Question about Acer Aspire One PC Notebook
I have had my laptop for 3 months - yesterday it was working, today it wont turn on. I have checked battery pack, changed fuse, changed plugs etc and nothing! Please help! :o)
  • 2,567 Answers
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced
Posted on Sep 18, 2010
2 months ago i replaced all the spark plugs and coil packs on my 2003 mazda 6. yesterday my car started acting the same way as when i needed these things replaced and today the check engine light went on...
I don't know how many miles you have on your car, but it is possible that you may have a spark plug being fouled out either with oil or coolant. I had a Protege with 120k and it burned more oil than gas. Change #3 plug and get a good look at the plug you remove. Look for signs of contamination.
Aug 18, 2011 | Mazda MAZDA6 Cars & Trucks
My acer d250 laptop wont turn on unless it is plugged in
Clean the baterry connector port with an alcohol solution or Spirit solution.and try.
If you can get hand to another battery,check out if everything is fine.Otherwise replace the battery.
Check if you have warranty of the battery.
Dec 27, 2009 | Acer Aspire One PC Notebook
My laptop wont start! ASUS X59SR!
its avirus and you have to format
Aug 23, 2009 | Computers & Internet
2001 Jetta - won't start EPC light is on - tried manually disengaging by pressing brake and EPC Sensor simultaneously and releasing. Still no luck. Battery is working fine -
2001 jetta gls turns over but wont start. In the past month the temp light on the dash would come on for approx 10 seconds then would go away. This happened 2-3 times. Over the past two weeks when I would start the car it would turn on, then immediatly turn off, only to turn back on within 1 try. This happened once. Yesterday while taking my son to school the car died, again only to turn back on immediatly with one try. Today I went to start the car and it turned on for 3 seconds then turned back off but this time will not start again. I checked all the fuses (one by one) at the panel inside the car on the drivers side. All were fine. The car turns over fine but will not start. Extremly frustrated...
Jun 06, 2009 | Volkswagen Jetta Cars & Trucks
Engine misses, then shut off, won't start again
not sure about the 2008 model, but the earlier ones had coil pack problems. it looks like part of the rocker cover with around four torque screws holding it down and one multi plug at the end on the n/s of the engine. oh they used to blow the fuse at the same time for the engine management. 30amp dooor pillar/"A"post area. test by removing the coil pack, fitting the spark plugs into the plug outlets. earth the body of each plug and crank the engine, you shoukld see a spark, if not then there are other tests before confirming the coil pack. let me know how you get on.
Apr 01, 2009 | 2008 Saab 9-3
My toshiba laptop l10 281 has stopped working it was working perfectly and was shut down properly wen i went to turn it on again today it wont go it wont even light up please help!! thanks in advance john
If nothing at all works then perhaps you have no power to the system.
Check that the powerpack is getting power (does it hum or get warm when plugged into the mains socket?) Check all connections to the power pack and back of laptop.
Try taking the battery out and powering up on only the power pack
Do you know anyone with a similar laptop that you could swap power pack with?
Jun 30, 2008 | Computers & Internet
Honda civic wont start
You might have to change the spark plugs or at least have them cleaned.
Jun 19, 2008 | 1996 Honda Civic
My computer its not working is off
try and plug in your charger and then put it on. it is obvious your battery is low. and if you left it on with the power plug on, try and replug it now if the light did not come on then there is possibility that your power pack is bad. then you have to change it. good luck
May 24, 2008 | Gateway Solo 5300 Notebook
Acer Aspire One  PC Notebook Logo
54 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
