Question about Karcher 2500 PSI Pressure Washer
Im just wondering if you had a picture of the water pump showing the way to put it back together thankyou for your time my email is dingopm@y7mail.com
    President:
  • Karcher Master
  • 1,388 Answers
Go to the address below and click on the parts link for a complete drawing of parts and order in install - Good luck
http://www.ppe-pressure-washer-parts.com/karcher-g2500oh-pressure-washer-parts
Posted on Sep 15, 2010
99 vw jetta 2.0 4 cyl auto changed water pump timing belt driven put back together ran rough like out of time. put cam and crank at tdc per markings. engine rotates when key turned but dont start. just...
Did you remember to reconnect your Cam Position Sensor after putting it all back together? One tooth off shouldn't have bent a valve (but pressure checking cylinder will answer that). Did you check TDC once the belt is tight?
Aug 06, 2013 | 1999 Volkswagen Jetta
What are the components in the handle of a Ryobi RHP 410 pressure washer?
Hello sir, that is a on going problem with power washers the pump not working, than works sporadically. the main cause is leaving the pressure hose hooked up to the machine over a long period of ,not draining hose & machine, in the winter time the hose & pump willfreeze causing hose & pump to expand and burst. build up of calcium deposits from hard water clogging up pump nozzle,valves in the gun handle,clogging hose fittings and screens.one of these has to be your problem.you can find a parts brake down at KARCHER.COM.orRJ BOWERS.COM . and manuals,these are good info,sites,hope this helps, MrFixIt,oh could you please rate this solutions.thankyou. ``
Jan 28, 2012 | Ryobi Garden
Ok good day my blackberry fell in water and the morther board is gone im wondering how can i get my bbm contacts back i have another blackberry now but im wondering is there a software i can put my pin in...
if the contacts are in the sim, then u can recover it by putting the sim in other cellphone.
and if its not saved in sim, you will have to go to the blackberry authorized shop.
Jul 01, 2011 | Cell Phones
Water Pump
first you have to take off the exhaust manifold. then take off the top motor mount and lift plate on the passenger side on top. then take off the 25 little bolts and nuts off the timing chain cover. with the cover off, take out the bolts on the timing chain tensioner (towards botton, by the crank, looks like a little rod in a aluminum housing). now take off the curved tensioner shoe and the chain will loosen. take the chain off. now the fun part is getting the bolts off the back of the water pump to the block. then the bolts connecting the water pump to the steel housing. and finally the three nuts connecting the pump to the chain housing. not hard just frustrating. replace the pump and new gaskets (comes with pump) and bolt back everthing back together. you may want to change your thermostat while your there since its right by the pump. now putting the timing chain back on and having it in time isnt the hardest thing but if your a first timer take your time. go to a mechanic and ask to print out intalation insructions on timing chain installation. then bolt it all back together.
Dec 23, 2008 | 1998 Pontiac Grand Am
Fisher & paykel waher
If you call f&p they will fax or email you a parts break-down. 888-936-7872
Jul 14, 2008 | Fisher and Paykel GWL11 Top Load Washer
Jeep CJ-7 304 V8 motor
did you put the washer back on the harmonic balancer this very well could be your problem, and did you use the old balance or a new one.but you are right if they dont line up right the belts wont stay on. give me more info. and i can help you get it straight.
Dec 08, 2007 | Car Audio & Video
Karcher 2500 PSI Pressure Washer Logo
107 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
