Magnavox 42mf230a smoked
My one and half year old magnavox 42mf230a had freezed frame, then black screen with sound, then smoked from right back side. It was very hot after unpluged. Can we still repair it?
    Sergeant:
  • 308 Answers
It should be repairable, however I would suspect the cost to be about half what a new one would be. A circuit board plus labor can easily approach $500. If you're lucky and it was just a few easily replaced components like capacitors venting, then you could possibly get off with a few hundred less.
Posted on May 23, 2008
How do I fix my Samsung LN52A580 TV as the right half of the screen is totally black (even thought I get sound and picture on the left hand of the screen)?
Samsung HL-R6178W DLP TV half of screen goes black [Solved] - HDTV ...
www.tomsguide.com/forum/54431-4-samsung-r6178w-half-screen-black
Aug 28, 2013 - 36 posts - ‎24 authors
Samsung HL-R6178W DLP HDTV I just bought this tv used as is. Every once in a while, the right side of the screen goes black on all inputs. I have read ... As for the 1000 dollar price tag, that's totally bonkers. I found a web site ...Missing: ln52a580
HLR6768W - Right half of screen goes black - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI have a 4 year old 67" Samsung DLP which has worked pretty well other than having... Over the past 6 months it's developed a new behavior where the right half of the screen goes completely black and stays that way until I power cycle the tv.Missing: ln52a580
Samsung LN52A580 Vertical Line Problems - YouTube
? 0:32
https://www.youtube.com/watch?v=eejE6O340EY
Aug 22, 2011 - Uploaded by Jonathan Polis
Samsung LN52A580 Vertical Line Problems ... This feature is not available right now. ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical Lines, ... Sanyo LCD with DistortedHalf Picture Lines Waves Distortion Distorted ... Samsung DLP Green screen / lines Repair HLR XX67 Series ...
lcd/led tv one side dark video screen display problem fix ...
? 2:28
https://www.youtube.com/watch?v=dYHPKxijz1A
Jan 21, 2016 | Samsung LN52A580 52 in. HD-Ready LCD TV
My magnavox model# 42mf230a/37 tv turns on I get good sound and picture but it has a 4inc black line onleft side edge of screen
Black lines on Plasma TV are cause by either the buffer boards or the logic board. OR your screen is bad. the only way to find out is the replace the boards. I would start with the Buffer boards. The buffer boards are located on the bottom of the screen attached by ribbon cables to the screen. look at the bar and replace the board that lines up with it. You can find parts fro this TV at www.interliquidparts.com You have to get the actual part number from the part on your TV to get the correct one.
Jun 13, 2011 | Televison & Video
This morning I turned on my Magnavox plasma screen 42MF230A/37 and I heard a strange pop. When the picture came up there was a large black jagged spot covering about a third of the screen on the left...
Chances are real good, that you have a blown capacitor. When you open or lift the back cover, you will find one or two capacitors that are bulged! These capacitors will need replaced. I would guess one of them will be 25 volts at 1200Mf. There will be another very close by. I do not recall its value at this time. It will need replaced as well. Find a TV tech or even an electronic hobbiest to check all the nearby capacitors. You may be able to save this TV. Give me a few hands and thanks for asking!
Sep 13, 2010 | Televison & Video
Magnavox plasma tv model 42mf230a/37 sound but ni
Replace lower scan converter PCB, which plugged into Y-Sustainer Board, located to the left of the display if you poke back cover open. There are 2 of them, but in some models might be the one, long PCB.don't wait to fix it! otherwise, you will knock out Y-
Sustainer and upper scan converter. That will cause you to spend few hundreds to fix it.
Good luck,
Alex's TV Service,
Philadelphia,
Pa, 215-806-5980.
Jan 21, 2010 | SNK Magnavox 42MF231D 42 in. Plasma TV
I have a magnavox 42mf230a/37 with black screen
more that likely your set got a serge and bleew a couple of capacitors in the power supply esay to find they will have dome on the tops from venting
Sep 17, 2009 | Televison & Video
Magnavox plasma tv model 42mf230A/37
I guess they are just built to fail. Mine was less than a year old, but they are sending me the exact same unit. Uggghhh
Mar 29, 2008 | Televison & Video
42 inch magnavox #42mf230a/37
One of the driver IC'S has gone bad. Need to replace just the driver IC or the board that the IC is on and that should solve your problem. If that doesn't do it, then the BAD NEWS IS THAT THE PANEL IS BAD. Replacement is you only option then. Good luck. GURU JAY.
Mar 16, 2008 | Televison & Video
I have a plasma tv need help
Sounds like panel is bad or driver ic is bad on the board directly below the black line. Good luck on the repair. Any questions, we can do a chat and go from there. GURU JAY
Mar 14, 2008 | Televison & Video
Garmin auto gps c330 freezes
"Black Screen"
It took a nap...
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Oct 14, 2007 | Garmin StreetPilot C330 GPS Receiver
Televison & Video Logo
181 people viewed this question
Top Televison & Video Experts
Electro Med Services...
