Question about GE Profile Spectra JGBP79 Gas Kitchen Range
Digital Display Doesn't Work
My control panel doesn't work. No display, no control on the oven. The range lights work, the range top ignites and runs fine but no oven controls. No clock, nothing. Could the control panel be cooked? Is there a fuse to replace some where? Is it less expensive to replace the oven than the control panel?
  • jaquee May 16, 2008
    We have the same problem... I have a GE Profiel Gas Range Model #JGB920SEF2SS. While baking in the convection bake mode, I pushed the Broil button and instantly the display panal went blank. Nothing. But the oven light is on and won't go off, even when the door is closed..
    We tried turning the breaker on and off and still the display panal is dead..and oven light still on.
    Any suggestions would be greatly appreciated!
  • Anonymous Jun 21, 2008
  • 213 Answers
SOURCE: the touch pad panel on stove is blank
on the ge range, you need an ERC its the main control for the oven. yes its costly. comes in a kit with a new wire harness
Posted on Nov 21, 2007
  • 23 Answers
SOURCE: GE Profile JGB97 Self Cleaning Oven Controls won't work
It sounds like the controls have been placed into a lockout mode. If your model is a JGBP79 do the following:
1) Press the BAKE and BROIL HI/LO pads at the same time for 3 seconds until the
display shows SF.
2) Press the SELF CLEAN pad. The display will show LOC OFF.
Now here is where the directions are kind of confusing, I will give it as they say it:
3) Press the SELF CLEAN pad again. The display will show LOC.
4) Press the START pad to activate the control lockout feature and leave
the control set in this special features mode.
Seems to me if its locked already, you would just do steps 1 and 2. And if you wish to lock it do steps 1 thru 4.
Posted on Jan 27, 2008
bestdarngood
  • 3037 Answers
SOURCE: Oven does not heat but broiler does
The most common cause of this symptom is a defective ignitor. Oven ignitors can glow and allow enough current through to open the oven gas valve but just not produce enough heat to ignite the gas immediately (see the link below).
In that case, replacing the oven ignitor is the usual solution.
http://www.appliance411.com/links/jump.cgi?ID=823
Posted on Mar 22, 2008
  • 26 Answers
SOURCE: Electric Oven not getting hot enough
Sir, I think the top oelement is for broiling ONLY. It should not turn on when baking. The clicking may be the oven heating up.
How far apart were the oven temp instrument and the digital?
Don't expect them to match...they are inaccurate.
1. Heat water until it boils. Place digital therm in boiling water until it comes up to 212deg. If it is not at 212 in boiling water, record the error.(this gives a rough calibration to the digital)
2 Turn on oven, set to 350 deg, place digital therm on rack. Wait until oven reaches 350 (on stove) and read the digital. Note the difference between the two
Posted on Mar 30, 2008
  • 10865 Answers
SOURCE: Whirlpool oven won't ignite
The good news for you is that your gas provider, the folks who bill you for the gas offer a free service whereby they will send out a technician to adjust your stove for no cost.
Posted on Apr 01, 2009
Kitchenaid oven troubleshooting
it sounds like the heat escaping from the door damaged the electronic control board part number 8186393 and sears has it for 200 dollars.the way the door was left open was directing the heat right at the computer board and you sholud never use the stove for heating the room or things like this happen
Nov 20, 2011 | Kitchen Ranges
I have to use a match to light the stove top and the oven doesn't work either.
what i believe is if power is on to stove,the igniter work off of electric and espically if no power to range the oven will not work
Aug 22, 2011 | DCS RGS-305 Professional Gas Kitchen Range
I have a whirlpool gold electric range,accubake model gy397lxus.oven not heating and range top not heating,digital control blank unless i rotate a heat selector for range top to on,the light indicators for...
I have look up your unit, I found the thermostat located inside the back panel the would only take out the function to your elements in your oven.
High limit thermostat
This link shows its location and price of the part. Now for you display issue, before continuing, push and hold the clock button on the panel until you hear a beep, if the unit is set to Sabbath mode this will clear that. If not I will continue, by the way missing a version number to model number, like a number (0 or 02). Have you have a power outage recently? I am not locating any line fuses the would take the display out. If the clock doesn't reset then I would think about checking warranty or can your dealer to inquire on your warranty.
Control Unit
Good Luck and I hope this helps.
Aug 17, 2011 | Whirlpool GY397LXUS Stainless Steel...
Frigidaire ES400 range - oven will not opperate, range will
Me too. Oven was on, big "pop" and breaker went. After re-setting the breaker (and setting the clock on the range), the stove top works fine, and the controller for the oven seems fine, just that neither the top or bottm elements will heat up in the oven. 240 V is getting to the control module, but it is not sending out any juice to the oven elements.
Any fixes out there?
Mar 30, 2009 | Kitchen Ranges
Oven does not work
Open the control panel to expose the clock/oven control.
With a volt meter verify incoming voltage to the clock control.
Check all wires for good contact.
If it still does not work replace the clock.
Remember to unplug the range to check the wires for good contact.
Mar 04, 2009 | GE Spectra JBP78 Electric Kitchen Range
Dual fuel kitchenaid; burners work, oven does not
I had a similar problem. There's a thermostat before the control panel. You need to remove the knobs and the front panel to get to it. You'll also need to remove a couple of trim pieces to keep from bending the panel. The part number is Whirlpool W10017820, sells for about $40.
Nov 29, 2008 | KitchenAid KDRP467KSS Dual Fuel (Electric...
Frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work
my frigidaire oven will not light. The broiler works and the oven ingiter lights up, but the oven will not ingite. The electronic display does work.
Aug 25, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
The touch pad panel on stove is blank
Nov 16, 2007 | GE Profile JGSP48 Gas Kitchen Range
GE Profile Spectra JGBP79 Gas Kitchen Range Logo
438 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
