Question about Uniden Cordless Phone
I connected an elite 9035 to charge the handsets but also connect the phone line at the same time which i later realized was not as the instruction manual recommended. i am not able to make (no dialing tone) or recieve calls ( there is a ring tone when calling the phone but no indiction of an incoming call). could this be related? check tel line is a message on the phone. thanks
  • 81 Answers
Unplug your Phone and plug in a regular un-powered phone. If it rings your cordless base station is bad and you will need a new one if it does not ring then there is a problem on your phone line and you need to contact your phone company. Note, the phone company will charge you for repairs inside your house.
Posted on May 04, 2011
How do i get volume on my binatone 3325 handset
Press C/8 to unmute the microphone.
complete installations
Plug the power adapter
& line cord
into the base station.
Plug the power adapter into a 230Vac, 50Hz
mains socket, the other end of the line cord
into your telephone line socket.
Warning: Always use the line cord provided in the box.
Other line cords may not be compatible and may not work.
Warning: Only use the power adapter supplied.
Others will result in non-compliance with the safety
specification EN60950, and will invalidate any approval
given with this apparatus.
Warning: The Base unit needs mains power for
normal operation, not just for charging the handset batteries.
Installing and charging the batteries
Slide open the battery compartment cover.
Place the 2 batteries with the correct polarity,
as shown.
Slide the battery compartment cover back.
Put the handset on the base and charge for
15 hours before first time use. The handset
beeps when charging starts.
Warning: Only use the AAA size NiMH rechargeable
batteries.
If you have a Broadband Line
If you connect your telephone to a line with a broadband connection, you will need to
insert a micro-filter between the telephone and the telephone line, otherwise you may
get interference between the telephone and the broadband, which could cause
problems.
In a home with broadband, every telephone must have a micro-filter connected, not just the one at the telephone point that your modem is connected to.
If you need more broadband micro-filters, contact your broadband provider.
Connection and Conditions for use:
You can connect your phone to a direct exchange line (DEL) on a local
exchange with its own phone number; to an extension socket
connected to a DEL; or to an extension on an approved compatible
PBX. Do not connect as an extension to a payphone.
The ringer equivalence number (REN) of all equipment (phones, fax
machines, modems, etc.) connected to an exchange line must not add
up to more than 4, otherwise one or more of them may not ring and/or
answer calls correctly. This phone has a REN of 1, and most other
telephones have a REN of 1 unless marked otherwise.
Handset - Base Connection
1) When purchased, all handsets are already registered to the base unit
and should link to it when they are all powered up.
2) To use your cordless handset and base unit together, you must be
able to establish a radio link between them. The signal between the
handset and the base is in accordance with the normal standards for
a DECT phone: Maximum range up to 300 metres outdoors or 50
metres indoors. Be aware that:
> Any large metal object, such as a refrigerator, mirror or filing cabinet,
between the handset and the base unit may block the radio signal.
> Other solid structures, like walls, may reduce the signal strength.
> Other electrical equipment may cause interference and/or affect the range.
3) Do not place close to another telephone, a TV or audio equipment - it
may cause interference.
4) Out of Range warning. If you hear a warning tone during a call,
and/or the sound in the earpiece becomes faint or distorted, you may be
going out of range of the base unit, so move nearer to the base unit
within 20 seconds, otherwise the call may be cut off.
Jul 20, 2014 | Lands Phones
I have a Panasonic KX-TG5633. It has worked fine for several years. suddenly one of the handsets no longer syncs to the base. I've followed the instructions to register it to the base, but it refuses to...
I am so tired of all the answers that don't help by repeating standard answers that you already know won't work or giving directions for a totally different product. The fix here is simple but not easy. It's either a bad charging/battery connection, a bad battery or both. Low power will cause the exact problem asked here.
As the phones get older, and I'm specifically talking about Panasonic cordless KX-TG563x but this may be true of other rechargeable devices, the metal contacts for charging and battery do not make a good connection like they used to. They may look perfectly fine and free of corrosion but are not actually making a good connection.
Symptoms include the phone getting hot while charging and not holding a good charge. The phone may show 3 bars of charge but still blank out like the battery is dying. With these Panasonic phones, weak battery will cause the phone to unregister and will give false charge level readings in the display. If your phone gets hot when charging, this is most likely your problem.
I had this problem with several handsets and used contact cleaner on the charge base, the phone contacts, the battery contacts inside the phone and on the battery itself. It fixed all the registration, heating and charging problems. I had one stubborn handset I had to clean multiple times but it's now working like new as well. I used DeoxIt contact cleaner from Caig, bought it on eBay. Great stuff. If repeated cleaning of the contacts with a good contact cleaner does not fix the phone, replace your battery. Use contact cleaner on your new battery for best connection. Ebay is a good source for replacement batteries as
well. Good luck!
Feb 11, 2011 | Panasonic KX-TG5633B Trio Cordless Phone
I have recently purchased a DECT Elite 9035 with an additional handset and can't get the answering system will not record any incoming messages. I have done everything that it says in the instruction...
Uniden Australia has offered to replace the phone free of charge.
I feel that I should not have to pay for support when the phone is only about eight days old.
Dec 28, 2009 | Uniden DECT 6.0 Cordless Telephone...
One 6041 handset will not connect, while the second handset does.
Unplug the entire phone set system from both electrical power and wall jack for approx 2-3 minutes and replug.
It's a reset measure that allows the entire system to reset / reboot as well as stops any and all line feed memory from the live phone line to hold the fault.
Such can be somewhat common when sharing the line with a DSL connection or wireless router is in use.
Jul 27, 2009 | Vtech Cordless 6041 Phone
Line in Use Message on Screen- GE 28213 Series DECT 6.0
to get a line you have to have the handsets in the stands or you have to use the end button to close the call
the phone stands are the battery charger and need the handsets need to there all the time-- unless answering a call --the operation is
all the handsets are in the stands being charged
a phone call comes in by lifting a handset to answer, the call is connected automatically without pressing the talk button
on finishing the call you press end but if you do not replace the handset in the stand but leave it say on the table , when you get another call you have to press the talk button to be connected as it was not picked up from the charger stand and so will not connect automatically when one handset is talking , all the other handsets can listen in and if one call is not ended , there is a line in use sound and no line
it is all in the owners manual and if you didn't get the manual , go google and down load it from the manufacturers web page as a pdf version for printing
Mar 07, 2017 | Uniden Cordless Phone
How to connect additional unit to base unit special code ?
Hello. Here is how you do register your handset below, and a link to the manual its on page 46. The procedure depends on how many handsets you have. If you only had one handset follow the directions below. If you have more than one handset follow the second set.
On the handset push menu, then dial 0 0
On the base, push and hold down the locator/intercom button until the charge light flashes
Press OK on the handset, and it should automatically register in a few seconds.
On the base, press select until you see the intercom number you wish to register it to. Stop there and push the Call button until the charge light flashes
Push OK on the handset, and it should register
Hope this helps
http://service.us.panasonic.com/OPERMANPDF/KXTG5631.PDF
Feb 28, 2009 | Panasonic KX-TG5632 Phone
Handset has message Out of Range even though it is fully charged on on the handset.
The handsets are reading out of range because they have lost connection with the base. This happens mostly during peak power demands or power outages, but can also happen when the phone is unplugged for any amount of time. This can also cause, at times, the answering machine to stop picking up calls. To remedy this issue, reset the phone system. Please follow the instructions below:
To reset the phone:
1. Disconnect the power adapter, phone line, and remove all batteries from the base and all handsets. Leave it disconnected for 30 seconds to reset the base.
2. Place the batteries in the handsets first and then plug in the power adapter and phone line. Do not place the batteries back in the base yet.
3. Put the handset in the charge cradle.
4. It may take up to 1 minute for the "Out of Range" to clear from the display.
5. Once the "Out of Range" is cleared from the handset place the back up batteries back into the base.
Sep 08, 2008 | Motorola Mobility SD4502 Cordless...
UNIDEN ELITE 9035 + 1 (WHITE) CORDLESS PHONE INSTRUCTION MANUAL DOWNLOAD
Try here:
http://www.uniden.co.nz/RESOURCES_MAIN/pdfs/ELITE_9035_OM%20Final.pdf
This is the manual from the Uniden NZ site.
Aug 24, 2008 | Uniden Cordless phone EXS9950
We have had a panasonic KX-A141ALM (two handsets) for about 6 years. Yesterday they suddenly had no dial tone. We checked all plugs & connections, the handsets are charged and we have now changed the...
Hi There, me too. I have the same models. one is on our fax machine and the other is remote. One does not ring, sometimes does not answer, other times it won't ring out. bugged if i know, i'm investing in another handset but am unsure if the later models will pair to the base station............good luck
Jun 09, 2008 | Panasonic Lands Phones
Phone loses connection after few minutes
I looked up the battery specs for your phone. They are 3 X 200mah= 600mah battery packs. They should last 8 hrs talk time with the headsets. This style of battery pack in my experience only last about 1 1/2years and sometimes longer and "sometimes" shorter...much shorter. I bet you never had problems when you first got them. Basicly this "battery design arrangment" goes back many years before newer battery technlogy was developed. But designers still insist on using them even today. They are cheap to make. ****Time to replace them with new ones.**** Make sure you follow the mfgs charging instructions: "After battery installation, place the handsets in their base unit or charger and allow to charge for 16 hours before use. You can keep the battery charged by returning the handsets to their base unit or charger after each use. When the battery is fully depleted, a recharge takes about 12 hours. Average talk time on a fully charged battery is about eight hours depending on environmental conditions, standby time is approximately four days." Good luck
Jul 19, 2007 | AT&T E5640 Phone
Uniden Cordless Phone Logo
159 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
