Question about M-Audio FireWire 410 External Sound System
Audio pops and clicks
I am running a m-audio fw410 on a philips quad core with vista 32 bit os.
Everything is ok,apart from recording externally.Whenever i attempt to record
live vocals and\or instruments,the resulting sound is of very bad quality.
Also,i must say that when i was using xp os i had no problems.
  • loxly May 26, 2008
    thanks for your reply ABASS,
    but i already purchased a new 1394 card and
    everything seems to be working fine...........
  • Anonymous Jun 20, 2008
    Hello, I have the exact same problem.
    I recently upgraded my computer and installed the latest driver from MAUDIO. Everything works fine except recording through MIC/LINE inputs.
    the input signal, when heard through the headphones is clen, however when playing back the recorded audio it has lots of crackle and digital distortion.
    It is not play back that is at fault here as any other audio file is played back without these interferences... I have tried changing PCI slots, tries to free up IRQ's... none of it has made a difference... any help would be greatly appreciated
    thanks,,
    Ben
My suggest that you should check your device managr and see if you have the sound driver on your system or you switch back to your normal XP. the vista might not compactable with it Thanks ABASS
Posted on May 26, 2008
Can i make a dual core run like a quad core, or add cores with out changing mother board?
You may be able to install a quad core processor on your motherboard, will need the model to check.
You can't make new cores out of nothing though.
Oct 22, 2012 | HP Compaq SR5702F PC Desktop
Wont to upgrade graphic card my p.c has 2gig max ram in it wonts should i upgrade to to preform its best cheers mike
Depends on what kind of hardware you have
-Memory- 2 gb ram is "ok" if you use windows XP but if you have Vista or Windows 7 you should have a minimum of 4gb ram.
-Processor- if you have a Dual core processor you are ok, if you have a p4 or p3 you dont want to waste money on a new graphics card because it will not help you get better games, your processor and memory will slow you down instead.
So my advice is, if you have a OK computer, go ahead with buying a new graphics card if you computer is old and slow, DONT buy a new card! put your money on +2gb ram instead (cheap,and gives you more benefits) or maybe buy an "upgrade package" with new motherboard-memory-processor.
May 05, 2011 | Computers & Internet
I have a problem in downloading sound driver for window7
There are no officially supported Windows 7 drivers for the Acer Aspire 5570 notebook. However, the Vista drivers should work just fine.
If you don't know whether you have 64 bit or 32 bit Windows 7, then please follow these steps.
1. Press Win+R to open the Run command.
2. Type "MSINFO32" into the dialog box and press enter.
3. Look for item "System Type" and note whether the value is x64 or x86. (x86 means you have a 32 bit OS)
Regardless of whether you have 32 bit or 64 bit Windows 7 follow these instructions:
1. Go ahead and download 32 bit Windows Vista drivers by following the link: Acer Aspire 5570 Audio Drivers
2. Save file to the Desktop for easy access.
3. Extract ZIP file to Desktop.
4. Open the extracted folder.
5. Right click on the file "Setup" and select "Properties".
6. Select the Compatibility tab and check the box for "Run this program in compatibility mode for Windows Vista (Service Pack 2)". Click OK.
7. Double click the "Setup" file to run the installer. If the installer completes, then restart the computer and play a music file to see if you have sound.
If the installer fails, then follow the next set of directions:
1. Press Win+R to open Run command.
2. Type "DEVMGMT.MSC" and press enter.
3. Look for a device that has a yellow exclamation point next to it. If you have more than one, look for a device that says "Multimedia Audio Controller".
4. Right click on the device that has a yellow exclamation point next to it and select Properties.
5. Click the Driver tab and select Update Driver.
6. Click "Browse my computer for driver software".
7. Select "Browse...".
8. Browse to the extracted folder and select the "Vista" folder if you have the 32 bit version of Windows. If you have the 64 bit version of Windows, then select the "Vista64" folder. If Windows tells you there are no compatible drivers after step 9, then select the WDM folder and repeat step 9.
9. Click OK and then click Next.
10. Ignore all errors that Windows may give you and install the driver, restart the computer, and try to play a music file.
Good luck, post back if you have any difficulties, and thanks for using FixYa,
Apr 10, 2011 | Acer Aspire 5500 5570-2609 Laptop
Can the Dell Latitude D610 run any of the following games: Age of Conan Star Trek Online Champions Online Aion
Check your system if it meets the following requirements
Age of Conan
Required
OS: Windows Vista/XP
Processor: 3GHz Pentium IV
RAM: 1GB RAM
Video Card: Shader Model 2.0 and 128MB RAM: NVIDIA GeForce 5800 or ATI 9800
Recommended
Processor: Intel Core 2 Duo 2.4 GHz (E6600) or better
Video Card: NVIDIA GeForce 7950GX2 or better
RAM: 2GB or more
Enhanced for: DirectX 10, 64-bit processors, multi-core
Supports Parental Controls on Windows Vista
Start Trek
System Requirements
  • OS: Windows XP SP2 / Windows Vista / Windows 7 (32 or 64-bit)
  • CPU: Intel Core 2 Duo 1.8 Ghz or AMD Athlon X2 3800+
  • Memory: 1GB RAM
  • Video: NVIDIA GeForce 7950 / ATI Radeon X1800 / Intel HD Graphics
  • Sound: DirectX 9.0c Compatible Soundcard
  • DirectX: Version 9.0c or Higher
  • HDD: 8GB Free Disk Space
  • Network: Internet Broadband Connection Required
  • Disc: 6X DVD-ROM
Recommended System Configuration
  • CPU: Intel E8400 Core 2 Duo or AMD Athlon X2 5600+
  • Memory: 2GB RAM+
  • Video: NVIDIA GeForce 8800 / ATI Radeon HD 3850+
  • Disc: 6X DVD-ROM
To check your system hardware> click on start>all programs>accessories>system tools> system information.
Thanks for using Fixya
proton
Mar 27, 2010 | Dell Latitude D610 Notebook
Diffrence
The terms 32-bit and 64-bit refer to the way a computer's processor (also called a CPU), handles information. The 64-bit version of Windows handles large amounts of random access memory (RAM) more effectively than a 32-bit system. For more details, go to A description of the differences between 32-bit versions of Windows Vista and 64-bit versions of Windows Vista online.
Jul 24, 2009 | Computers & Internet
32 bit IE won't connect to internet in Vista 64 bit.
32 bit programs, last I checked, won't work in a 64 bit operating system, just as 64 bit won't work in 32 bit operating systems.
If 32 bit programs will work in a 64 bit OS, they probably won't work properly.
Jun 08, 2009 | Dell Inspiron 530s Desktop Computer...
Need help with flstudio and east west colossus
HAVE THE PERFECT SOLUTION FOR YOU MAYNE
I was having this same exact problem it was pissing me off! i kept trying over and over,, tweaking everything with my colossus instrument and exporting but my sounds kept F'in up
but i tried some new sh**,, i basically juss saved all my instruments that i played on the colossus, individually as wav files,, then loaded them again from the browser in Fl studio,,, IT WORKED!! try it mayne if u have any questions hit up my email,,, ruthlessfam@live.com
May 10, 2009 | Audio Players & Recorders
Motherboard not work as it should work
hi some motherboard does not support vista. try to install windows Xp. if it keeps working then the problem will be the os, otherwise try to upgrade ur bios or ur supplier
Mar 15, 2008 | ASUSTeK P5K Desktop Board - Core 2 Extreme...
O s
The four things that make 64-bit Vista inadvisable for ordinary users are:
1: No compatibility with old 16-bit Windows apps. This means ancient Windows 3.x software, which most people don't run any more, but 16-bit code can still pop up in the darndest places. Like, for instance, in the installer programs for other apps.
2: No automatic registry and file redirection, which is what 32-bit Vista uses to allow existing software to work with Vista's better user account security, even if the software wants to do admin-rights stuff to the registry and Program Files directory. Many apps still break in 32-bit Vista, but many more break in the 64-bit version.
3: No compatibility with existing 32-bit drivers. Everything on your computer will need a new driver. 64-bit WinXP is the same, and there aren't many 64-bit computers on which Vista won't at least install, but 64-bit Windows also has...
4: No support for unsigned drivers.
Jan 28, 2008 | Computers & Internet
Open Questions:
M-Audio FireWire 410 External Sound System Logo
97 people viewed this question
Top M-Audio Computers & Internet Experts
Gareth Cockram
Gareth Cockram
mukhtar21 shaikh
mukhtar21 shaikh
John Bolton
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
