Question about Nintendo DS Lite Console
DS Lite top screen and mic not working properly. Good ole boyfriend tried to replace the casing and the mic on my nds lite, but apparantly, I'm the more technical talent of the two. The problem after replacing the casing and the mic is that the top screen isn't working properly. It's white / grey depending on the position the screen is in. Speakers are working fine, the top screen itself is not replaced. The orange strip that is on the back of the screen, soldered to the ribbon cable, has been severed, the ribbon cable has been tugged (not bent or anything). Could this be the problem? How to fix this? And the mic still doesn't work. Mic was properly replaced, brand new. The contacts for an external mic have been cleaned, I read dirty contacts there could make the ds lite believe there was an external mic. What else to try?
  • 83 Answers
Hi - either the cable is not ALL the way in the connector ( double check) or the cabels damaged after install ( common) you need to repalce the entire screen on a ds lite as the cable is not detachable.
as for the mic - you will need some PCB rework on the motherboard to rectify that I'm afraid, contact us at www.dsdoctor.co.uk if you need any more help :-)
Posted on Sep 17, 2010
Testimonial: "Thank you! I've decided to just go for a new one, since my lovely pets decided that an open DS is fun to chew on. But thank you very much!"
NDS lite has the power(green lite flashes), but screens wont lit
When you switch the DS lite on you should notice that one of the screens flashes... if thats correct then the screen that doesn't flash is the one that will need replacing which, I would assume is the upper screen as judging by what you say has a damaged ribbon.
Regards,
SOD69
Feb 10, 2010 | Nintendo DS Lite Console
Nds lite wont turn on
if you have another nds lite try switching batterys if that dont work then its broke, sorry.
Sep 21, 2009 | Nintendo FOR NINTENDO DS LITE NDS AIRFOAM...
Turns on and lights up but no images on top screen
The DS top screen has two components, which are the LCD display, and the backlight. If the LCD display has gone bad but the backlight still works and the connecter is seated properly, the DS will still power on and the lower screen will be normal, and the top screen will light, but it won’t display anything.
You didn’t mention if your DS is the original DS or the DS Lite. Replacement top screens for the DS Lite are cheap on eBay, but installing the screen is a bit complex. The screen for the original DS is a different part and they are more expensive and hard to find.
I’ve never worked on an original DS, so I can only tell you about installing the top screen on a DS Lite.
First, the DS Lite has to be just about completely disassembled. You have to completely remove the top and bottom cases, pull out the microphone and wi-fi cables, and release the connecter for the top screen, which is located on the main board in the lower case. You’ll need the tri-wing screwdriver. You can leave the bottom screen/touch screen assembly attached to the main board, but be careful not to pull or tear the flex cables. Check YouTube for videos on disassembling the DS Lite.
Here’s the deal breaker for most people: The speakers are soldered to the flex cable of the top screen. I’ve never seen a replacement sold with speakers. You’ll have to unsolder your speaker wires from the old screen cable and reconnect them to the new one. If you can’t solder, you could take the screens to a local tv/electronics repair shop and pay to have it done. I got this information for you from http://wiinewz.com/forums/nds-general-discussion/72805-ds-top-screen-white-blank.html this appears to be a common problem I hope this helps
Dec 01, 2008 | Nintendo DS Lite Console
R4DS
what is R4DS?
Dec 26, 2007 | Nintendo DS Console
Bottom screen scrambled on nintendo ds lite
This option is only suitable for out of warranty devices as opening it violates the warranty.
Open the device following this info:
How to dismantle an Original Nintendo DS.
If yours is the NDS Lite, just find this video in youtube:
"Disassembling Nintendo DS Lite"
The bottom screens have 2 wrap wires, one big and visible, that is the screen cable, the other is small and not so obvious and this one is for the touch screen and you dont want to get it broken.
The cable connectors release the cable by lifting ot pulling the brown or black lock and be sure to remember how it was connected so you can know the right position of the cable when connected right not having any problem with loosen cables before you finish.
Good Luck...
Dec 16, 2007 | Nintendo DS Lite Console
Nintendo ds
Its possible though sometimes it is expensive so dont worth the work.
-Top screen broken: you can buy a replacement and carefully do the work by yourself with the help of a guide (youtube have many) and some tools (3 winding screwdriver is the less common though not much). The foil data ribbon can be bought separatelly for the original NDS though the new NDS lite have it soldered and very difficult to work.
-Broken plastics: a broken hinge means you need to buy a replacement shell. Anyway buy a complete shell from a DS modding shop or take parts from a non broken plastics DS (water damaged one may be good) in a place like ebay. You would be lucky if you find a non broken screens and good plastics DS for parts.
At the end you may be over your repair budget and not only that, you would be very near to buy a new unit with this money. Each one make its own choice.
Good Luck...
Dec 03, 2007 | Nintendo DS Lite Console
Conection?
Here is a guide to dismantle an original Nintendo2.gif DS:
How to dismantle a Nintendo DS.
If yours is the NDS Lite, just find this video2.gif in youtube: "Disassembling Nintendo DS2.gif Lite"
And after opening it you can do your work. Make sure the flexible cables connecting the top screen part of your DS are well in place and not broken. Your problem may be only a loosen cable but in case the cable is broken you gonna need a replacement. Be careful not to damage the screen or other sensitive electronic parts on your device and you will be on your way.
Good Luck...
Dec 01, 2007 | Nintendo DS Lite Console
Top screen cracked
Here is a guide to dismantle an original Nintendo DS:
If yours is the NDS Lite, just find this video in youtube: "Disassembling Nintendo DS Lite"
And after opening it you can do your work replacing the top screen. Just be careful with the flexible cables, the new screen and other sensitive electronic parts on your device and you will be on your way.
Good Luck...
Dec 01, 2007 | Nintendo DS Console
My nintendo ds lite top screen isn't working properly
Top LCD's flex cable that passes through right-hand hinge into bottom part of case will be damaged or not properly seated in its connector socket.
Nov 17, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
317 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
