Question about Saeco INCANTO DELUXE Espresso Machine
The level float sinks to the bottom and it indicates it's out of water but it is , I have the incanto deluxe, what can i do to fix it or can i get a new one
  • 1,618 Answers
You can get a new float from servicesunlimited or wholelattelove, I think there is a hole in the one that you have and it ges fill with water and sinks.
Posted on Sep 15, 2010
Testimonial: "thanks for that"
  • grasso33426 Sep 16, 2010
    I will see if I am still under warranty hopefully Saeco can get me otherwise I will purchase one. thanks .
I have a Saeco Incanto classic, the low water light is on, tank is full, and I have steam coming from the steam wand.
try descaling the machine it could be that the water level switch is clogged with water calcium and not lifting when water is added, or it is defective and needs replacement. I hope this was helpful.
Oct 22, 2014 | Saeco Incanto Classic Espresso Machine
Water light not going out, even when full. Not able to make coffee
the water tank has a float inside, the float has a magnet. the machine senses the position of the magnet and indicates water ok/not. sometimes the magnet rusts inside the plastic casing, renders it less magnetic so it wont work. or the float is missing- fell out while you were cleaning the tank. you will need a new magnetic float to fix the problem.
Feb 11, 2014 | Saeco Incanto Classic Espresso Machine
My Saeco Incanto Deluxe keeps giving a message "Fill Water tank" even though the water tank is full. Does not allow me to choose any other options. Please Help.
Your machine has a magnet that floats in the water tank. If the magnet is not floating when you have water in the tank then you need to replace the magnet. You can also try to clean the magnet before replacing. It may be dirty and tends to stick to the water tank.
This is what it looks like.
May 15, 2011 | Saeco Vienna De Luxe Espresso Machine
I purchased this machine only 2 days ago and it permanently displays the 'fill watertank' message. I've tried filling and refilling the tank and turning the unit off...some advice would be very helpful1
In the water tank there is a float with magnet inside. When water is filled it should rise up to indicate the machine has water.If it is not floating up ,try putting some foam underneath to raise up.It should help.
Oct 18, 2010 | Saeco INCANTO DELUXE Espresso Machine
I have saeco incanto deluxe coffee machine,ventilate msg appears
Check the end of the steam nozzle, make sure it is not blocked. If not then with the knob open for hot water cycle push in on the knob if that works then the tap rod assemble or the steam valve needs to be replaced.
Feb 20, 2010 | Saeco INCANTO DELUXE Espresso Machine
Water is full, but red water light is on and coffee wont come out
Try lifting the water tank and make sure it is pressed along the back of the machine when you put it back in.
Sep 28, 2009 | Saeco Incanto Classic Espresso Machine
The Sensor Magnet for water tank does not float to the top
OK, first of all, I do not recommend my solution if you are forgetful or do not check your water level manually daily.
However, I found a super easy solution.
The way the unit works is to use a float in the water chamber with a magnet on the bottom. When their is enough water in the tank, the float rises and the magnet on the bottom floats to the top of the magnet chamber. When it floats up, it aligns with a sensor in the machine that allows the machine to operate. When the the water level lowers, so does the magnet and drops below the internal sensor disabling the machine with a "Fill Water Tank" error message.
To eliminate this error and allow the machine to operate, I simply popped off the lid to the magnet chamber with a butter knife and turned the water chamber up side down to let the magnet float fall out. Remember to empty the water first.
Here comes the highly technical part. Turn the magnet float upside down and slide it back into the float chamber. Since the actual magnet is on the bottom of the float it now is at the top allowing the internal sensor to turn off. No more error message!
The reason I do recommend this is because this completely defeats the purpose of the sensor and will most likely damage your machine if you run it without water. Keep you tank filled however and you will eliminate the frustration of a "float gone bad" keeping you from your morning caffeine.
Apr 08, 2009 | Saeco Incanto Classic Espresso Machine
Water tank level indicator sinks to the bottom when water tank is full.
I think the float is up and down, try to take it out and turn it.
Look at the float in the other tank to see if it is same position, the rounded side should be down.
Let me know if you get it to work.
Best regards
Sep 04, 2008 | Saeco Royal Cappuccino Espresso Machine
Saeco INCANTO DELUXE Espresso Machine Logo
158 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
