Question about SanDisk 2GB microSD Memory Card
The memory is locked.how to unlock - SanDisk 2GB microSD Memory Card
    Problem Solver:
  • 18 Answers
You got card unlock system in market which has around Rs200.00 price which is run on battery. you insert your memory card into it and switch on it, then a red LED will on, at that time you will not remove your card, which indicate that your card unlocking process is going on. if the card is unlocked , a green LED will light, then you press the swith that below the green LED and remove your card. if you remove your card before pressing the green switch, your card will lost. some times all the data that stored in your card is lost.
Posted on Sep 15, 2010
My memory card is locked am not given lock number how to remove lock 2gb micro
Look closely at the memory card itself. There should be a tiny picture of a lock indicator on the card and a little tab to click or move to the lock position. There should also be a picture of an unlocked lock to signify which direction you need to move that little tab in order to unlock the memory card. Try sliding it to the unlock position to solve your issue.
Sep 12, 2011 | SanDisk 2GB microSD Memory Card
My micro sd card lock how can unlock micro sd card
Locked Memory card.
Note:- Locking of memory card is a RANDOM process.(means it gets locked on its(memory card) "OWN')
1.Whenever a card gets locked,its mainly due to the following reasons.
(I)When you insert it into a uncompatible mode.
(II) when some unsupporte files are placed.
(III)When its for specific mobile.
100% working solution for LOCKED MEMORY CARD is :-
1.Use Unlocker(its like a pendrive device with 9V battery ),and its IC is programmed in such a way that it tests every possile code.
2.The one that sets mades the memory card Unlock.
3.BUT you cant know what the CODE was.
4. Data can NEVER be retraced.
Noye :-Buy an Unlocker available @ Rs.200.But you may not get the same problem often so take it to the retailer it will costaround Rs.20 for unlocking .
Aug 29, 2011 | Nokia 5130 XpressMusic Red Unlocked Import...
My phone memory card is not format and not data deleted
try to see your memory is locked or unlocked.. there will be a switch to lock or unlock. if the memory in locked condition, try to switch to unlocked. maybe that was the problem. hope this useful. regard, riyan
Feb 26, 2011 | SanDisk 2GB microSD Memory Card
The memory was lock. but i want to unlock it
id1102_e3sdhc.gifSOLUTION 1 - Unlock the memory card.
There is a Lock switch on the left side of the SD card. Make sure the Lock switch is slid up (unlock position). You will not be able to modify or delete the contents on the memory card if it is locked.
NOTE: If you are using a microSD/microSDHC card or a miniSD/miniSDHC card, insert the card into the standard SD adapter.
SOLUTION 2 - Toggle the lock switch.
If the lock switch is not on lock:
1. Slide the switch up and down. Repeat this 3 times.
2. Let it stay on the Lock position for 30 seconds.
3. Slide the switch up to unlock the card.
4. Try to transfer files into the device.
Dec 30, 2010 | SanDisk 4GB microSD High Capacity Memory...
My memory card suddenly says locked, why and how do I unlock it
Thanks for using Fixya.
(i) Unlock the memory card.
There is a Lock switch on the left side of the SD card. Make sure the Lock switch is slid up (unlock position). You will not be able to modify or delete the contents on the memory card if it is locked.9632f20.gif
(ii) Toggle the lock switch.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Jun 06, 2010 | SanDisk 1GB microSD Memory Card
Memory card locked
go to settings in your phone look for a button that says memory inside you will get several options depending on your phone it will normally say something like lock memory and unlock memory of course you want to unlock memory.. if this does not work pull your memory card and on the side of the memory card is a very small slider button that says lock and unlock just select unlock and your ready to go.. I hope this has been of some help at the very least it gives you an idea where to look and what to look for
best wishes okcfirewall
Jul 24, 2009 | Nokia N73 Cellular Phone
Unlock memory card
There is a little 'lock' switch on the side on the card with a lock symbol. Slide the switch to the unlocked position to unlock your card!
Aug 06, 2008 | Cell Phones
Memory card locked
I had the same problem - just put the lock button of the card to the lock position and than again to the unlock position
Jul 06, 2008 | Canon PowerShot A450 Digital Camera
Unlock memory card
You can't do it with your phone. You need extra hardware and soft for unlocking mmc.
May 19, 2008 | Nokia N73 Cellular Phone
SanDisk 2GB microSD Memory Card Logo
87 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
