Question about Dell Dimension 2350 PC Desktop
Want to kow how much ram I can add and where to buy it.
I have a Dell Dimension 2350 CPU and currently has 128 MB. I just re image the system and still runs pretty slow. How much ram can I add to the existing 128 MB already in place to run faster? What is a good site to purchase ram, please?
Thanks
Karina
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 156 Answers
Hi
Dimension 2350 Series has two memory connectors and supports non-ECC PC2100 (266-MHz) DDR SDRAM memory modules. Supported memory capacities are 128, 256, or 512MB. The maximum (total) memory is 1GB.
Regarding where you could buy? I suppose you can check you local PC store. There is always eBay if you fancy.
Mike
Posted on May 19, 2008
Hello i bought some pc2100 ddr ram 512 mb for my dell 2350 but when put the ram in it beeps and wont boot up it came with 256mb ddr sdram can anyone tell me if this is the right ram and if so why wont it...
The best thing to do when it comes to computer ram, and replacing it, is to take the stock (the working ram that came with the PC) ram out and take it with you to a local computer store to ensure that you're getting the right kind of ram.
Your PC can be VERY picky when it comes to computer memory, so don't guess what's right for it.
Hope this helps. :)
Oct 06, 2010 | Dell Dimension 2350 PC Desktop
My system says, (RAM) radon access memory low cpu intel (r) pentium 4 cpu, version 2.80 ghz. RAM 256 mb. What can I do to resolve this problem. Dell 4700 dimension
Windows XP requires a "bare-minimum" of 128MB of RAM, works "OK" with your 256MB of RAM, if you don't open too many programs at the same time, and if you close/re-open Internet Explorer about once an hour of usage.
But, Windows XP would be _much_ "happier" if you added 256MB or 512MB of RAM, because it is telling you ("available random access memory is low") that it is using all the RAM.
Add more RAM -- your computer will run much better.
Jun 15, 2010 | Dell Dimension 4700 PC Desktop
Hardware upgrade required for autocad 2009
Your existing CPU will not work with that motherboard. The AM2+/AM2 processor slot is for AMD processors only. For this motherboard, you will need one of the following processors: Phenom FX / Phenom / Athlon 64 FX / Athlon 64 X2
Jul 06, 2009 | Dell Dimension 8250 PC Desktop
Dell dimension 2350 shuts off after a few minutes
Definitely check the power supply fan and the CPU fan for dust. Overheating could be the culprit, good luck.
Mar 18, 2009 | Dell Dimension 2350 PC Desktop
Dell Demension 4600 motherboard memory
From the Dell specifications page for Dimension 4600:
Memory
Architecture
Dual Channel DDR SDRAM
Memory connectors
Four
Memory capacities
128-, 256-, 512-MB or 1-GB
Minimum memory
128-MB DDR SDRAM
NOTE: Between 32 and 64 MB of system memory may be allocated to support graphics, depending on system memory size and other factors.
Maximum memory
4 GB
Memory type
PC2700 (333-MHz) or PC3200 (400-MHz) DDR SDRAM
(non-ECC)
Mar 09, 2009 | Dell (2336V) Motherboard
RAM
You may have bad or incompatible Ram . Verify that the memory you have is compatible. .
Machine name: Dell Dimension 3000
CPU options: Intel Pentium 4 or Intel Celeron
Chipset: Intel 865GV Chipset
HD Bus: Ultra ATA/100
Front Side Bus options: 800MHz FSB
Memory Speed options: PC3200 DDR400 184pin SDRAM DIMM
Special notes: The Dimension 3000 has two different bus speeds each of which takes different memory. You cannot mix the speeds.
Take the memory out and install one at a time. This way you can verify that the memory is indeed working. If you find a bad one, replace it.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 01, 2009 | Dell Dimension 3000 PC Desktop
Total newbie here - how do I add more memory to my DELL Dimension 2300? I have my cpu open and i am replacing my fan also.
Well your Dell 2300 has a total max. memory of 1 GB from both slot.
If you already have (2) 512MB RAM in the slot then thats the max it can handle.
Dell 2300 only has 2 memory slots. Memory comes in 1- 128MB, 256MB and 512MB PC-133 DIMM modules. So if you want to max it out get (2) 512 MB PC-133 DIMM.
Note:
You must wear a static strap or ground yourself first on the computer chassis before you touch any thing inside your computer
to discharge any static electricity
For further instruction check this out:
http://support.dell.com/support/edocs/systems/dim2300/replace.htm#1101964
Jan 11, 2009 | Dell Dimension 2350 PC Desktop
Which RAM to use for Soltek SL-75DRV/-v
Leif: The difference in the numbers (2700 versus 3200) is speed rating-- basically, the higher the number the faster the RAM. Your computer is currently using 2700, so it's safe to use 3200, it's just faster than is currently used/specified.
Your computer is a Socket A - AMD Via-based board, so it is likely the motherboard will accept 1 GB memory modules. With three slots open, you would want to buy 2, 1-GB modules for best results. At current pricing, that would cost about $100. 2- 512MB modules would be next-best and around $55. Be sure to place the two modules in the slots next to each other, and closest to the processor for best results.
Nov 22, 2007 | Dell Dimension 3100 PC Desktop
Dell Dimension 2350 PC Desktop Logo
118 people viewed this question
Alun Cox
