Question about Refrigerators
I have a Zanussi Electrolux fridge freezer. Model: ZRB2630W. The drop tray at the rear of fridge freezer is filling up with water and smelling, meaning it is not evaporating the water that is coming from the drain valve. Could the connection that is meant to make it evaporate water be faulty?
  • 1314 Answers
SOURCE: locate evaporator condensate drain tube
next remove the evaporator fan cover and under the evaporator will be a silver tray with a hole in it this is the drain for the defrost systems and some times they get frozen the best way to clear them is with a eureka 350 hand held steamer you can get at Lowe's fairly cheap you can also find about 1000 other uses for it a round the house
Posted on Jan 26, 2008
  • 1462 Answers
SOURCE: Overflowing drip pan under the fridge
for reallybsq
problem could be door seals not sealing completely and hence excessive ice formed on evaporator and excess water when it melts. however, i have found this problem many times with large larder fridges and really found no cure.
for guest.
towards the bottom of the back wall, there is a gulley with a drain hole in the middle. this drain is blocked. clear it with something flexible and make sure water flows away freely
Posted on Sep 07, 2008
woodchuck789
  • 4070 Answers
SOURCE: GE Monogram Built-in refrig has blocked evaporator drain.
You should be able to see the drain under the coil. Part 804 on this diagram. Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing.
Posted on Aug 26, 2009
SOURCE: I have a maytag MSD2754GR, the freezer bottom is all iced
The drian hole has become stopped up and ice has accumulated in the the drian hole. You will need to unplug the fridge and remove the cover on the back (located at the bottom, 6 screws). On the freezer side there is a drian hole with a rubber 90 and a clear line that runs to the drain pan. Remove line and unstop. Don't not put the line back on yet.
Now for the fun part, remove the basket and the two bottom shelves from the freezer. Half way up the back there are 2 screws that need to be removed. After removing screws pull up on the top cover to so you can remove the bottom cover. The bottom cover maybe froze to the coils and to the inside drain pan. Break the ice with a butter knife, and remove cover ( do not hit the coils). Now you need to break the ice that is froze to the the pan and under it. Once you have remove all the ice you will see the drain hole, use a small pointed object to break ice that is in drain hole. Now you can put the drain line back on and make sure that the other end is in the drain pan under the fridge. Now reassemble the fridge and plug it back up.
It took me about 20 minutes to do this.
Hope this helps.
Posted on Sep 11, 2009
  • 48 Answers
SOURCE: My Fridge leaks water on to the floor. water not evaporating
Do you live in a very humid environment? Do you open and close the doer repeatedly? Both of these factors contribute to the water tray getting overfilled. Also if you are in a very humid area the tray will not be able to evaporate all the water.
Check also to see that the underneath area of the fridge has been vacuumed of as much dust as possible, especially on the coils. Poor airflow caused by excessive dust will contribute to the water not evaporating as fast as it should. Be aware that the water you see comes from the FREEZER section where the cold coils are located. Try hard not to put wet things in the freezer and try to keep it closed as much as possible. In the drier months does this happen?
Posted on Sep 21, 2009
Where is the defrost timer in a Zanussi ZNB323W/ Electrolux/ ZNB323S fridge-freezer ? I can't find it?
The timer box is located in the compressor compartment to connect the timer to the electrical components which
defrost the battery evaporator (defrosting heater, thermal switches).
Dado
Sep 24, 2015 | Zanussi & Electrolux Fridge Freezer Handle...
My Westinghouse fridge freezer, model WSE6100SF, was affected by a power cut lasting 3 days. It now smells, but not inside. Is there a drip tray under the fridge that collects the water?
yes there is but most are not removeable.... remove the cover in the rear of the fridge, the pan is located around the fan motor that's underneath the fridge... I would try pinesol, bleach or odoban to kill the smell..... good luck
Oct 09, 2014 | Westinghouse Refrigerators
How do I run a diagnostic test on my fridge freezer?
I would check the coolant pressure is correct. You may need the services of an engineer with the correct equipment and gas bottle.
Aug 11, 2014 | Zanussi & Electrolux Fridge Freezer Handle...
Why is it leaking a lot of water
Where is a leaks occurred at the bottom of the refrigerator door or from back side ? Which model you're talking about ?
Dado
Jul 30, 2014 | Zanussi & Electrolux Fridge Freezer Handle...
Zanussi freezone fridge freezer model number zfc 50/17 freezer working fridge not
FREEZER FAN MOTOR MAY NEED REPLACED. THE EASIEST WAY IS TO TAKE OFF THE BACK PANEL IN FREEZER AND REMOVE THE FAN
MOTOR, TAKE IT TO THE NEAREST APPLIANCE PARTS STORE WITH YOUR MODEL NO.
EASY JOB.
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
need more help go here:
http://www.applianceaid.com/procedures.html
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Sep 27, 2011 | Zanussi Refrigerators
Can i turn the freezer part of my fridge of so i can defrost the bottom part n leave the top part on , i have a zanussi electrolux
no your model is a single compressor which runs both frdge and freezer.. freezer is supposed to be frost free however freezing elements can be overwhelmed with frost if door has been left open. there is a drain hole behind the back panel of the freezer that can block or freeze up causing water to flow in tp the freezer and turn to ice. complete defrost and check that drain hole is clear to fix it.
Jul 24, 2010 | Zanussi ZEBF250W Bottom Freezer...
Fridge smell
It sounds as if you may have had a spillage at some stage in the fridge unit and this has gone onto the tray at the rear of the unit at the bottom on top of the motor.There may be some other explanation when you do pull out the fridge to access this tray.It may be easier to clean the tray in position as they can gat damaged if you try to remove them.If so get some soapy water and a sponge then clean out and dry,also some spray dissinfectant in the tray after cleaning will help.
May 03, 2010 | Zanussi ZEBF277W Bottom Freezer...
I have an unexplained smelly zanussi fridge/freezer model Model zx99/5si? I have a zanussi frost free fridge/freezer model Model zx99/5si which is just 4 years old and it is now giving off a revolting...
Hi - we had this problem, and it was in fact where some blood from a defrosting pice of meat drained into the compressor condensation tank and began to decay!
I agree the smell is terrible, so a good clean up is needed but this solves the problem immediately!
Kind regards,
Mike
Aug 14, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
I have a zanussu fridge
Re. Zanussi ZK87/46EFS Fridge Freezer
The same symptom occurred in our fridge freezer. The fridge compartment warmed up whilst the freezer compartment continued to keep temperature.
The cause of our problem was diagnosed as a frozen sensor that controls a flap, that controls the flow of cold air from the freezer compartment up into the fridge compartment. We were advised to power off the fridge freezer (removing all food and trays from the freezer unit first), and to leave it to defrost for 24hrs. We needed to place a few towels on the floor of the freezer compartment to soak up the melt water. After 24hrs we followed the power up instructions in the manual (versions are available online if you have lost yours). Within a few minutes it was obvious that the fridge compartment was being cooled – Problem solved :)
Apr 13, 2008 | Zanussi Refrigerators
Refrigerators Logo
82 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
