Question about Toshiba Satellite M45-S265 Notebook
System not booting, DVD/CD drive not working. How do i boot from external USB CD drive. The setup did not show USB in the bios, it has CD ROM LAN FDD and HDD but not USB. I am wondering is this is possible at all Raghu
  • 4 Answers
Newer models come with a boot mode using usb memory, older ones might have none... try updating your bios.
Posted on Sep 15, 2010
How do I unlock the Bios on an Acer ES-1 111M Laptop
To boot from a CD, DVD or USB device, make sure that the device has boot sequence priority over the hard drive.
BIOS Boot
BIOS (Basic Input Output Subsystem) is a programmable chip that controls how information is passed to various devices in the computer system. A typical method to access the BIOS settings screen is to press ESC, F1, F2, F8 or F10 during the boot sequence.
BIOS settings allow you to run a boot sequence from a floppy drive, a hard drive, a CD-ROM drive or an external device. You may configure the order that your computer searches these physical devices for the boot sequence.
The first device in the order list has the first boot priority. For example, to boot from a CD-ROM drive instead of a hard drive, place the CD-ROM drive ahead of the hard drive in priority.
Before you set boot priority for a USB device, plug the device into a USB port.
To specify the boot sequence:
  1. Start the computer and press ESC, F1, F2, F8 or F10 during the initial startup screen. Depending on the BIOS manufacturer, a menu may appear.
  2. Choose to enter BIOS setup. The BIOS setup utility page appears.
  3. Use the arrow keys to select the BOOT tab. System devices appear in order of priority.
  4. To give a CD or DVD drive boot sequence priority over the hard drive, move it to the first position in the list.
  5. To give a USB device boot sequence priority over the hard drive, do the following:
    • Move the hard drive device to the top of the boot sequence list.
    • Expand the hard drive device to display all hard drives.
    • Move the USB device to the top of the list of hard drives.
  6. Save and exit the BIOS setup utility.
  7. The computer will restart with the changed settings.
Boot Priority Options
Some computer manufacturers allow you to select the device that contains the boot sequence from a special device selection menu. The example below uses a Dell system board.
To set boot priority using a device selection menu:
  1. When the computer starts to boot up, after the manufacturer's ID screen, press F12 several times. The device selection menu appears.
  2. Use the up and down arrows to select CD-ROM or
May 04, 2015 | Acer Aspire Computers & Internet
I have a old Toshiba Portege 7100that i am trying to boot from a usb hardrive. When i start the computer up it says starting.Then 2 seconds later it says insert system drive and press any button to boot....
this model is too old to boot from a usb version1
maybe you can flash the bios to upgrade usb1 to usb version 2
or, load the ubuntu linux operating system using a CD
Sep 30, 2013 | Toshiba Portege 7100 Notebook
Hi, I'm installing widows xp in HP Compaq nc6220, but after setup loading files the mesaage (bottom of setup screen) "Setup is starting windows", then it did'nt contiue the installation,...
1 many times the the CD cant load as the files in the CD are corrupt or the CD is not read by the drive corectly...so get a new WinXP CD
2 try an external CD drive if your BIOS alows to boot from USB drive....(connect the external CD drive to the USB and make necessary changes to the BIOS boot seq in the BIOS screen...
BIOS screen can be enabled by pressing the F1, or F2 or the Del key as on as you start the PC
3 once in BIOS screen look for boot seq and change the boot drive to the foll
1st boot device - USB CD / DVD rom drive
2nd boot device - internal CD rom drive
and so on
if you can do the above then try the WinXP installation using the external CD rom drive....
else there is a little complicated method of using a pen drive thru USB (will discuss that later) provided your BIOS alows booting from USB
for more PC related issues visit my website
reg
kris
suresh_krishnan1961@yahoo.com
www.sureshayyar.110mb.com
May 18, 2011 | HP Compaq nc6220 Notebook
Usb dvd writer can install xp?
Yes you can use a usb external cd/dvd-rom to any operating system as long as the bios allows you to, most bios's have the capability.
When the external usb drive has been connected power up the mechine, in post it should tell what to press to enter your boot menu without entering your bios and choose usb drive to boot.
Jan 22, 2010 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
How to configure theh bios to boot to cd
when u power up the computer press "del" or F2 to enter in bios
then go t o boot option set first boot device as dvd drive then presss F10 then save all settings then it boot with dvd or cd
May 22, 2009 | Computers & Internet
Satellite A20---is it possible to boot from external burner
you can try to install throu USB Drive. Search google there are many tricks how to bootup with your Pen Drive.
Feb 27, 2009 | Computers & Internet
Want to Boot from dvd ROM
when the pc in post usually on dells bios there is a boot menu option it is usually f12
if you don't know what your doing in the bios it is not a good place to test your skills after pressing F12 just choose cd rom for boot
Jan 28, 2009 | Dell OptiPlex GX280 PC Desktop
I can't boot from external usb dvd/cd drive
please try to remove the connection between motherboard and vd/dvd drive.
then perform the previous steps.
Jan 27, 2009 | HP Compaq Evo Notebook N1020v PC Notebook
Toshiba a205 laptop wont boot
try to boot the windows from external DVD or CD ROM on USB if you have acces to your BIOS set the bios to boot from USB. i think your CD/DVD rom is not working properly, or is no booting from it bios is not setup corectly.
Jan 17, 2009 | Toshiba Computers & Internet
Open Questions:
See all Toshiba Satellite M45-S265 Notebook Questions
Toshiba Satellite M45-S265 Notebook Logo
746 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
