Question about Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television
Little white dots on the screen
I now have about 14 white dots that look like the milky way in the left side of the screen. They showed up all at once about a week ago. It's like the pixels burst and left no color... The TV is less than six months old, bought from Best Buy.
  • 1 more comment
  • maurgord May 24, 2008
    We have an authorized service rep coming out on 5/27, so we will give them your suggestions. If that's the problem, I'll post back how helpful you were!!!
    Oh, oops, the TV is 65 inch. . .
  • taterbug519 May 24, 2009
    have one of these dots on my screen. everything else is working fine. how do you do a cleaning?
  • Anonymous Mar 13, 2014
    just replaced the lamp and the color balast now the picture has smearing or pixelization. This smearing at time is like a polarization effect especially on faces in movies with moody lighting. The white dot issue I understand but is the color issue also a result of a bad dlp/dmp chip?
    New Friend:
I have a mitsubishi projector tv and it just got white spots what can i do to fix it
Posted on Apr 27, 2013
Go to ask.com to find info lolz
Posted on Oct 02, 2008
Had an authorized warranty repair center out, they said the projection bulb needs to be replaced, "good thing it's under warranty." They should be back next week to replace, hope that fixes it.
Posted on May 29, 2008
    Scholar:
  • 173 Answers
Dirty lens, dirty mirrors, warped light guides, spider webs and mini-UFOs that fly across the inside can cause what you described.
but 6 months is pretty early for a cleaning but possible.
Posted on May 24, 2008
I have a 2005, 42" toshiba LCD model 42DPC85 that when we turn it on everything is good except the whole screen is black but imediatly the colors dot by dot start making the black disappear, it only took...
You need a new DLP chip. The chip has little mirrors that are black on one side and white on the other side. When the chip wears out , your screen will turn white one dot at a time or black one dot at a time or they may just all stick shut at once. Since your screen is black, all your mirrors are closed. You can buy the chip from shopjimmy.com and they have a video of how to replace the chip so you can do it yourself. It takes about 1 1/2 hours. The chip is about $160. To have this service done for you is about $200. Do it yourself and save the money. Your tv will be just like new again. Just make sure the chip is in perfectly level or when you turn your tv back on, your picture will be slanted. you won't notice it on the picture itself but words on the screen or scrolling messages and the menu will be slanted.
Feb 10, 2014 | Toshiba Televison & Video
Mitsubishi xd280u white dots
bad dmd chip $200 http://www.youtube.com/watch?v=775YOs-aOPc&feature=share&list=UU_Iacxxa-E63l6FhQjkcH8A
Jan 20, 2013 | Mitsubishi XD280U Projector
Lenovo Y410 white screen
All that's left is the Video Cable, and LCD screen, Aberger.
Video Cable connections are tight? LCD screen side, screen Inverter, and motherboard side?
Then a continuity check with a multimeter set to OHMs, for each wire in the cable, or take to a 'Mom and Pop' computer store, and have the tech check it, or replace.
Video Cable checks out, connections check out, the LCD screen is the problem.
My money is on a bad LCD screen, JMHO.
Regards,
joecoolvette
Oct 25, 2012 | Lenovo 3000 Y410 Notebook
Just paid to replace the lamp 2 weeks ago in our mitsubishi 73 dlp 1080p tv purchased a 5 year in home contract with Tweeter Sevice net 1/2008 lamp fixed and picture is once again great but now the 73...
Mitsubishi that the one,who u should contact.Talk to them make some kind of deal with them to help u to do a repairing or replace the tv Light Engine Projection Block.That the tv problems,this problems a design flaw on the tv Light Projection Egine Block the IC they put in that causes of this white spots are showing up will continue showing up more and more white dots.It will not stops.
Sep 03, 2011 | Mitsubishi WD-73833 73" HDTV
How do you change a low beam headlight bulb on a 2008 Buick Allure?
I actually did change my low beam bulb with ease. I took pictures to help with step by step procedures.
Step 1.
Step 2.
Step 3.
Remove the red dotted plastic plugs out. So you have wiggle room.
Once removed all the red dots, where the green dots are you can gently lift it past it, and pull it towards the front away from the engine.
Step 4.
Find the white latch and pull it up to the little square:
This you will see if you have pulled to far up, it has to match up with the little white square.
Step 5.
Black Latch, pull it up just the same way for the white latch, but you will need to unscrew the lock screw.
Step 6.
The light bulb port has to be turned clockwise to unscrew, opposite to lock back it in again.
Step 7.
Once done it should like this, and you will need to a flat screw driver to pop the little clips on the side of the holder and replace bulb.
Step 8, put everything back together and you are done.
Nov 09, 2010 | Buick LaCrosse Cars & Trucks
Red dots show up on the black portion of the screen. Any ideas? Thanks, Steve
I had the same red dots in the dark areas and it was driving me nuts. I also have a toshiba 50hp66. Luckily I found out that it's an easy fix. Open up the back of your tv and on the left side you will see two adjustment pots labelled Vsc and Vy. I first marked with a sharpie where the factory defaults were. Then I adjusted down (to the left) the Vy a little and the red spots were gone! My TV looks like new. Hope this helps.
Aug 08, 2010 | Toshiba 50HP66 50 in. Plasma Television
White "press dot" screen
The actual answer is to press the dots, but use a dull plastic tool that fits "within" the dot. Otherwise the width of your finger is too imprecise to calibrate the dots and screen.
Hope you, and others, get this and try it. It works. I just discovered it and did it, successfully after only about 10 presses.
Jul 21, 2010 | Garmin Nuvi 660 GPS Receiver
White dots in plasma tv
The only thing you can try is to adjust the tiny control on the Y board, if you want to try do this. Open the set , set it up so you can watch it with the back off. now looking at the back on the left side you will see a circuit board larger connected to a smalled one or two that go to the screen edge . on the larger board look for a few small controls, mark their positions with a dark sharpy then turn each a little while looking at the dots to see if one makes them better or worse. If one control effects the dots try to center it for the least amount of dots, if no effect is observed when a control is turned return it the original position that you mark before starting. if the dots do not clear either the Y board is bad or the whole scfreen is defective.
gd lk
Eric
Aug 15, 2009 | Televison & Video
White dots all over screen
this seems to be an issue either with your DMD board or with your Digital Video board... turn on the tv and go to the menu if the white dots appear on the menu the issue is with your DMD board but if they don't show on the menu, the issue would most probbaly be with your Digital Video board
Jun 26, 2009 | Samsung HLS4266 TV
Clicking
unplug the power cord first!!!
then...
if you lift up the cover for the keypad, there will be a little hole under the black switch. press the little button like thing and then slide the whole thing forward. unplug the ribbon strips and undo the screws. then open the lid where you photocopy (top one) and undo the screws on the left. then pull the lid upwards so that it comes of. it will take a bit of strength. there will be a screw there, undo it.
this will enable you to lift the whole thing of so that you can get inside. if you look at the glass screen, you will notice that there is a white strip next to it. mark a little dot on the other side of the plastic where the white strip is. the put the glass back on. mark a dot on the main body where the white strip is. lift he screen of and line the light bar with the mark you have drawn.
put it all back together and start it up. hopefully it should work :)
Jun 13, 2009 | HP PSC 2510 All-In-One InkJet Printer
Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television Logo
589 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
