Question about Brother DCP 165C Compact Color Inkjet Multifunction Printer
Genuine Brother Cartridge - Black - Not printing. Believe printer needs a jet clean but cannot access the test function
    President:
  • 1,961 Answers
I should ask if you are now using a new cartridge? or just using a refilled cartridge?
If you are using a refilled cartridge then the nozzle and the print head is already clogged. That is very common to all printers. Test or cleaning from printer utilities may not be enough to do this because it is physically clogged.
To check...remove the cartridge and place the printhead on a piece of tissue. To see whether the ink is passing thru the printhead. If markings where not proportion then its really clogged
Remove the cartridge from the printer. Dipped the nozzle or printhead section of the cartridge to a mixture of ammonia and water. Leave it soak for at least two hours. Warm water is necessary. You can also place the printhead directly from a running water and rinse it with distilled water to remove residue from the tap water.
After the procedure. place the printhead on the tissue again and see the markings left by the ink.
Please post back after this procedure so I could know whether to give you more advance solution.
Please give this solution a ratings if this first instruction was helpful.
Thank you for using Fixya.
Alp
Posted on Sep 15, 2010
Brother MFC-290c printer does not print black anymore. Test print page color ok but not black printing. What is the problem?
The problem is either:
* out of BLACK ink -- replace the ink-cartridge
* clogged ink-jets -- the ink is not spraying onto the paper, so run a few print-head-cleaning cycles
* dead electronics -- not triggering the jets to spray ink, so replace the printer
Feb 20, 2011 | Brother MFC-290C Multifunction Color...
I have put a new black cartridge in printer but nothing is printing out- when I run a test the color cartirdge are working but not black
Hmmm, make sure it is properly fitting in there.... Take it out and put it back in.... Usually the printer performs some kind of "preparing the ink" operation... SO allow it to does this...... Make sure you are using genuine ink, sometimes printers won't accept non-genuine inks.... Hope this helps :)
Jan 08, 2011 | Brother MFC 490cw Color Inkjet...
I have not used my printer for a while because I was out of ink. Recently I replaced the cartridges but the printer does not print. I has been cleaned several times but with no success. Please help.
Did you use genuine Brother ink jet cartridges as recommended by the manufacturer?
Also, did you use compressed air to clean the contacts at the cartridge when removed to make sure the contacts are free of debris or dust?
Dec 18, 2010 | Brother Multi-Function Center MFC-240C...
Black not printing
Canon Bubble Jet i560 Ink Jet Printer not printing black
Aug 01, 2010 | Canon BubbleJet i560 InkJet Printer
My Brother LC61 Series printer does not print - printer is less than 1-yr. I purchased new ink cartridge a couple days ago, however, all of a sudden, the printer will not print.
1st question that should be asked, is was it a genuine Brother approved cartridge with the right value of filtered ink?
If not then the jets will be possibly clogged.
if you return it for repair to brother under warranty, make sure its fitted with genuine cartridges otherwise warranty is void
please rate my help++++thanks for using fixya
Apr 16, 2010 | Brother MFC-290C Printer
Black is not working in my brother mfc-240c printer
did you use genunie brother black ink cartridge?
ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
I located a page on http://www.fixyourownprinter.com forum, which had plenty of details about similar issues.
Try the forum, there are alot of issues like yours.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Apr 06, 2010 | Brother MFC 240C All-In-One InkJet Printer
In print test, seems some nozzels of the black print head are clogged. how can I clean them? I understand the ink cartridge and the print head are seperate. so how to get and disassembled the head and with...
You need to dissasembly the hole printer to take out the print head.In case you wish to do this don't use alcohol. Use hot water or some degreaser.
Principle from Brother claim in genuine cartridge have a unclogged preparation.If you don't use a genuine cartridge buy one black, put it on printer, start cleaning and wait for one day.The nozzle will unclogged, but this is not 100% sure.
Oct 19, 2009 | Brother MFC-5440CN All-In-One InkJet...
I replaced the black ink cartridge, Innobella, LC61Bk, all correct, for the first time in my MFC-990CW Brother fax, etc.times 3!!!! And I get "white" lines through the text. Yes, I have gone throught the...
i HAVE A lc61 SERIES BROTHER INNOBELLA AND I AM NOT ABLE TO PRINT. wHEN I TEST THE PRINTING I GET ALL COLORS BUT BLACK ON THE TRIAL DEMO I TRIED CLEANING BUT IT STILL DOES NOT WORK WHAT CAN I DO???
Oct 16, 2009 | Brother MFC-990CW COLOR INK-JET MFC Ink...
I Need to Print
Sadly in a word, 'No'.
Here is the exact answer from Brother:
Your Brother machine is designed to stop ALL printing operations
(printing from the pc, printing received faxes and printing copies or reports) when any of the ink cartridges are empty. This is to ensure the life of the print head and maintain premium print quality. If the unit were to continue printing, print jobs and cleaning cycles would suction air from the dry cartridge and damage the printhead. Even if you print in black only or change the print settings to MONO or GRAYSCALE to avoid printing in color, the programmed cleaning cycles would still suction the dry cartridge, because they are programmed to clean ALL the ink nozzles.
The only way to continue printing is to replace the empty ink cartridge or cartridges.
While memory is available, black and white faxes will continue to be received into memory. If a color fax is being received, the Brother machines HANDSHAKE will request the fax be sent as black and white fax.
All faxes received into memory will automatically print once the ink cartridge is replaced.
NOTE: Brother strongly recommends that customers do not use generic ink or refill their Brother ink cartridges. Using non-Brother supplies may affect the hardware performance, print quality and machine reliability since the ink formulation in genuine Brother ink cartridges prevent smearing and clogging of the print head. The Brother limited warranty does not apply to any problem that was caused by the use of unauthorized third party ink and/or cartridges.
Nov 26, 2008 | Brother Multi-Function Center MFC-240C...
Brother DCP 165C Compact Color Inkjet Multifunction Printer Logo
69 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
