Question about Canon Cameras
The flash on our Canon Powershot A530 isn't working.
  • Canon Master
  • 4,738 Answers
Many cameras have a safety feature that prevents the flash capacitor from charging if the case is opened. They usually use a couple of the screws along the perimeter of the camera to complete a circuit that lets the processor know that the case is closed. Verify that all the screws are in place along the perimeter of the camera. If missing a screw, try using one of the others to replace it.
If they're all there, next thing to check is the batteries. The brand you're using may have reached its shelf life, and thus may not have sufficient power to charge the flash capacitor. Try a better brand.
If better batteries don't help, then the flash tube or its circuit is probably at fault. This is difficult to replace, requires some soldering, and goes beyond what I can describe here.
Posted on May 18, 2008
I leave tomorrow HELP I have a Canon Powershot A530 and when I put in an 4GM memory card I get Memory Card Error
The A530 is designed to work with SD cards. Your 4GB card is actually an SDHC card. While it will fit into the slot, it won't work there. You need to go with SD cards 2GB and smaller.
Sep 28, 2010 | Canon PowerShot A530 Digital Camera
How do i turn off the flash on my Canon PowerShot A530
Press cursor-up on the round cursor pad (marked with a lightning bolt) to change the flash modes. To turn the flash off, select the lightning bolt in a circle with a slash through it.
Sep 14, 2010 | Canon PowerShot A530 Digital Camera
Can I get a free manual for my digital camera: Canon PowerShot A530 ?
You can get the user manual for this camera from this link, click HERE
Or you can also get it from this LINK
Aug 27, 2010 | Cameras
CANON POWERSHOT A530 LOW BATTERY READING
Alicia,
Mentioned on my blog that the last paragraph of the advisory states:
""PowerShot A530 and A540 digital cameras affected by this phenomenon will be repaired free of charge, regardless of warranty status. Accordingly, if the opening/closing spring on the inside of the battery cover of your PowerShot A530 or A540 digital camera sticks out, please do not use the camera. Instead, please contact a Canon call center (1-800-OK-CANON) at your earliest convenience."
But also mentioned that if they don't help, a temporary fix is to insulate the spring from the battery contact plate. Merely place a small piece of tape between the portion of spring that's sticking out and the metal battery contact plate.
Sep 09, 2008 | Canon PowerShot A530 Digital Camera
Camera Powershot A530 won't flash
EZ Fix for non working flash on Canon A530:
Remove batteries
Remove memory card
Remove date/time battery (tiny door next to battery hole)
Wait a minute.
Replace the items
Rest the date/time
Shoot!
Dec 12, 2007 | Canon PowerShot A530 Digital Camera
My flash won't work!!!
Check to make sure your camera's not on the A530 recall advisory list. Maybe the flash capacitor isn't getting enough power due to the shorting described in the advisory?:
http://camerarepair.blogspot.com/2007/12/canon-a530-a540-with-short-battery-life.html
Sep 28, 2007 | Canon PowerShot A530 Digital Camera
Problems with the battery and the flash on my canon powershot A530
Hi, On another brand/model of a digicam, a similar problem was fixed by cleaning the battery terminals/contacts. The ends of the terminals that pushes on the battery were partially corroded hence the batteries were not getting full contact. They were cleaned by scraping off the corrosion and applying a strong solvent using cotton buds. Further, they were bend a little to add more pressure to the batteries. If the above does not work, it is possible that the flash charging circuitry is defective and drawing much power than it should normally be. Try operating the digicam with the flash off. If this likewise is a "no joy", perhaps your camera would need the services of a qualified professional. Hope this be of some idea/help. Post back how things turn up or should you need further information. Good luck and kind regards.
Sep 16, 2007 | Canon PowerShot A530 Digital Camera
Canon a530 powershot won't snap a picture
sounds like the flash isn't charging, as the flash icon flashes while the flash is charging before letting you take the photo. Put it in "P" and disable the flash and see if it'll let you take a photo. G>
Sep 03, 2007 | Canon PowerShot A530 Digital Camera
Cameras Logo
159 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
