Question about Apple iPod MA446LL/A MP3 Player
Can u help me
My ipod took a dip in the washing machine 2 years ago, and i thought it would be perfectly dry by now but when i put it i to the charger or hold the menu button , only the apple sign shows up
- please help me:(
First of all I have the White 30GB, not the Black. My IPOD was in a backpack along with some sunscreen. I heard the spray go off a couple of times in my bag before I realized that it was spraying my IPOD. It stopped working for about a day and then I blew into it. It came back on so I put it on the charger. The next day I took it off the charger to use it and it would never come back on.
  • Lit_Mama Jun 11, 2008
    My ipod 30GB will not come on and i just wanted to know how to take off the back
  • Apple Master
  • 13,433 Answers
Well Basicly if you take the ipod apart, dry it, then place it in a airtight container filled with rise, and leave it in there for 2-4 days, in parts.. that might get it to work again.
Heres a few helpful videos for you. Remember to rate my solution. Thanks
Posted on May 16, 2008
  • Ekse May 16, 2008
    You can find videos on takeing your ipod apart at
    http://www.ipodhowtovideo.com/
  • Ekse Jun 01, 2008
    This thread has gone 7 days or more without a response. Please close the thread with a “FixYa” or “Helpful” rating.
    If the issue is not resolved, please post back with latest developments, what steps you took, etc. and I will assist you further as best I can.
    Thank you.
Put nano in washing machine 2 yrs ago dried out no backlight no movement of songs can only shake shuffle
Dude you are lucky if it atlist plays music. There is no free fix for that.
Mar 22, 2010 | Apple iPod touch
Drums tries to turn but fails.
usually there is a board on the side of the wall of the machine. Check carefully for dry or burned tracks on the board. they either use a relay or possibly a triac etc, Current is fairly high and any bad soldering can create a dry joint. Look for any loose connections leading from the motor to the board. Check the tachometer which normally connects at the bottom end of the motor.Sometimes the magnet comes loose and gives an incorrect signal to the controller. let me know.
Nov 12, 2009 | Hoover PE235 Front Load Washer
Phone Fired
Phone, you need a new one, fatal error, means something inside of your phone is fried. Charger, are you sure the outlet is good for electronics, sometimes the outlet is a dud after a while, even in newer homes, that is a possible problem, or you're getting the wrong charger, sometimes there isn't enough volts, or too many and can ruin yur battery, if you would like the perfect charger, google it, and figure out the perfect charger for your phone.
Sep 17, 2009 | LG RUMOR Cellular Phone
I had go my ipod shuffle 2 days ago and i charger
plug it in, then use itunes to restore your ipod to factory settings. Update it then when you want to put music onto the device drag the music over onto yout playlist/music folder for your ipod, click and drag the song you want to your ipod, do not release your mouse button until you see the +copy appear.
Aug 02, 2009 | Apple iPod shuffle MP3 Player
Dyer LSG7804ABE Gas Stackable very little heat
self help is right .first i would try a load with out the ducting.if you have good air flow and still didn't dry[because now youv'e elimanated the house venting as a possiable.replace your coils
Jan 02, 2009 | Maytag LSE7806A Top Load Stacked...
Ipod went through washing machine
I have a friend who wzs told at verizon to put her daughters cell phone that had been washed into a ziplock bag with dry instant rice for 24 -36 hours and the moisture will be drawn out and the phone would be fine and it woked for that I bet it would for the ipod too
Sep 27, 2008 | Audio Players & Recorders
Low Battery
Dear sir, u need to clean the battery terminals/. Battery chemicals creates an internal circuitary & causes drain of batteryu at faster rate soem times 12 times faster than normal .. , best way to do is
open all screws , then wash the radio with iso-propyle alcohol..& a brush let it dry fully then assemble the same . I hope u will be able to get gud back up time .
REgards
raj
May 24, 2008 | Cobra 22 CHANNEL 2-WAY RADIOS
Can u help me
try this
http://www.fixya.com/support/r561901-ipod_problems_start_5_solutions
the ipod should be taken apart right after it got wet - battery and all parts taken apart and then dryed and placed into a airthigh container filled with rise for 1-4 days.
I'm not sure it might be too late for yours but you can try it.
May 12, 2008 | Apple iPod MA446LL/A MP3 Player
Zanussi WJD1667W not drying at all
I've got this machine, and all washer dryers tend to have two heating elements and it sounds to me that the heating element for the drying side of the machine's functions needs replacing. You could probably find a cheap element for the machine somewhere and get it fitted for a small sum.
Let me know if this rectifies your problem
WD Pro
Apr 24, 2008 | Zanussi WJD1667W Front Load Washer / Dryer
I put my ipod in the washing machine...
hi there
im so sorry for that friend. what you can do is bring that to a service center and hope that the technician can dry and replace the batteries for that and hope that it will still work.
Feb 12, 2008 | Apple Mini IPod
Apple iPod MA446LL/A MP3 Player Logo
48 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
