Question about GE Advantium 120 Convection/Microwave Oven
F3 Message and Beeping
My GE Advantium microwave oven started beeping and displaying "F3" in the middle of the night, and now is beeping about every 30-45 seconds. What is the F3 error message and how do you clear or fix it? Thank you.
  • nherringshaw Jan 17, 2009
    My microwave kitchen aid is beeping every hour or so. The keypad does not work. But there are no flashing codes just the time.
  • Anonymous Mar 16, 2014
    MIcrowave started beeping when it hadn't been used since the night before. Display screen showed "F3" and when I tried to clear it, it shut down. Unplugged oven, waited @ 30 seconds, plugged back in and no change. I tried this several times, at one point it did clear code only to go back to F3 when I put a cup of water in the oven and tried to set the time and level to start it. Once I got a 'F10", but it never appeared again. Researching best I could it appears the display panel is shorted. Any ideas? I want to determine if cost of repairs is worthwhile.
  • GE Master
  • 9,098 Answers
On a GE/Hotpoint, F3 means you have a failed keypad.
If you or someone you know might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
It's at http://www.microwavedisplay.com/keypad_replacement.pdf
If you'd rather have us fix it for you, we do that for $39.95 plus parts and you can visit us via our link here on Fixya http://tinyurl.com/yzjozk
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
Posted on May 27, 2008
My GE Advantium microwave is beeping about 5 times every 2 minutes or so. The display says, "Keypanel Shorted. May need service. Press CLEAR to continue." Ironically, I need a working keypanel to press...
check the touch pad or control unit any short circuit in the control unit, other wise any moisture at control unit chec the circuit other wise replace the touch pad.
Jan 28, 2014 | GE Advantium SCA2000B Microwave Oven
The microwave is beeping at intervals and is flashing an F-3 Last night the vent was running full force and the beeping was going on too - I unplugged it but it didn't fix the problem
The error code of F3 on the GE microwave oven indicates a shorted keypanel/keypad.
Most likely the keypad will have to be replaced to fix your problem.
Mar 10, 2011 | GE JVM3670 Microwave Oven
Ge psacemaker microwave oven no working it started with a sensor error and the message change to F3 and beeping. I unplug and plug its still same error.Model JVM1750. What does F3 message stands for?
F3
Key panel (touch pad) shorted This code will occur if a shorted key panel is detected
continuously over 60 seconds. Replace key panel (also called touch
pad).
Dec 19, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
F3 error
So far so good we unplugged the machine took the filters off the bottom let everything dry out over night and it seems to be working I'll update you tomorrow. I think the steam got the control pannel wet.
Jun 24, 2009 | GE Advantium 120 Convection/Microwave Oven
F3 Error Message
the code means this.
F3 Shorted touch pad panel
Good Luck
Dec 29, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Spacemaker beeping loud and f3 message driving us crazy
The error code F3 indicates an oven sensor problem. The oven sensor is most likely the failed part. The oven sensor probe must have the correct resistance readings at specific temperatures. When the electronic range control (ERC) cannot identify the correct resistance of the oven sensor or the resistance is way out of specs F3 will display.
I recommend calling a service technician to diagnose and repair your oven.
Dec 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
F3 Error Message
It needs a new key pad it is shorted the ge website has a list of error codes f3 is the keypad
Jan 31, 2008 | GE Advantium 120 Convection/Microwave Oven
Keeps beeping and shows F3 but keypad not working
Ya what the ????
Not shure what to tell you, first I would see if leaving unplug for a day would solve your problem, to me sound like main board is defective, also try by opening the door a closing it a couple of time, just in cass a switch is jam open.
Regards
bob
Jan 20, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Advantium 120 Convection/Microwave Oven Logo
641 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
