My laptop cannot connect with my router after I changed the hard disk to a new one
    Scholar:
  • 85 Answers
* Please check the cable between the router and computer.
* Conform with the ISP (internet service provider) whether connectivity is up or not from their end.
* Configuration on the router may do some issue please have a look on this.
Posted on Sep 15, 2010
New hard disk problem
Unplug , remove battery, reseat the HDD, plug in, reboot. Is the HDD new? If no remove and test.
Mar 11, 2013 | Computers & Internet
Iintend to change my sata hard drive to a SSD hard drive.How do I format before change
When you install Windows on your new SSD hard drive you can then transfer data from your old hard drive using an USB hard drive adapter or install the old hard drive into an USB hard drive adapter case and use it as an USB external hard drive after you have transferred your data to your laptop.
When you connect the USB hard drive adapter to the laptop, the laptop will see it as an external storage device, you can then open the various folders anf files and copy them to your new hard disk.
Apr 07, 2012 | Dell Computers & Internet
I have an i mac and windows 7 laptop.......the laptop is brand new and i want to transfer all my music and movies from my mac......can this be done and if so how???!!!!!!!!!!!!!!!!!!!!
> transfer from Mac to PC ... how ?
Several ways:
* use Ethernet cables to connect the network-port on each computer to a "router" (one of those boxes that "splits" your Internet signal, and might provide "wireless" access inside your home), and then enable "file-sharing" on both computers.
Then, the computers can "talk" to each other, via the router.
* write all the files to an external storage device, e.g., USB memory-stick or Western Digital Passport device. Move the device to the other computer, and copy from the device onto the computer.
* "burn" all the files to CD-recordable or DVD-recordable disks.
Move the disks to the new computer.
Oct 29, 2010 | Western Digital Passport 320GB External...
Need to secure router via laptop
Your laptop must be a wireless computer. You want to secure the wireless network.
You will need to change the settings on the router.
First you will need to connect the computer to the router with the cable. Do you have any computer connected to the router ?
If not then connect the laptop to the router. Open the set up page of the router and change the wireless security settings of the network. Change the wireless network name also.
Click here for more information about the router and internet
Mar 27, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
We formerly used a linskys router, How can we
if you have not changed any settings from belkin router, access the wireless configuration on your windows machine and search for the belkin ssid then hit on connect
Sep 23, 2009 | Belkin N1 Wireless USB 2.0 Network Adapter...
External disk is not been detected
Check the BIOS setting, make sure the hard disk is set to Auto (detect) or change the settings to default settings (your BOS may not have this option) then save and reboot laptop.
If the hard disk has not been detected and/or Unable to find the operating system, it means you may have a faulty hard disk or a faulty hard disk controller or the hard disk may not be making proper electrical connection.
To reseat the hard drive, remove the hard drive and reinsert it into the laptop a few times and see if it boots up..
If it still does not see the hard drive then the fault is probably the hard disk. To test if the hard disk is faulty, remove the hard disk and insert it into a hard drive USB adapter and connect it into the USB port of a working computer. If you don't see this drive as an external drive then you will know its faulty. Then you will need to purchase a hard drive, insert it into your laptop then install the Windows operating system and all your device drivers and programs to get your laptop operational again.
If the hard drive is OK the the fault is with the disk controller, and it is near impossible/expensive to repair the motherboard. Put your money towards a new laptop and put the hard disk into a USB hard disk adapter case and use it as as a portable external hard drive.
Best of luck.
Dec 12, 2008 | Toshiba Satellite M45-S351 Notebook
Dell Latitude D600 with new Hitachi 30GB Drive Not Recognizing
XP install is not detecting any hard disk.
No jumpers are required for laptops, can only have one hard drive in a laptop.
Check the BIOS for the hard disk configuration, make sure that it is set on Auto (detect).
You may have a faulty hard disk, you can check it by booting up with a floppy DOS boot disk, run fdisk to see if it detects the hard disk, OR connect this hard drive to a USB hard disk adapter and connect it to a working computer's USB port and if it detects it as an external drive the it is OK.
Nov 30, 2008 | Dell Latitude D600 Notebook
Routers
You may simply have incompatibility issues, there now where near as problimatic as they used too but still exists. First off make sure that when you try to connect that you have the right security settings, (if used the disk from the router or had somebody install it you should have written it down). When configuring your router always do it with a hard wire connected so as you don't drop yourself every time you change a wireless setting.
Take your laptop to a free wifi hotspot as way to make sure that your wireless card actually works. But if you can see your network it sounds more like a security setting issue.
Feb 07, 2008 | Buffalo Technology (WYR-G54) Router
My wireless router wont work
Run a cat5 cable from the laptop to a cat5 port on the router, open internet explorer in the address window type http://192.168.1.1 or what ever the IP address of the router once you have accessed the router create your PPPOE internet connection, enter your Internet Service Provider's username and password. Once you have done this, disconnect the cat5 cable and connect wirelessly to the router from the laptop. If all this fails press and hold the reset button on the back of the router for 10-15 seconds this will reset the router to factory defaults. connect to the wireless router and create the PPPOE connection. BPCS
Dec 29, 2007 | D-Link DI-634M Wireless Router (DI634M)
New Laptop Connection
Try each of these suggestions 1. username admin, password 1234, 2. username leave blank, password admin BPCS
Dec 28, 2007 | Linksys Wireless-G Broadband Router
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
