Question about Comet GXD2527G Pressure Washer Pump
I have a Pressure Washer with a Comet ZWD 4040 Pump. It recently had a new Unloader Valve fitted. It has suddenly developed a problem, the pressure goes up to 3000psi and then drops back to 2000psi. I have tried adjusting the pressure valve up but when I release the trigger the Engine stalls. When the unit unloads the pressure gauge shoots up to 6000psi. Any suggestions what the problem could be and how do I fix it? Thanks. Derek
  • 3,740 Answers
Derek, Hi and welcome to FixYa. I am Kelly.
I just now happened across your post and note it is 3 months old. Hopefully you already have the problem solved.
If not.. looking at the pump history of having the un-loader valve replaced it sure seems that the current un-loader valve is sticking. When an un-loader valve is removed the internal housing is sanded smooth and everything about the un-loader valve is coated with Lubriplate #105 White Grease. I get the feeling that who ever did the un-loader valve repair failed to sand / clean the housing and use White Grease for the final assembly.
You should remove the valve... Sand the housing and get some Lubriplate #105 white grease (auto parts store) in a tube. Lubricate it liberally and reassemble it. If should work fine after that.
Thanks for choosing FixYa,
Kelly
Posted on Dec 07, 2010
Why is it my power washer starts but doesn't develop pressure?
Either a bad pump check valve or bad unloader valve. On customer grade gas power pressure washer pumps it is about the same cost to replace and get a good warranty than repair the current pump.
Mar 19, 2015 | Garden
What grade of oil do i use in the zwd 4040 hi pressure pump
30 weight NON DETERGENT. Autozone and other autoparts stores usually have it. It is often hard to find, so you might have to ask them where they hid it.
Dec 13, 2014 | Comet ZWD 4040 G-K Pressure Washer Pump...
B&E pressure washer w/ comet 3540 pump
Things to check:
1) is water coming out of the bottom of the pump or is the oil in the crankcase high level and milky yellow. If so your seals are bad.
2) Your check valves might not be seating properly. A couple of fouled check vavles will cause either no pressure or pulsing pressure. A good inlet water strainer keeps foreign matter out of valves. But valves do wear out and get build up that keeps them from working right.
3) Your unloader valve might be worn or fouled. Bad unloader would usually show as low pressure ( but more than hose pressure) or low volume out the trigger nozzle.
Valves are your most likely problem.
Feb 17, 2014 | Comet Pressure Washer Hw3540s Triplex Pump...
Comet water oil
You have to take off the pump head. Here is the link to the service for comet pumps.
https://www.pwmall.com/PDF/CometServiceManual.pdf
Nov 03, 2013 | Comet GXD2527G Pressure Washer Pump
Comet axd 3020 will not build pressure
junk axial wobble plate pump. Usually axial pumps are not worth the time to try to fix them. This one has a 5 year warranty , so they think they have a pretty good one. ( I would never buy one) If you want to try to fix it, I would check the check valves first. Take them out and see if some are broken or not sealing properly. There is a valve kit available.
The other likely problem is your unloader valve. If the seal is shot or the valve stuck open the pump will not build pressure.
parts diagram http://www.ppe-pressure-washer-parts.com/files/1961581/uploaded/axd-PUMP%20BREAKDOWN.pdf
Oct 31, 2013 | Comet Garden
My pressure washer stops running when i let off the trigger
hi there sal rick85
sounds like the unloader valve is not working or stuck closed , check the setting of the unloader valve may be set too high, the unloader must open in odrder to cycle water back to inlet side of pump - if not builds up heaps of pressure , stalls the engine - service the un loader valves on the pressure head
take look and let me know - what brand your blaster unit is i know its honda but what pump
comet - axd, lw/zw, - in line or axial cam
in the mean time here is good web site on power washers
http://www.the-power-washer-advisor.com/
or go to
http://www.the-power-washer-advisor.com/pressure-washer-pump-trouble-shooting.html
cheers pauly46
May 30, 2011 | Honda Pressure Washer PSI 3000
Pressure off and on every few seconds with my karcher 3000BH
hi there rjcomer2
here is web site for parts
http://www.ereplacementparts.com/karcher-2500-11944010-pressure-washer-parts-c-33388_33389_33973.html
sounds like you have a unloader valve problem or a crack in the pressure manifold housing between pressure outlet and unloader valve assy allowing unloader to cycle on/ off
or some dirt trapped in the unloader valve seat , make sure you have good supply of water - ie good flow from tap to pump
try cleaning unloader 1st and fitting in line tap filter
hope it helps
pauly46
May 20, 2011 | Karcher 2500 PSI Pressure Washer
I live in the naples fl. area .--where can i get my comet axd 3030 pump rebuilt and what is the cost?
These AXD pumps usually do not require a rebuilding process. What happens is the unloader / bypass valve gets stuck and you do not get any output pressure. What you can do is tip you pressure washer so that the input and output fittings are vertical and actually dump oil into the water supply hole. (3 oz at least) Slowly pull the recoil (ign off) and add a bit more oil and let it sit overnight. Then the next day once again pull the recoil through and let it sit another 10 minutes. Then connect all hoses (Purge the air in the garden hose) BEFORE connecting the main water supply and start the unit then running at MAX SPEED rapidly fan the wand trigger. What your doing is cycling the unloader valve. Do not do this for more than 2 minutes if the pressure does not suddenly start. IF the pressure builds continue at lease another 30 rapid cycles of the wand trigger.
I lost count on just how many pressure washers I have brought back to a good working service life by just doing the above. I do know it is a substantial number.
Give this a try before you go off on the need to rebuild the pump avenue.
Aug 26, 2010 | Honda Pressure Washer PSI 3000
I have a Comet 4040 and oil and water mix is bubbling out of the red cap on top of my pressure washer. Can anyone tell me what repair kit I might need to fix this problem?
Hi this could be the oil and pump seals worn. Also make sure that you don,t have the transit plug in or the pump cannot breath. It should have a air vented dipstick.
May 21, 2010 | Comet GXD2527G Pressure Washer Pump
Comet GXD2527G Pressure Washer Pump Logo
1,054 people viewed this question
Top Comet Garden Experts
michael
michael
Joseph Hoffmann
John Trevino
Are you a Comet Garden Expert? Answer questions, earn points and help others
