Question about Zyxel NWA-3160 - Wireless access point - 802.11b, 802.11a, 802.11g
I have a new Zyxell NWA-3160 used as a standalone AP at home. I used the web configurator to change th password, the SSID name and to switch to WPA-PSK security configuration. The IP address and the subnet mask are unchanged 192.168.1.2 and 255.255.255.0. My computer has the following network address: 89.43.40.18 / 255.255.255.224 / 89.43.40.1. The computer is connecting fine to the network, Internet is present but, after few minutes the connection is lost and I cannot reconnect unless I switch off and on the AP. In the same time my iphone 3GS cannot join the network. Would you like to give me some hints about this failure. Best regards, Cezar Pricop
  • Zyxel Master
  • 2,782 Answers
Hey CESARP,
I don't want to ALARM YOU but you just
BROADCASTED all your personal security
information
on a GLOBAL SITE...
Enough for a mediocre HACKER to invade your home.
I would TAKE IT all DOWN...
and use the technical support numbers
on your routers OWNERS MANUAL.
SERIOUSLY... Be alarmed.
Carnac the Magnificent
Posted on Apr 04, 2017
How do i change my router name
First you have to access the router through web browser (Internet Explorer) by typing the IP address of your router in the address bar, which is usually 192.168.1.1 (also written at the back of the router)
Then, press Enter. A login screen will appear. Leave the User name field blank. The
first time you open the Web-based utility, use the default password admin. (You can set a new password from the Administration tab's Management screen.) Click OK to continue
and lookup for the options to do the following (under Basic Setup): -
1. Change the SSID (Name) of the router
2. Change the default administrative user name and password (unless you've configured otherwise, the default username is admin and the password admin or password.)
The SSID is the network name shared among all points in a wireless network. The SSID must be identical for all devices in the wireless network. It is case-sensitive and must not exceed 32 characters (use any of the characters on the keyboard). Make sure this setting is the same for all points in your wireless network. For added security, you should change the default SSID (linksys) to a unique name. Below is the snapshot of the required option
(The above step would prevent unauthorized access to your router)
You may wish to refer to the Linksys WRT160N User Guide
(Page 7 Login details, Page 13 Router Name)
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 23, 2011 | Linksys WRT160N Wireless Router
How to configure the ap in mac os
First, make sure you disable the proxy if you`re using one, then open up your web browser and type in this address: 192.168.0.50. A login dialog will show up. The username:admin , left the password empty. Log in, and from there you can configure your AP. Good luck
Mar 16, 2011 | D-Link AirPremier DWL-3200AP 802.11g/b...
How do I set up the password to my Dlink wireless router
Set Up a D-Link Wireless Router
  • 1 Plug one end of the Ethernet cable into the DSL modem.
  • 2 Then plug the other end into the "WAN" port on the back of the D-Link wireless router.
  • 3 Connect wired computers to any of the other Ethernet ports on the router using another Ethernet cable.
  • Access the D-Link Configuration Screen
  • 1 Open your web interface and type "http://192.168.0.1" into the address bar, then hit "Enter" or "Return."
  • 2 Use "Admin" as the username and leave the password blank when the login screen appears.
  • 3 Click "OK." You should now see the D-Link configuration screen.
  • Set Up General Security
  • 1 Change your administrative password by clicking on the "Tools" tab and choosing the "Admin" button. Enter a new password under the "Administrator" heading. Confirm it, and click "Apply."
  • 2 Disable the wireless Local Area Network (LAN) if you don't need to use the wireless access and you want to make sure no one else is able to access your network.
  • 3 Under the "Home" tab, choose "Wireless" and select the "Off" option.
  • Enable Wireless Encryption Protocol (WEP)
  • 1 Locate the "Home" tab in the D-Link Configuration screen, and click on the "Wireless" button.
  • 2 Use the "Open System" button beside "Authentication."
  • 3 Select the "Enabled" button next to "WEP," and set the encryption key to "128 bit."
  • 4 Set the "Key Type" to "ASCII" and choose a 13-digit password for the "Key 1" field.
  • 5 Write down the password in a secure location.
  • 6 Click "Apply."
  • Change the SSID
  • 1 Change the SSID to make it more difficult for others to locate and use your network by clicking on the "Home" tab and locating the "Wireless" button.
  • 2 Change the default SSID to one of your choosing, then click "Apply."
  • 3 Disable SSID broadcasting. Under the "Advanced" tab, click on "Performance" and check off the "Disabled" box. Again, click "Apply."
  • Filter MAC Addresses
  • 1 Click the "Advanced" tab in the D-Link "Configuration" screen and select the "Filters" button.
  • 2 Choose the "MAC Filters" and click on "Only Allow Computers with MAC Address Listed Below to Connect to the Network."
  • 3
  • Enter the name and MAC address of the computers allowed to access the network, beginning with the one you are currently configuring. Click "Apply."
  • Dec 28, 2010 | Computers & Internet
    Ip address wrong, showing 192.168.254.1
    Solution Overview
    This article explains how you can avoid having to run the Wireless Configuration Utility or Wireless Setup Assistant (Macintosh) after making changes to the router's security settings. The need to change these settings can arise if users forget their network key/passphrase or router web server password or if you have security concerns.
    Printer response to security settings changes
    The printer will respond with a flashing orange (pattlnk_6172008_1844-orgblksml.gif) Wi-Fi indicator light after the following actions are performed on the network or router/access point (AP):
    • -A change to the Service Set Identifier (SSID) or network name.
    • -A change to the security type (none, WEP, WPA, or WPA2 personal).
    • -A change to the security network key/passphrase.
    • -A hard reset of the router followed by entry of security values that are different from the original values.
    • -The printer is moved to a network (AP) that has different security values but already has installed drivers and created ports. NOTE: Port reconfiguration may be required in this case. Click here for instructions.
    In order to rejoin (associate and authenticate) the wireless network (WLAN), the wireless client (printer) has to be reconfigured with the router's new SSID, security type, and network key. This requires connecting the USB configuration cable to the host computer and running the Wireless Configuration Utility or Wireless Setup Assistant to apply the new security settings on the printer's wireless network adapter.
    Solution: Change the printer settings first
    Change the security settings on the printer while it is still communicating on the network before making the changes on the router. Understand that this will cause a temporary change in the Wi-Fi indicator light from pattlnk_6172008_1952-tn_grnsolproof.jpg to pattlnk_6172008_1844-orgblksml.gif. After you have made equivalent changes on the router, the printer's Wi-Fi indicator light will return to pattlnk_6172008_1952-tn_grnsolproof.jpg.
    Procedure: How to change security settings via the embedded web server
    If you change your AP security settings frequently, this procedure is for you.
    1. Open your web browser application and enter the printer IP address into the web address field, i.e. http://ip_address.
    2. Click on Configuration.
    3. Click on Wireless.
    4. Enter the SSID, security type/encryption, and network key that will be used to configure the router.
    5. Click Submit.
    Jan 16, 2010 | Lexmark X6650 4-In-One Wireless InkJet...
    Changing the password
    1. Select Configuration|Security from the Access Point menu tree.
    2. Select Modify System Password.
    3. Configure the AP password settings as required:
      System Password Select any alphanumeric, case-sensitive entry of up to 13 characters. The characters selected are displayed as asterisks. Changing this passowrd changes the Read/Write Community password found in the SNMP Configuration screen. The default password is Intel. Confirm System Password Select the same alphanumeric, case-sensitive entry of up to 13 characters as System Password. The characters selected are displayed as asterisks.
    4. Select Save Settings at the bottom of the page.
    Jul 02, 2009 | Intel PRO/Wireless 2011B LAN Enterprise...
    I WANT OT PUT PASWORD TO MY WIRELESS BROADBAND ROUTER SO ONE CAN ONLY OPEN OUR COMPUTER AND SELECTED PEOPLE CAN ONLY USE THE WIRELESS CONNECTION.HOW CAN THIS BE?
    Log into your router by opening your web browser software, for example Internet Explorer. Type in the address field the ip address of your router. The ip address depends on the manufacturer, but it should look something like this - 192.168.1.1 . A window should appear asking you for your user name and password. If the router is set to default settings, the user name should be ADMIN and the password should be ADMIN. Hit enter. This should bring you to your routers configuration window. lynksisssid_thumb.jpgSSID screen.Go to your wireless tab / basic wireless settings. Enter a SSID (wireless network name). The SSID may be on a sticker on the router or you could make one up. Choose a wireless channel. Disable your SSID wireless broadcast. Save or apply changes.
    linksyswep_thumb.jpgWEP / WPA screen.Go to your wireless tab / wireless security. Choose enable. Choose either WEP or WPA encryption, the latter is a more secure choice. Choose 64 or 128 bit encryption, again the latter is a more secure choice. Enter a passphrase and write it down so you can enter it when it is called for when installing the wireless software on your wireless computer. A hexadecimal WEP/WPA key should be generated. Save or apply changes.cheers
    Dec 03, 2008 | Edimax 4 Port Wireless AP Broadband Router...
    AP Mode Problems
    Probably you have to learn that there are various people looking for an access of the internet through your facilities. Anyway, inorder to solve your problem these are the following recommendation I made just for you. Hope this will be helpful.
    PHASE I
    1.) How do I reset the EOC-3220 / EOC-3220 EXT / EOC-3220+ back to factory default settings? An RS-232 null modem serial cable is required for this procedure.
    (where to buy it : http://www.keenansystems.com/store/catalog/product_info.php?cPath=3&products_id=221)
    1. Connect the EOC-3220 to your computer with a null modem serial cable.
    2. Start a HyperTerminal session: Click Start and then select Programs -> Accessories -> Communications -> HyperTerminal.
    3. After the HyperTerminal window appears:
    a. Give this new connection a name. Ex: EOC-3220.
    b. Select correct COM port. Ex:COM1.
    c. Set baud rate as "38400", data bits "8", parity "none", stop bits "1", and flow control as "None". Then press “OK” to bring up the HyperTerminal window.
    4. Wait until the "#" is displayed in the HyperTerminal window.
    5. Type "flash reset", then hit enter.
    6. Type "reboot", then hit enter. After the device reboots, all settings will be at factory default.
    Phase II
    1.) Since that you already reseted the AP you need to use the default IP which is 192.168.1.1 user: admin password: admin
    2.) Make it sure you need to use different IP such as 72.10.251.xxx and the subnet: 255.255.255.xxx
    3.) The idea of configuration in come from your own desire which was no body can no longer try to match your network IP so that there will be no body access your AP anymore without your knowledge.
    4.) You need to make you SSID invisible to everyone inorder no body no longer able to reach your SSID by setting up basic setting which is transparent to everyone.
    5) And lastly change the default user and password of your AP.
    Good Luck
    Nov 24, 2007 | EnGenius EOC-3220 (EOC3220)
    Change name
    You would like to change the SSID to something else?
    The SSID is the name that is broadcasted, the name that you see when you connect to your network.
    1. Log into the web configuration of your router at http://my.router, or the default address http://192.168.2.1. The Enter Network Password login prompt appears.
    2. Type the following text in the user name and password fields: "admin".
      3)
    In the "Wireless" setup tab:
    - Change the default SSID to something meaningful to you, but something that does not give anyone else any hints about your network. For example, using your name or your residence's street address as the SSID is not what you'd call a bright idea.
    Oct 27, 2007 | Dell Wireless 2350 Router
    Wireless security
    Hello sir,
    GETTING STARTED How to Physically Connect the D-Link
    1. Plug an Ethernet cable into the DSL modem. Plug the other end of the cable into the "WAN" port on the D-Link.
    2. Using an Ethernet cable, plug any wired computers into any of the 4 Ethernet ports on the D-Link.
    How to Access the D-Link Configuration Screen
    The D-Link is configured using a Web browser. After you have connected your computer to the D-Link router, follow these steps:
    1. Launch your Web browser. Enter "http://192.168.0.1" into the address bar and press the "Enter" or "Return" key.
    2. A logon pop-up screen will appear. Type "admin" for the username and leave the password field blank.
    3. Click "OK". A D-Link configuration screen will appear. All changes to the D-Link configuration are made here.
    GENERAL SECURITY MEASURES
    Change the Admin password
    Leaving the password blank is not a good idea. It should be changed to something more secure. To change the password, go to the D-Link configuration screen and:
    1. Click the "Tools" tab.
    2. Click the "Admin" button.
    3. Under the "Administrator" heading, enter the new password, and a second time to confirm.
    4. Click "Apply".
    5. The next time you access the D-Link configuration screen, you will need to enter the new Admin password.
    Disable the Wireless LAN
    If wireless access is not necessary, you should disable the wireless part of the D-Link. This will prevent anyone from accessing the network wirelessly. (If you are using the wireless features, please skip down to "Wireless Security Measures".) From the D-Link configuration screen:
    1. Click the "Home" tab.
    2. Click the "Wireless" button.
    3. Click the "Disabled" button next to "Wireless Radio".
    4. Click "Apply".
    5. You are done securing your wired network. No further action is required.
    WIRELESS SECURITY MEASURES
    Enable WEP
    Enabling WEP* (Wired Equivalent Privacy) will require anyone wishing to access the Internet through your wireless network to enter a password. After the correct password is entered, a connection is established, and all data sent from the D-Link to the computer and back is encrypted. From the D-Link configuration screen:
    3. Click the "Open System" button next to "Authentication".
    4. Set the "WEP Encryption" to "128 bit".
    5. Set the "Key Type" to "ASCII".
    6. Type a 13 digit password into "Key 1".
    7. Click "Apply".
    8. When you connect to your wireless network from a computer, you will need to enter the 13 digit password.
    *Note: If your computer's operating system supports it, enabling WPA-PSK is more secure than WEP. The steps above can be modified to set up WPA-PSK.
    Change the SSID
    By default, the D-Link is set to advertise the existence of your wireless network to computers. It does this by broadcasting an SSID (Service Set Identifier), also called a "network name" because it identifies your wireless network. Changing the SSID makes it easier for you to distinguish your network from surrounding networks. From the D-Link configuration screen:
    3. Change the "SSID" from "default" to an SSID of your choice.
    4. Click "Apply".
    Please don't forget to comment this
    Good luck
    Cheers!!!!!!!!!!
    Oct 26, 2007 | D-Link Securicam Network DCS-950G Wireless...
    Zyxel NWA-3160 - Wireless access point - 802.11b, 802.11a, 802.11g  Logo
    63 people viewed this question
    Top Zyxel Computers & Internet Experts
    Prashant M
    Prashant M
    Michael Galve
    Michael Galve
    Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
