How to get the serial number for sharpdesk AR-275
  • 1,326 Answers
The serial number should be on the back of the copier. Or you can run a 22-6 in service mode
Posted on Sep 15, 2010
Serial number for AR-M207 Sharp Printer Scanner Fax
The sharpdesk ser # is located on the documentation that came with the installation disk.
Dec 29, 2009 | Sharp AR-M207 All-In-One Laser Printer
I can't use my sharpdesk scanners, when i scan it modifies my webcam as scanner.
Unplug all your other USB devices except for the copier, and try it again. You may have to unplug the copier, uninstall the driver, reboot, reinstall the driver, and then plug the USB cable for the copier back in. You should be using the Sharpdesk software package that includes the button manager, otherwise good luck!!
Jul 06, 2009 | Sharp AR-153E Copier
Sharp AR-275 Copier
Hello sir; there have no reset key for maintenence, whenevere PM light on you need to do PM service (such as replace drum developer, drum blade etc.)
May 19, 2009 | Sharp AR-275 Copier
Sharp AR-275 copier with fax module. Need to edit sender ID
push custom or system setting button, push key operator programs on lcd, type in 00000 from number pad, hit fax settings, fax default settings, own name/number set. hit ok button at top when done then CA button to return to main menu.
Mar 04, 2009 | Sharp AR-275 Copier
Sharp copier printer error: PostScrip printing not licensed for t
what is you OS? check you printer drivers. are they properly installed?, what is your connection between your PC to your printer?, AR 275 can be connected thru network, parallel port, and a USB... they have different printer drivers
Feb 01, 2009 | Sharp AR-275 Copier
How to use the scanner sofware?
Here's the link to the user manual for the copier (it says ar122 and ar152 on the front, but it is the same manual, read it as if you had a AR 122E); http://www.tradenet.sharp.co.uk/files/Copier%2CPrinter%2CMFP/AR_Product/AR153EN/AR153EN57.pdf Check this link for basic info on Sharpdesk; http://www.sharpusa.com/products/applications/sharpdesk/1,2693,3-3,00.html If you open sharpdesk, select the help menu there should be "about sharpdesk" at the bottom - this should tell you which version of sharpdesk your office is running. Check this link for the user manuals for most versions of the Sharpdesk program; http://esupport.sharp.at/html/om/index.php?StartRec=0&ListLimit=10&Lang=%&TemplateLang=nl&ProdLine=34&SortOrder=DESC&OrderBy=Title&SearchString= Hope this helps, please ask again if you have any questions :)
Jul 05, 2007 | Sharp AR-153E Copier
1,585 people viewed this question
k24674
