Hey guys, I have a WD External 640GB HDD and I want to convert it to NTFS from FAT32. My External Drive is under (E:) connected via USB 2.0
  • 6,487 Answers
If you want to convert the file system of that hard drive to NTFS , you can only do that when you format the drive, so in order for you to do that right click the E: and click Format and from there you can select the file system that you want to use.
Posted on Sep 15, 2010
Hi, my ps3 won't recognise my 1tb wd external hard
The problem with the new 1Tb WD Passport that I just purchased is that it is a USB 3.0 format and apparently PS3 doesn't recognize that speed.
Haven't found a workaround for it yet, but all these people advising you to reormat anew Passport drive are wasting your time.
Jul 02, 2012 | Computers & Internet
Is WDBAAU0015HBK is fat 32 system file format? IsWDBAAU0015ABK is also available? How to convert my existing seagate 1tb hard disk from ntfs to fat32 with out making partition?
You can convert FAT32 to NTFS, but you cannot reverse this process. If you want to set up the hard drive for FAT32 you need to delete the NTFS partition the create a new partition and then format in FAT32.
Aug 24, 2011 | Western Digital WD Elements Desktop...
Wiselink won't recognize my WD external hard drive
Your drive is setup as ntfs it needs to be formatted to fat32 via Windows and if Windows won't let you format it to fat32 you need to use a drive partitioner program you can find several free ones on the webz
Jun 06, 2010 | Samsung DLP HL-P5663W 56" TV
How do I format my WD MyBook Elite to FAT32
Using FAT32 these days on a current OS will half the
HDD storing capabilities especially if your unit uses'
a SATA HDD , FAT32 speed compared to NTFS is
less than half and the compression tool on NTFS
are more compact and compile better , also FAT32
is used to apply an operating system not for external
storage and if you are using your external storage HDD for holding an operating system to the HDD
will be suspectable to contracting viruses and
putting your data at risk , since the external HDD
is static and does not run through the OS registry
Jan 28, 2010 | Western Digital My Book Essential Edition...
1tb wd external problem
Dear, What type of file system it is. FA16 supports only up to 4GB but FA32 and NTFS support more. For more info http://www.ntfs.com/ntfs_vs_fat.htm
And, please try to format the drive using FAT32 if its FA16 or NTFS and try.
Oct 15, 2009 | Western Digital My Book Essential 1TB...
I tried plugging in my WD hard drive to my DVD player to watch movies but the player wouldn't recognize it. Thank you!
First thing is to check what format the HDD is using - if it's been formatted on a Windows box, it's likely to be NTFS - and a lot of consumer electronics devices can't read NTFS, just FAT or FAT32.
Jun 10, 2009 | Western Digital External USB 2.0 80 GB...
Free space on my external hdd
If your External HDD file system is configured as FAT32 instead of NTFS, the max file size limit . By using NTFS, you get increased security, file compression, disk quotas, and encryption—features you don't get with FAT.
To convert the default (FAT32 to NTFS):
1.
Close all open programs to avoid loss of data. Be prepared to restart your computer.
2.
Open Command Prompt, and at the command prompt, type convert C: /FS:NTFS, where C represents the drive letter of the disk to convert. Press Enter or Return on the keyboard.
3.
Wait while the process completes. Don't do anything while the conversion is taking place.
You can also open a Command Prompt from the Run line (available from the Start menu). Just type cmd and press Enter.
Other useful links:
http://en.wikipedia.org/wiki/File_Allocation_Table
http://windowsitpro.com/article/articleid/38803/understanding-file-size-limits-on-ntfs-and-fat.html
May 19, 2009 | Western Digital My Book Home Edition 500...
Format external hard drive to NFTS
Assuming you are running Windows XP or Vista, the easiest is through the Disk Manager.
Open the administrative tools from the Start menu and select Computer Management. Then select Disk Management in the console.
Now you can right-click the disk and select Format. Chose NTFS and wait for it to finish (which will take some time!).
Do realize that this will erase your data on the disk. If you do not want that, you need to use the CONVERT command from the command prompt. type CONVERT /? to find out about its usage.
Jules
Apr 04, 2009 | Western Digital Elements powered by WD 320...
Phillips 1TB HDD problem, playing movies hrough DVD player (USB)
My question would be are the movies in the right format. Just because they play on your computer does not mean they will play on you DVD.NTFS or FAT 32 would have no bearing on this. They are simply data per sector protocols and are related to magnetic storage devices.You may need the proper codec for you computer so it can make a DVD you player can play.
Dec 14, 2008 | Computers & Internet
WD mybook world won't work on mac?
Window and OSX - fun and joy.
Since you formatted a 1TB drive and it works fine in Windows, I have to concluded the the drive was formatted NTFS.
Here is the issue in a nutshell, OSX supports reading NTFS but have very limited write cababilities.
If you want both Windows and OSX to have full access to an external drive you should format it FAT32. The only issue then is that under normal conditions a FAT32 drive has a maximum size of 32GB.
I would partition the drive to have 1 or more FAT32 partitions and then have the rest of the drive NTFS.
Is the OSX version correct or should it be 10.3. If it is actually 1.3 it would mean you have the OSX Server edition that originally came out in 1999 and it may not have very good USB support - version 1.2 would only support 1 USB device.
Oct 16, 2008 | Western Digital 500GB My Book World...
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
