with the vent off you have a motor that is going bad
Jun 11, 2008 | GE DBXR463EBWW Electric Dryer
Dryer stopping in middle of cycle but timer continues to run.
oK " It's your timer, it has to be replaced
it's not going threw all it cycles, will start but will not finish
not a big job, unscrew plate on back at the top you will see
timer , take it out and replace it
( can not stress enough that you have to unplug the electrical cord from the wall socket before working on a dryer or any appliance )
Jan 24, 2008 | Whirlpool LER3624JQ Electric Dryer
Dryers Logo
Top Hoover Dryers Experts
Tim Whalen
John Tripp
John Tripp
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
