Question about ASUS P5VD2-MX Motherboard
Computer reboots whenever I try to use my dvd/cd driver. same sometimes happens when using my 3G modem.
  • ASUS Master
  • 27,725 Answers
Test your PSU power supply unit
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
good luck
Posted on Sep 15, 2010
My drive will not burn dvd-r anymore but it used to, it burns cd-r and reads discs no problem, but now when i try to burn the disc spins but makes a strange knocking noise.
sometime it has more to do with the driver software than it does with the unit itself.
Try uninstalling the writer software, restart the computer, reinstall the software, restart the computer, and attempt burn again. Software occaisionally gets confused and needs to be "rebooted" from time to time. Hope this helps.
Oct 12, 2009 | BenQ DW1670 Double Layer 16 DVD RW IDE...
I get kicked off line whenever I open either one of my optical drives.
try updating the drivers.if you cant just uninstall them and reboot the computer.Windows will find new hardware and reinstall the drivers.
good luck
Sep 14, 2009 | Plextor PX-708A DVD±RW Burner
Whenever i am connecting the lg lxu-800 usb modem in my computer it is asking for the device driver software.Although i have the cd,still it is not getting detected.
  1. Disconnect modem from computer by taking out the usb lead from computer
  2. insert modem cd in cd/dvd drive and run install
  3. Install the driver from the cd
  4. follow directions onscreen the restart computer if necessary
  5. plug modem back into usb port
  6. now when windows detects it it will find the correct drivers
Welcome
Jun 22, 2009 | Computers & Internet
Vista home basic and 3G modem installation
The 3G Device is actually two devices in one. It is a portable storage unit and a 3G Modem. Once the cdrom driver is installed you can go to my computer and it should show up. you then go into the cd drive which has appeared and run the setup program to install the 3G Modem Driver. That is the way they designed it.
Jun 06, 2009 | Microsoft Windows Vista Home Basic for PC
CD/dvd drivers missing or malfunctioning
Try uninstalling itunes, restart computer, and then reintall itunes.
Dec 24, 2008 | Toshiba Satellite A105 Notebook
Acer Monitor AL1706 freezes w/ horizontal lines after burning cd
The issue is you system, download memtest86 and run it from disk if you get any error your ram is bad or it my be the program you are using try uninstalling it and reinstalling it
Dec 09, 2008 | Acer AL1706AB LCD Monitor
ACER 9410CD/DVD-ROM driver not found.
I am assuming you are using XP,
update the drivers via device manager and select the device with the yellow question mark,right click update,reboot and restart
if nothing then remove the device via add/remove programs
select device and remove,reboot and restart
should auto recognise and install the drivers for you,
dont forget to do SP2 updates
Good luck with that,
Let me know how it goes thanks
Aug 14, 2008 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Modem driver
Sounds like you've got a memory issue, sometimes when the computer is working with complex memory calculations the module dumps the data on the stack and poof reboot. Try a newer memory module? Also go into bios and see what options you have for memory processing, depending on age of laptop you might be able to disable the ALU in the CPU but it sounds like a memory issue.
ALso try reinstalling direct X, and even possibly windows itself.
Modem driver, consult mfg.
Aug 12, 2008 | Dell Latitude C840 Notebook
Unable to connect to internet through netgear modem. told to uninstall firewall, this I did but still no joy.
really need more information to make an educated guess, but if this netgear is recently added, try using the control panel - add/remove and remove all programs for the netgear. Then control panel - system - device manager and uninstall the modem. Keep modem connected to pc and reboot. After it detects the modem use the modem cd to load only the driver. Let windows manage the modem.
May 25, 2008 | Compaq Computers & Internet
DVD reading problem
1. go to device manager / right click on cd drive / uninstall driver / reboot and windows will reinstall driver 2. go to My computer right click on cd drive properties - check digital cd playback recording - check enable cd recording on this drive driver - update or uninstall reboot your computer Goodluck!
Jan 18, 2007 | Sony (DW-D22A/B2) DVD±RW Dual Layer...
ASUS P5VD2-MX Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
