Question about Vacuums
I am trying to get to the on/off switch on a Panasonic MC-E851 . One of the two screws has a very unusual head and I Cannot find a tool to fit . What is the head type of the screw called to allow me to buy a tool to foit?
  • 37 Answers
SOURCE: How to remove bottom plate
you will need either a t15 or a t20 torx bit. you should find these at any hardware store.
Posted on Sep 26, 2008
  • 430 Answers
SOURCE: removing cover to motor
You will have to access the motor by removing the entire bottom brush housing and tilting the vac motor shaft out of the housing. Once released you will have a main body and brush housing.
There are visible motor housing screws in the lower portion of the main housing and if I recall there may be twoscrews inside the bag chamber as well
Posted on Sep 09, 2009
SOURCE: Panasonic MC-E450 vacuum cleaner wiring connection access
Disconnect from power first!!
Undo the three screws.
Tap the base of the handle assembly from the front and it will slide back so it can be removed
With the handle removed, pivot up the bottom of the electrical box cover and it will unclip at the top edge.
Posted on Apr 07, 2010
SOURCE: access to panasonic mc e450 electrical supply panel
Disconnect powe
Remove three screws
Tap base of handle from front - it will then slide back
remove handle
Pivot bottom of cover over electrical box up and it will unclip from the top edge.
  • 389 Answers
SOURCE: replace mains cable panasonic MC-e 468
No. Once you've removed the screw, the handle just slides off - either backwards or forwards (sorry I don't remember which, but it's obvious when you've got the machine in front of you).
Posted on May 31, 2010
Brush bar not turning. belt ok
hair carpet strand has to be removed from around brush head mounting location or motor,switch faulty
Jan 09, 2016 | Panasonic Mc-Ul594 Eco Max - Bagless...
Panasonic vacuum cleaner MC-5030 stopped and don't work
Unplug, check if brush has cord wrapped. Check for fuse, if applicable.
Check power lead in another supply socket. Check for reset button, if applicable. Contact Panasonic technical support for suggestions before heading to service centre.
Jun 17, 2012 | Vacuums
Need part number for hose alone for panasonic MCV9610
The following hose fits models MC-V9610, MC-V9620, MC-V9635, MC-V9647.
It can be found at: http://www.pasc.panasonic.com/epartr/PartsListChoice.asp?validate=1
AMC94P-GEZV004
Jan 08, 2011 | Panasonic Vacuums
Panasonic Replace Belt MC-5127
The Panasonic MC-5100 Series takes this belt here:
Panasonic MC-5127 Replacement Belts
Dec 20, 2009 | Vacuums
Removing cover to motor
Sep 09, 2009 | Panasonic MC-V5209 Vacuum
Trying to replace the mains cable on uproght cleaner mc e468,but having great trouble getting the plastic covers off
first remove handle
single screw rear of cleaner and slide handle horizontally rearwards
remove access cover (2 screws) for electrical connections and switch
Aug 09, 2008 | Panasonic Vacuums
My Vacuum Will NOt Turn On and Off
The screws are Torx head screws. If you don't have most places that sell tools should have them.
May 10, 2008 | Eureka 2961AVZ Bagless Upright Vacuum
Panasonic Vacuum MC-E450UK
Panasonic MC-E 450UK upright vacuum cleaner.
Just had this problem myself...........easy to get at it when you know how.
Panasonic UK wouldn't help me so I spent some time working it out..........here it is.
Remove the hose from its mounting storage at the rear (called hose clip) where the main body of the vacuum cleaner meets the base of the handle assembly. Remove the screw at the rear of the handle assembly which is behind where the hose 'was' situated and is located inside the deep recess.
Using the soft part of your clenched hand as a hammer, knock the base of the handle assembly at the front and it will slide backwards off the main body of the vacuum cleaner. Don't be scared, give it a thump and keep moving it backwards with a few more knocks.
Next remove the two screws at the front which hold the mains cable and on/off switch cover in place.
Finally looking from the rear once more, lift the plastic 'lug' at the top of the cover and which is part of the cover. This will now allow you to release the cover and pull it forward.
There you go! Told you it was easy!
Watch out for the funny little spring at the front behind the cover in the tiny plastic tube where it connects to the small rubber tubing as it could possibly try to escape.
You now have complete access in order to cut the intermittent part of the cable out and remove it from the 'choc' block.
Happy fixing!!
Jack.
Apr 07, 2008 | Vacuums
Vacuums Logo
29 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
